Member postings for Anders Elmqvist
Here is a list of all the postings Anders Elmqvist has made in our forums. Click on a thread name to jump to the thread.
Thread: Questions regarding Proxxon pd 230 lathe Chuck mounting/Spindle
01/04/2023 21:10:34
Thanks!
Unfortunately no luck. A Swedish store "HAB" apparently had them on stock ("orderable", but that turned out to be false.
Found some comfort in discovering the ultimate replace for the original o-ring-type transmission belts: https://a.co/d/ieeMlcq
Ome roll lasts a lifetime I'd presume, and has worked great so far. (You easily melt the ends together with a soldering iron.)
29/03/2023 13:17:31
Thanks, Neville.
I sloppily misintepreted your comment above as regarding the four-jaw, but now realise that it was about the three-jaw. On the other hand, hope rises that if the PCD of the three holes on the PD230-chuck (24028?) are the same as on the PD210/ML210, then maybe the PCD for the four holes in the Toyos spindle are also the same as on the 24030. (If that one can be found, that is...)
Also, I hadn't found the later thread, where you had given up on finding a 24030 and state that "Mounting register for the Proxxon Chuck is 40mm and PCD is 34mm. Toyo spindle is a register of 22mm and a PCD 0f 35mm."
( https://www.model-engineer.co.uk/forums/postings.asp?th=180070 )
Bad news, but good to know.
If I find any 24030s left on a shelf somewhere, I'll let you know.
27/03/2023 20:10:24
Thanks for this thread!
I happen to be on the exact same quest; recently got hold of a Toyo ML210 with milling attachment.
Did you make it work in the end? Are the four holes for attachment in the right position?
Best Regards
Anders
