Member postings for James Stanley
Here is a list of all the postings James Stanley has made in our forums. Click on a thread name to jump to the thread.
Thread: Oscillating Engine Simulator
27/03/2023 10:12:46
The latest version now:
  • can simulate double-acting engines (but still only oscillators)
  • has a new air flow method option, from a paper written by the late Bill Hall, sent to me by Duncan Webster
  • plots torque curve charts
  • plots pressure-speed charts
22/03/2023 18:15:37
I'd be really interested to hear how that turns out. I'm not sure how applicable the results will be if your engine is not an oscillator however.
20/03/2023 21:15:07
Thanks for the kind words! And Bazyle I don't think very many people make their own CPU any more, but if you are interested there is a great page at **LINK**listing some of them.
> I am intrigued by the compression loop and even more intrigued by the expansion loop. So what is going on there?
If you assume that the inlet and exhaust ports are symmetrical, then it is always the case that either the port timings overlap each other, or there is a range of positions, crossing top dead centre and bottom dead centre, where neither port is open. This means there is no way to avoid at least a little bit of unwanted compression and expansion, without letting both ports open simultaneously.
I don't have a good intuition for whether you would be able to solve this by making the port locations or sizes asymmetrical - my guess is no, but it might be interesting to fiddle with.
I don't think this unwanted compression/expansion actually costs any *efficiency*, because the work extracted in one cycle of the engine is given by the volume enclosed by the pressure-volume diagram. The pressure spikes enclose no volume, so they waste no energy (i.e., the energy you spent compressing the air on the approach to top dead centre is given back when the air expands after you pass top dead centre). It does however slow down the engine: compare rolling a ball up and down a frictionless hill to rolling it along a flat plane. The ball loses kinetic energy going up the hill and regains it coming down the hill, but it still takes longer to travel any given distance because the average speed is lower.
> Can we persuade you to do one for a compound steam engine?
Quite possibly! There are 2 different directions I want to take this. One is to make it simulate more than just simple single-cylinder single-acting oscillating engines. It would be relatively straightforward to split out the part that computes port overlap areas, and turn it into a pluggable "valve operation" module, where you can select what type of valving the engine has. Making multiple-expansion engines should be relatively easy as well - you'd probably model it as a fixed-volume vessel connecting the exhaust port of one cylinder to the inlet port of the next, and all the air flow calculations remain pretty straightforward. Double-acting cylinders would be similarly straightforward.
Probably the most annoying parts of supporting different types of engine would be making the visualisation and the user interface handle all the different possibilities.
The other direction I want to take it is to have it take some constraints and goals, and then it would automatically fiddle with the engine parameters to try to optimise the engine. For example, with displacement below 5cc, with 20 psi air supply, find the most efficient engine that can supply at least 1 Watt, below 1500 rpm.
> Not stupendously difficult, pressure sensor on cylinder, slotted wheel on crankshaft and a data logger.
Yes, I think this would be very interesting to do. Sadly I'm much less competent as a machinist than as a programmer, so my engine build is progressing much more slowly than my simulator did. But I definitely want to try to plot a pressure-volume diagram from a real engine. I suspect the limiting factor will be finding an inexpensive high-frequency pressure sensor.
20/03/2023 14:15:03
(My apologies if this is not the correct section of the forum, I couldn't work out a better fit).
I've been working on a simulator for oscillating engines that I would like to share in case anyone is interested, you can use it online: https://incoherency.co.uk/oscillating-engine/
The colour in the cylinder is an indication of the pressure (red is high, blue is low).
The colours shown on the flywheel indicate the port timing (red means inlet port open, blue means exhaust port open, the thickness tells you how wide it is open).
The plot on the right-hand side is a pressure-volume diagram, with the blue and red horizontal lines representing atmospheric pressure and inlet pressure respectively.
I think it should mostly be physically accurate, the main weaknesses are:
1. it assumes the supply pressure in the inlet does not momentarily drop when the port is open, even if you make the hole really large.
2. I don't have a decent model for the inherent friction losses in an engine, so you might find that the simulated engine ticks over substantially faster or slower than a real one with the same parameters - in this case please let me know and I'd be keen to integrate your data into the loss model!
If you want to know more or need help using it just ask. I also have written a blog post that goes into more technical details: https://incoherency.co.uk/blog/stories/oscillating-engine-simulator.html
Edited By James Stanley on 20/03/2023 14:16:37
Edited By James Stanley on 20/03/2023 14:16:51
Thread: Mini surface gauge from "Lathework: a complete course"
03/03/2023 16:41:26
Well I am happy to report that I have made the device function, to an extent.
I re-cut the threads on the stud as tight as I could get my dies to go, and I also drilled out some of the internal threads in the "bush" part so that it is not engaging on such a long length of the stud.
It's still quite tricky to turn, but it does work. In the image below you can just about see the range of adjustment I get from the fine-adjust knob, it's about 1mm (but obviously varies depending on how far the scriber sticks out), see the 2 horizontal scratch marks on the can:
Thanks everyone for the comments and advice! I will remember the trick of using the tailstock to push the die for next time I need to cut a straight thread.
01/03/2023 18:08:43
Thanks for the many suggestions! Jim I'm not sure if it's encouraging or discouraging that your device didn't work either .
Making the part by cutting an M6 thread onto the head of an M4 allen bolt is an interesting idea, I hadn't thought of that. An M4 bolt on its own wouldn't work, the way this part works is the difference between the pitch of the M4 and M6 thread is used to either jack open or close up the slotted part of the base, to tilt the column over.
It has occurred to me that in use, the portion of M4 thread nearest the shoulder (save for the last couple of mm, which are also unused) is actually in use - and due to the taper of the die, this is also the portion of thread that is least well-formed.
So if I simply reverse the die and cut it as far as I can go, that might salvage it without having to remake the part. You can see in my picture that the last few threads are chunkier than the rest.
Failing that I will have another go at this part, and try Bizibilder's suggestion of using the tailstock to push the die square.
Edited By James Stanley on 01/03/2023 18:09:45
28/02/2023 10:44:20
Has anyone successfully made the "mini surface gauge" from chapter 2 of "Lathework: a complete course"? Did it work?
Here's mine:
I have made it but the fine adjust knob is unusably difficult to turn because I didn't manage to get the threads on the adjuster stud sufficiently precise.
Here's my adjuster stud:
You might be able to see that the M4 (smaller, longer) portion is "wavy". I attribute this to making the thread with a die in the vice, instead of using the lathe. The book suggests that a tailstock die holder would work better, but since tailstock die holders aren't introduced until chapter 7, we are told to cut the thread with a die for now.
Is there a trick to cutting straight threads by hand? Or is it a case that the part simply can't be reliably made to work until you can cut the thread in the lathe?
