Member postings for Nick DoubleYa
Here is a list of all the postings Nick DoubleYa has made in our forums. Click on a thread name to jump to the thread.
Thread: Warco WM290 or GH600
21/07/2023 13:36:39
Thanks guys this is really good info!
My Myford has a 3/4 Hp motor and it seems perfectly fine for aluminium too.
Some other questions would be
How did you lift and move it around? Engine crane OK?
Is it delivered on the stand or separates?
Where would the straps go on the lathe and should I even bother getting it with the stand, or are they too flimsy to bother with?
Anyone got the DRO version, and if so are there any problems with the DRO scales blocking anything?
I think the GH600 is probably the way to go. I even have loads of old motor oil I can use
21/07/2023 10:17:19
Hi there, I'm selling my Myford and looking to get a slightly larger lathe. I will be using it for thread cutting, turning metric threaded adaptor parts about 3-4" in diameter.
The threads on the parts will be ISO metric 0.75mm, 1.0mm and 1.25mm.
I want to be able to switch quickly between these threads without having to play with changewheels like on the Myford which takes too much time.
The reason is that the threads are on the inside and outside of the part and I wouldn't need to remove it from the chuck. It would be batch-work.
I will use a DRO to get the part to the correct dimensions quickly.
My question is, would the GH600 or WM290V be better for this purpose, and which would be quickest?
I would like the ability to reverse without having to keep the nuts engaged if possible, and without the chuck falling off like you would get with a Myford.
Any advice or comments, appreciated, thanks in advance.
Thread: Myford Metric Lathe Leadscrew
30/12/2022 13:04:23
Posted by JohnF on 29/12/2022 10:18:58:
Hi, The OP Nick did not say whether his machine has a screw cutting gearbox or not ? Looking at the charts he has posted probably not so this link to a previous post relating to the Myford-metric-threading may not be be appropriate to the OP ? Nevertheless it is an interesting post on the subject.
https://www.model-engineer.co.uk/forums/postings.asp?th=125630
Regarding the video showing the method of using a thread dial indicator, I was taught this back in the early 1960's by my mentor during my apprenticeship and have passed it on many times - so many I "wrote it up" some years back and later added a link to the excellent video by OX Tools.
The method can of course be used on any machine fitted with a thread dial indicator and works from imperial to metric or vice versa.
Hi John just to answer the lathe is without quickchange gearbox but it has the full set of metric change gears so quite a lot of work to switch between threads if say making an adaptor. On the other hand it's also got the full imperial range. The tailstock has metric scale and so do all micrometers.
Edited By Nick DoubleYa on 30/12/2022 13:05:07
29/12/2022 03:36:57
If you have a thread dial indicator on your machine, there is a way to make your life easier, when cutting up to a shoulder, but reversing the lathe to run back to the start must be done electrically via the motor on a Myford.
If you can't currently reverse your motor electrically, shout up and you should get some assistance on the wiring and switching.
For the time being, don't try machining with the lathe in reverse; there is a chance you could unscrew the chuck, this is only about returning the carriage for another cut.
Bill
Thanks for your help, Bill. I have a thread dial indicator with the usual 1234 on it. I'm guessing the little gear would have to have a special ratio or something.
Also, more importantly, I do appear have a motor capable of reverse. Here's the motor info plate. I would definitely need some sort of switch preferably a lever mounted on the lathe or stand enabling easy reversal for each pass, as you say. Any safe solutions you can suggest would be much appreciated. Regards, Nick
Edit: Although I've created an album, after hunting around a bit, it doesn't seem to have an edit option to add more images or tidy up existing ones, so I don't want to create a new album for every time I post. Anyway, the motor does appear to be reversible by switching the polarity.
Edited By Nick DoubleYa on 29/12/2022 03:48:54
28/12/2022 19:18:04
Posted by Mike Poole on 27/12/2022 11:58:37:
The metric pitches on the chart are extremely close approximations for a metric pitch, there never has been a Super 7 with a metric leadscrew . Don’t worry about the threads being approximations, unless you have high end metrology equipment you will not measure the error. For most practical purposes it will be satisfactory. The only way to cut a true metric thread is to use a 127 tooth gear in the gear train. 5 inches is exactly 127mm which is where the conversion comes from. Using the metric setups in the table will mean not disengaging the half nuts and reversing the lathe to start the next cut. There are other methods but not disengaging keeps it simple. Plenty has been written on screwcutting both online and in print.
Thanks Mike, I think the only option is to wind the chuck back by hand for each pass? I imagine if I engage the tumbler gears to reverse it, backlash would cause thread misalignment?
28/12/2022 17:46:29
Posted by Hopper on 27/12/2022 10:49:10:
Is it a metric Super 7, or just an Imperial Super 7 with a metric screwcutting chart? Seems odd for a metric lathe to list imperial threads first, metric second.
Are the cross slide and top slide collars graduated in metric or imperial?
Hi there, the lathe is an original metric one with 0.05mm micrometer graduations and all the metric listed gears are included. That's why I was wondering about the leadscrew.
26/12/2022 20:34:13
Hi guys, I've lurked on this forum for some time and finally joined, seeing I recently acquired a metric Myford Super 7.
I've many questions about these lathes. Firstly I was wondering what kind of leadscrew I have, seeing the tables look quite different to pictures I've seen online?
I'm after 1.5mm on this table
Zoomed out
Sorry the pics aren't orientated correctly they look fine on my phone.
Edited By JasonB on 27/12/2022 06:49:45
