Member postings for Colin Spence
Here is a list of all the postings Colin Spence has made in our forums. Click on a thread name to jump to the thread.
Thread: new to myford lathes
10/03/2023 20:01:01
Posted by Howard Lewis on 10/03/2023 15:51:45:
Once you have made a good machine out of the two, you can use it to make some of the bits forn the cripple to make it saleable.
Sorry to here that someone started to bastardise it by adding some metric hardware.
That makes things confusing for anyone who comes after!
Some of these bodges take moore work to put right than if they had left well alone. $ hours to undo bodge and repair, then 90 minutes to repair the original faukt, if you are lucky.
Tell me about it, I couldn’t believe what he has done, instead of searching around!!!!!
10/03/2023 13:25:31
I have just found another ML4 that I can hopefully use to sort mine out. It looks like an earlier one than mine as it has flat belts, however it has some things I definately need plus extra tools as well. I pick it up tomorrow and once I get it home and look it over I can assess what I need off it and let you know what spares may be available.
09/03/2023 21:00:18
Posted by Georgineer on 09/03/2023 17:59:25:
Howard,
The latest ML4 thread was indeed 1⅛" x 12 TPI, Whitworth profile, as later used on the ML7. The register was 1⅛" diameter rather than the ML7's 1¼".
Quote: " I used one of the genuine ML4 gears as a drill jig, by drilling right thriugh and locating this on a stud over the 7 Series gear. Keep away from the keyway! " - Yes. it works, but I found that when using the gear with the new through-hole, the drive pin tends to escape. I ended up putting a grub screw (M3 from memory) to block the hole off again.
George
Unfortunately a lot of the bolts and screws have been changed for metric and other bodges, really hope I can revive it.
Colin
09/03/2023 20:58:57
Posted by Brian Wood on 09/03/2023 14:30:12:
Colin,
Something odd about the serial number you quote. My Dad bought a new ML4 in 1945; the serial number on that lathe was D 2382. The spindle and 25 T gear fitted to it at the tumbler end were both stamped with the number and other castings etc were also so marked.
The motor drive unit is pure ML4.
Enjoy bringing it back to working order
Regards Brian
Hi Brian, thanks for your reply, there are some components and gears with the same serial number on so it does suggest it could be one of the later ones built. I really would like to get it back to original but not sure its going to happen so good working order is probably the best I could do.
Colin
09/03/2023 14:23:10
Posted by Georgineer on 09/03/2023 12:43:44:
Welcome, Colin. If you haven't already done so, search this site for ML4, followed by ML3, ML2 and ML1. You will find a wealth of information, some of which might prove useful.
Since your lathe has a serial number, it is most likely to be a relatively late ML4. Earlier lathes weren't numbered, and the ML4 is by far the most common version
George
Thank you George, I will look into that, it’s good to get confirmation of the model.
09/03/2023 14:21:25
Posted by Robert Atkinson 2 on 09/03/2023 12:32:02:
Hi,
As it is a long bed and appears to have a bronze bush bearing on the headstock spindle it is a ML4.
The damaged / repaired gear is part of the backgear system that provides low spindle speeds.
Robert.
Thanks Robert, all info gratefully received, I will look into that.
09/03/2023 14:20:03
Posted by Hopper on 09/03/2023 12:31:22:
Lathes.co.uk should have pics to identify which model you have. They also list a lot of serial numbers for some models.
There is also a MyfordLathes group at https://groups.io/g/myfordlathes/topics that has a lot of info on older Myfords both from members postings and in the Files section. There is also a Myford Lathes Facebook page with members with earlier Myfords who may be able to help.
The bottom pic you posted is the tumbler reverse mechanism that goes somewhere at the top of the quadrant on the headstock and engages with the gear on the end of the main headstock spindle. It's purpose is to reverse the direction of the leadscrew for cutting left hand threads or feeding left to right etc.
A good book to give you the basic layout and terminology and how to use lathes of this vintage is The Amateurs Lathe by LH Sparey. Available I think from Tee Publishing.
Thank you for your reply and assistance, I will look into all those avenues!!!
09/03/2023 12:28:26
09/03/2023 11:54:03
img_6141.jpgimg_6140.jpgimg_6139.jpgimg_6138.jpgimg_6137.jpgSome more pics, hopefully someone can identify the model for me, serial number is RD3211.
You will see one pic with a nut wedged where a screw thread should be, botched job but I have no idea what it should look like and even what it is called.
08/03/2023 19:49:09
Posted by SillyOldDuffer on 08/03/2023 19:00:22:
Hi Colin, welcome to the forum. How to add photos is a little strange, instructions here.
Thanks Dave, easy peasy, I have added my pic, I will take more tomorrow and post them as well.
08/03/2023 17:22:14
Hi, I am new on here and trying to find some help with a Myford Lathe I bought a couple of years ago. I am only now getting round to putting it together and setting it up. Firstly I am not now actually sure what model it is, I thought it was an ML3 but now after reading this thread I think it could be an ML4. The serial number is RD3211, I will try to add some pics but at the moment it is stripped down. I am also not sure what the gears are called but again hopefully some pics will help. There is a gear selector just below the headstock with two gears exactly the same, they have 20 teeth each and really need replacing as the teeth are worn. Also the gearbox cover and backplate have been broken, backplate was repaired but not well and the cover looks like it has been glued together. One of the mover wheels has been replaced with a modern round wheel but the screw thread has been botched together, I don’t have a pic of that at the moment due to the snow but will post when I can. I have looked on eBay but I see nothing for the early ML series lathes and all the gearing looks different. Any help at all would be amazing thank you in advance.
Pics to follow When I figure out how to add them!!!! 😉😉😉
