Here is a list of all the postings Darakhshan Muqaddas has made in our forums. Click on a thread name to jump to the thread.
Thread: Donations to the website |
21/09/2022 12:07:48 |
That is a big problem what one should do. |
Thread: 7 1/4" Dart Martin Evans or John Smith |
21/09/2022 12:05:19 |
D Goodwin was Dave Goodwin from Rishton close to Blackburn, a free castings provider. The codes are his projecting rundown codes - DT for Dart castings. He was dynamic in the 80's and 90's, perhaps likewise the 00's. |
Thread: Donations to keep forum free |
21/09/2022 12:04:15 |
this is paving the way to a paywall presentation, then, at that point, Morton's can stuff it. In the event that, as JasonB says, numerous clients don't contribute anything, all good - charge them. Simply save free use for those ( like me ) who have a membership as an advantage of same. Been taking ME for 60+ years and MEW from no. 1. The greater part of those 60 years oversaw without web's new innovation so won't miss the Discussion enough to want to pay for it on top of two costly memberships. |
Thread: ER25 MT2 |
21/09/2022 12:03:45 |
My min-factory is a morse 3 shape. The devices I use, from a drill throw, through ER32 holder to a face factory all delivery with a sharp tap from a respectable size hammer very much like morse tooling consistently did. I have preferred activities over faff about with a self delivering game plan. |
Thread: Digital Archive - Again! |
21/09/2022 12:02:57 |
Darren, one thing I have seen is on the off chance that I go to Magazines, select ME or MEW and login it doesn't take me to the most recent mag however the first from when your new watcher became dynamic. Eg Model Designer opens 4693 not 4696 so I need to then get document up and choose the most recent issue. |
Thread: Galloways NDC engine - oil feed |
21/09/2022 12:01:58 |
Running on air or steam Ransack I would take care of into the steam chest. Ensure you have method for metering and a detour back to the repository however - needn't bother with a ton in the event that it's for show running as it were.
Could it be said that you are mindful of Albion Composites copper tubes? They truly do some extremely fine drag ones reasonable for plumbing oil lines however you really do need to make your own associations
Pull |
Thread: Drawing Projections |
20/09/2022 13:21:50 |
During my functioning life I just at any point met first point projection once. I needed to deliver a sketch changing a complicated spine and didn't understand the first drawing created by a German firm was first point projection. Luckily when the rib was set-up on the dance drill nothing checked out and I was called for.
Never expect a drawing is third point projection. In the event that it isn't you can deliver a dreadful wreck. |
Thread: cable core colours for 3 phase motors |
19/09/2022 12:56:39 |
wouldn't consider rubber to be oil resistant. In fact I'd be surprised if you can still get it. Google will give you the current colour codes |
