Member postings for Igor P
Here is a list of all the postings Igor P has made in our forums. Click on a thread name to jump to the thread.
Thread: Stepper motors
25/03/2022 20:34:40
Can you post a link to the controller and the exact DM542?
Thread: Gib missalignment
25/03/2022 20:18:49
Many thanks for all your support guys, much appreciated. I decided to leave it like this for now, untill I make a new jig, just to machine the gibs. I will probably use the ball endmill technique described in one of the links.
I have a further question regarding rigidity. Is my thinking this is compromised right now correct, or not really?
23/03/2022 19:13:25
Posted by MikeK on 23/03/2022 13:26:56:
The roughness is probably just the very end of the channel. Worth noting that the gib screws on these are often the cause of problems, forcing the gib at an odd angle.
Thanks MikeK!
23/03/2022 19:11:58
Posted by pgk pgk on 23/03/2022 10:53:08:
Perhaps some more info re how you went about it and pictures if possible might get some folk on here to have ideas about what went wrong.
I see there is a thread about these here
https://www.model-engineer.co.uk/forums/postings.asp?th=100234
pgk
I machined a 60° angle, just found out today it is supposed to be 55°.
23/03/2022 19:03:46
Posted by John Hinkley on 23/03/2022 13:09:14:
Blimey! Where do you begin with dovetails cut like that. I'd be doubtful if you'd get any improvement without re-machining the sliding surfaces. Sorry to be so negative, but I think you've got a bit of a Friday afternoon mill there.
I also have distinct feeling this machine was made Friday afternoon just before Chinese new year after a few glasses already.
Edited By Igor Petejan on 23/03/2022 19:10:20
23/03/2022 19:01:54
Posted by Roy Vaughn on 23/03/2022 15:37:37:
I second what MikeK has said. I've just been through this with my X2. I machined the gib screws to a point which improved things a lot.
Will give it a try. Some prefer pointed gib screws, some say flat, I checked mine and they are flat. What about rigidity? Increasing it would be my goal. Also reduced friction, but that I already got due material combination.
23/03/2022 18:45:33
Picture of old gib.
Picture of new gib
Picture of new gib at an angle
I have no idea why pictures do not show.
Edited By Igor Petejan on 23/03/2022 18:56:16
Edited By Igor Petejan on 23/03/2022 19:09:46
22/03/2022 23:45:41
Hello.
I have made a new brass gib for my SX1 mini mill.
They look bad and contact only on two lines and not 2 surfaces. Why did this happen?
