Member postings for Andrew Crow
Here is a list of all the postings Andrew Crow has made in our forums. Click on a thread name to jump to the thread.
Thread: Help to identify Gauge 1 4-4-0 loco
04/08/2023 09:43:43
Hi Mick, back in the nineteen seventies Don Young designed a 4F loco in 3 1/2 gauge and that used Joy valve gear which might help. It looks like you already have the weigh shaft, however you would need a reverser in the cab and corresponding reach rod. I think I may still have the original article and could possibly email you the appropriate pages if you are interested.
Andy.
Thread: Material for Collet Holder
30/05/2023 21:22:06
Hi Steve, when I owned a BCA Miller I made 2 er collet chucks and the material I used was what used to be known as EN24T now 817M40 it's a high tensile steel but machines well and should have all the strength and wearability needed
Thread: Drilling deep holes - 10x drill diameter - Runout?
05/02/2022 19:27:35
Most drills wander slightly caused by various factors and exacerbated as the hole is drilled deeper. The best way I have found to keep the hole true is to start with a centre or starter drill followed by a drill about 1/32 under finished size then bore the hole to just under the next drill size that will leave a few thou for reaming. Bore as deep as possible, follow up with the next drill ( at a reduced speed, about half normal drilling speed) which should follow the bored hole then finally use the reamer. It sounds a bit laborious but does work.
Thread: Anybody else remember Chuck the Muddle engineer?
30/01/2022 16:56:03
I remember Chuck and always looked forward to the next cartoon as a bit of humour was and is always welcome. Amid the humour though, Terry always raised a valid point on good engineering practice and safety in the workshop.
Thread: Graham Meek Myford Super 7 Screw Cutting Clutch
29/01/2022 10:43:50
Hello Ken, many thanks for your reply, I think I have the grasped the concept, I assume that this device also eliminates anti-rotation pin. I have an old selector handle from an ML7 which I will try to incorporate into the design if it doesn't involve too much carving of the gear cover.
Best regards,
Andy.
28/01/2022 19:25:36
Many thanks to everyone for the information to my query, lots of useful points which I will try to incorporate. However, one further question has cropped up concerning a disengagement arrangement. I am assuming that this involves using something similar to the existing Myford tumbler arrangement. I would like to incorporate this as it's useful to disengage when using the leadscrew handwheel for milling.
Any information would be gratefully received.
22/01/2022 17:39:32
I have read Graham's article on the Myford screw cutting clutch which contains quite a bit of grinding. I don't have grinding facilities and I'm not sure I would want to cylindrical grind on my lathe. Have other builders completed the unit without resorting to grinding?
