Member postings for Maarten Kip
Here is a list of all the postings Maarten Kip has made in our forums. Click on a thread name to jump to the thread.
Thread: Skoda M11 30.5 mortar drawings
14/09/2022 13:06:04
Hai Mike,
Thanks for the quick response. Yes, those drawings are already in my collection. The drawings from landship are usefull because they have a rudimentary scale attached to it.
kind regards,
Maarten
14/09/2022 12:45:22
Greetings,
My name is Maarten Kip and i am relatively new on this forum. For some time now i am studying the Skoda M11 30.5 mortar and am planning to build a scale model of this piece of artillerie. I wrote to several museums (for example the "Heeresmuseum Vienna" with the question if they have technical drawings or bleuprints of the mortar. Sofar i have been out of luck. I am able to distill some measurements from photographs but have a lot questions left. S my question is does any of you know if there are drawings\bleuprints and if so how to obtain them. (i have written a request to the Skoad factory archives also).
Kind regards,
Maarten
Netherlands
Thread: Milling problem
20/12/2021 13:30:01
Hi there,
As i am relatively new to milling i was wondering what i am doing wrong. When i am milling (conventionally) over the X axis and traverse over the Y, my mill performs well. But when i move the X,Y table over the Y axis and traverse over the X axis my mill creates little steps in the surface. The steps occur on the side opposite where the mill is cutting. It looks like the mill is cutting a 0.08 of a millimeter or a 0.003. I can feel ridges whit my fingernail.
I have tried to tram my mill to my best abilities.
Kind regards,
Maarten
Thread: Milling cutter advice
20/12/2021 13:15:36
Thanks Clive for your elaborate answer!
09/12/2021 15:46:13
Thanks Jason and Thor!
09/12/2021 13:25:07
Hi to all,
I am relatively new to milling and was wondering if anyone could give me advice wich milling cutters are a good start for a beginner?
I have an Emco mill with ESX25 (ER) collets. Mostly i am planning to mill aluminium, brass, bronze, cast iron and mild steel.
What size is usefull and what geometry of the mill cutters? Finger, ball, 2 flute, 3 flute etc.
Will Weldon shafts fit into ESX25 (ER) collets?
Kind regards,
Maarten
Thread: Teco VF400
07/09/2021 12:09:32
Posted by mgnbuk on 07/09/2021 08:35:57:
That looks rather like a modern incarnation of the old East Germany manufactured Hobbymat milling machine.
The head & column assembly could be fitted to a bracket mounted behind the Hobbymat lathe bed, or mounted in a separate X-Y table assembly to produce the stand-alone milling machine. Much along the lines of the Emco FB2 milling machine, but smaller. IIRC the original DDR machine was a 1MT spindle, but I could be mistaken.
Hobbymat mill
Nigel B.
By the looks of it i had already deduced it was based on the Hobbymat/Saupe Mill. Those had 1MT spindles. The Teco has a 2MT spindle.
07/09/2021 08:20:59
Posted by ega on 06/09/2021 11:09:45:
Posted by Speedy Builder5 on 06/09/2021 08:17:39:
My only comment about the Tevo machine is the round column. If you need to change the head height, you may loose registration on the x-y axes.
There seems to be a key at the rear of the column.
Looking closely at the pictures of the backside of the machine i am not really sure. Could be a key but could also be the acme thread for the Z axis.
07/09/2021 08:18:41
Posted by Ady1 on 06/09/2021 08:23:58:
I would look at videos to get a decent feel for the racket they make
You will also need to do sound reduction stuff, like rubber feet, some vibrations can go through an entire building
Can you hear neighbours washing machines?
My small workshop has fibration reduction matting. I allready have a lathe and so far so good there are no complaints altough i have done quit a bit of lathe work.
07/09/2021 08:16:42
Posted by ega on 06/09/2021 11:05:36:
For the benefit of possible future searchers: is there a typo in the heading and, if so, could it be corrected (Teco is a brand of VFD).
PS Just looked at the link and it seems the typo is in the post - my mistake!
Edited By ega on 06/09/2021 11:07:57
Yes, i'm sorry. Mistake is on me. Thanks for the input!
06/09/2021 07:51:25
Hello everyone,
Forgive me beforehand if the following has been answered in a earlier thread or if i am mistaken by posting in this section on the forum. I am still a newbie on this website.
Has any of you experience with the Tevo VF400 Mill as advertised here:
The reasons i am interested in this machine are the following:
- In the advertisement it is said it is extremely quiet wichj is important for me because i live in an appartement with tennants all around me.
- It is not so heavy, and i will do only small work.
- I like the simple way it is constructed.
I know it has its limitations but for me thats no issue.
An alternative for me would be the Wabeco 1200
Kind regards,
Maarten
Thread: Hello from the Netherlands
06/09/2021 07:41:07
Posted by speelwerk on 02/09/2021 13:31:07:
Hello Maarten,
This time in English since that is the language of this forum.
Yes, I have done work for Museum Speelklok **LINK** but that was a long time ago. I stopped with working for them, too much problems about money. After 41+ years I am winding down on repair work, done it enough and also because of personal circumstances. You can see and hear some work I have done on **LINK** Niko.
Posted by Maarten Kip on 02/09/2021 11:57:30:
Posted by speelwerk on 01/09/2021 17:02:41:
Dag Maarten, dan maar even in het Nederlands welkom heten. Er is hier heel veel kennis en kunde en ze zijn erg aardig en behulpzaam maar soms zijn ze wel een beetje aan het gekken. Zelf zit ik in een plaats 15 km ten noorden van Utrecht, doe niet aan modelbouw maar restauratie van mechanische muziek, voornamelijk uit de 19de eeuw. Niko.
Edited By speelwerk on 01/09/2021 17:04:30
Dag Niko, leuk zo'n welkom! Ben echt een beginner, dus alle hulp en advies is meer dan welkom. Doe je ook werk voor speelklok tot pierement? Ben geintresseerd in automata. Ik zit oostelijk van Utrecht en werk vlakbij stadion Galgenwaard. Hartelijke groet,
Maarten
Hi Niko, that's impressive work! I really like the pin making machine.
Kind regards,
Maarten
02/09/2021 12:01:44
Posted by Wout Moerman on 01/09/2021 19:36:41:
Welkom Maarten!
I'm in Nijmegen and love this forum. I use my tools to make more tools and do repairs and modifications in and around the house.
Thanks Wout,
Nice, i used to visit Nijmegen on a regular basis. Nowadays i sometimes visit Molenhoek (Locloods) or visit Kelders in Boxmeer for materials etc.
Hartelijke groet,
Maarten
02/09/2021 11:57:30
Maarten
02/09/2021 11:50:54
Posted by Brian H on 01/09/2021 16:52:11:
Thank you for that Maarten. I often holiday in Schagen in the North and have passed through Utrecht but not stayed.
What sort of projects are you interested in?
Utrecht and its surroundings are beautifull. The city of Utrecht is worth a visit! I am interested in Engines, internal combustion, steam, Stirling etc. Also automata are a field of interest.
02/09/2021 11:47:17
Posted by Harry Wilkes on 01/09/2021 15:29:53:
Welcome to the forum
H
Thank you!
02/09/2021 11:46:55
Posted by Steviegtr on 01/09/2021 15:18:20:
Hello & welcome Maarten.
Steve.
Thanks Steve!
01/09/2021 15:34:28
Posted by Brian H on 01/09/2021 15:21:56:
Hallo Maarten and welcome. Where abouts are you in the Netherlands?
Hi Brian
I am working and living in the vicinity of the city of Utrecht
01/09/2021 12:00:56
Hello to everyone, just to introduce myself. My name is Maarten, i live in the Netherlands and have a very small amature workshop wich i enjoy a lot. Interested in all things mechanical and 19th century engineering. Looking forward to learn from this forum. Kind regards, Maarten
