Here is a list of all the postings The Real Ron Skingley has made in our forums. Click on a thread name to jump to the thread.
Thread: Tap Extractor |
15/09/2021 08:00:57 |
Thanks for all the replies. |
14/09/2021 21:29:51 |
Not having any luck with scriber and small hammer. |
14/09/2021 18:51:35 |
Ah yes, a sort of DIY extractor. Most if not all my 'stock' is mild. Only three flutes on the tap, so some very careful work required with the junior hacksaw. Thanks. Edited By The Real Ron Skingley on 14/09/2021 18:52:15 |
14/09/2021 18:38:54 |
Yeah, still trying the scriber method. Edited By The Real Ron Skingley on 14/09/2021 19:09:48 |
14/09/2021 18:28:40 |
Hello All, Had to happen eventually with clumsy fingers. Finished with taper tap, just started to remove the plug tap, and a careless move and it was broken off flush. In cast iron. |
Thread: Hole in tool post |
13/09/2021 13:03:03 |
Other problems with this is, 4 jaws and 6 spokes. |
13/09/2021 12:20:55 |
OK, to be fair, I've just tried it again, and it is possible, just. But VERY dodgy. Literally another quarter turn on the key and the jaw falls out. |
13/09/2021 12:11:22 |
Yep. Won't reach. |
13/09/2021 12:01:12 |
Posted by JasonB on 10/09/2021 16:03:11:
Victoria flywheel should be OK held with a 4 jaw gripping inside the rim. I hardly ever use a faceplate for turning flywheels finding the 4-jaw much better. 4 jaw not big enough to get to the rim. |
11/09/2021 11:26:08 |
That's a nice mod Martin. Unfortunately I can't do away with the topslide. |
10/09/2021 20:01:47 |
That looks good. If only I could do away with the topslide I might do something similar. |
10/09/2021 18:58:43 |
Well I could of course. |
10/09/2021 18:04:53 |
I think I might be on the way. So now I've got a 7" faceplate that mounts in the four jaw chuck, and can be jiggled to get the flywheel running true to the inside edge of the rim. And take things very carefully. |
10/09/2021 17:47:42 |
Posted by DiogenesII on 10/09/2021 16:22:27:
Faceplates.. ..Just on the off-chance, you might as well give us the the spindle nose / flange dimensions.. ..even if nothing used turns up, you might at least find out if something new can still be obtained..? The chuck mounting is a bit of a pain. |
10/09/2021 16:05:35 |
Yep. But my 4 jaw won't reach, it's too small. |
10/09/2021 15:51:42 |
Yes, thanks all. |
10/09/2021 14:56:27 |
Posted by Michael Gilligan on 10/09/2021 13:49:56:
On the original Dickson tool-posts, a hole was intended for an alignment pin. The purpose of any ‘similar’ hole on a ‘clone’ is still open to question. MichaelG. . Ref: **LINK** Edit: __ as a slight digression: The patent for a tool-setting fixture is worth a look: Edited By Michael Gilligan on 10/09/2021 13:57:27 Patent makes interesting reading. |
10/09/2021 14:07:28 |
That's a good idea. |
10/09/2021 13:55:00 |
Ah yes, thanks. The Dickson one has the pin square-on which would make sense. |
10/09/2021 13:48:52 |
Thanks for the offer Mike, but I'm in SW Ireland. |
