Here is a list of all the postings brett slater has made in our forums. Click on a thread name to jump to the thread.
Thread: Emco Compact 5 - complete newbie |
12/06/2022 19:47:39 |
Having spent some time cleaning/dismantling etc I've realised there are a few things that i need to add to the machine and I'm hoping that someone can help with this. in terms of where i can source the parts... Firstly a milling table, do i need an Emco original or are there other suppliers whose products could be attached ? Ditto for a back plate. A collet chuck for the lathe itself, again are there generic makes that i could buy for this, should i look at a one that attaches to a back plate or directly to the spindle ? I seem to be missing some of the black screws that are used to attach the 4 jaw chuck to the spindle - do these have some sort of generic designation ? Thanks in advance ! |
03/06/2022 16:06:43 |
@Howard/Graham Thanks for the tips - I'll have a look at some of these titles if they're still available. At the moment I'm dismantling, cleaning and lubricating the machine as i think its been sitting in a shed for a couple of years unused. Once thats done i'll pick a small project just to familiarise myself with the working s a nd see how it goes from there ! |
29/05/2022 09:57:02 |
Posted by Thor 🇳🇴 on 28/05/2022 16:31:09:
Hi Brett, Welcome to the forum. I have a PDF of the manual if you are interested. Thor Edited By Thor 🇳🇴 on 28/05/2022 16:50:11 Thankyou for the offer. The lathe actually came with the original manual but it only covers the lathe not the milling attachment. |
29/05/2022 09:52:06 |
Posted by Jouke van der Veen on 28/05/2022 20:19:51:
Hallo Brett, There is a radial hole in the mill spindle, above the chuck. You place a long (dovel) pin in that hole and a second pin in one of the key holes in the chuck. By squeezing by hand the two pins together the chuck will come loose. The chuck has M14x1 RH thread. A manual for Emco Compact 5 will help you a lot. Mine is in German. Regards, Jouke
Perfect thats done it - the collet holder is now attached !
28/05/2022 15:44:41 |
I'm a keen modeller but have never really done any metalwork until now . I 've just bought a second hand emco 5 with milling attachment and a set of ER collets plus the holder that looks like it should attach to the drill press. I cannot for the life of me figure out how to remove the drill chuck - could someone help me out please ? Also can anyone recommend a good book to help me get started - at this stage even the terminology is new to me. I'm sure i'll be adding more daft questions as i explore the new toy ! |
