Member postings for Elliott Trent
Here is a list of all the postings Elliott Trent has made in our forums. Click on a thread name to jump to the thread.
Thread: CVA mk1A Lathe Oil Change
04/02/2023 16:59:28
Hello everyone!
Brand new here and just getting into machining through a friend.
Basically I've picked up an absolutely wonderful (albeit incredibly heavy!) 1977 CVA mk1a toolroom lathe.
It all functions wonderfully but it certainly needs some cosmetic work and general servicing. I'm beginning by flushing all the oil out and I'm struggling to get all of the sight glasses drained. I've found two drains in the side part behind the belt cover, basically the headstock drain is at the top and the gearbox is down the bottom. I'm struggling to find any others - will they potentially be far away like down in the apron from the feed there?
Glad I did it, the oil in the headstock was milky, but I'm struggling to drain 3 out of the 5 sight glasses so any suggestions welcome! I konw its based on a 10EE and they suggest you need to remove the sight glasses, but these arnt a simple screw on arrangement like on the monarch, i imagine they are designed to be punched out from inside once fully taken apart?
Thanks in advance!
Elliott
