Member postings for Michael Brett 1
Here is a list of all the postings Michael Brett 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford cross-slide
31/08/2021 09:40:42
I took the handle of and the spring was in place and seemed in good condition. It was all very dirty though with lots of swarf mainly brass. I gave it all a good clean and now it is working fine. Must of been all the muck stopping it getting enough grip. If I have any more trouble I will order another spring. Thanks for all your advice.
Cheers Mike
30/08/2021 20:42:29
Hi al
I have a Myford super 7 lathe ,imperial version. On the top slide the marking ring turns with the hand wheel as it should . But on the cross-slide the marking ring almost spins freely, which means I cannot use it for measuring how much I am turning off. Is there some sort of clutch mechanism , if so how can I tighten it up.
Or does something need replacing. Thanks in advance for any help.
Thread: 80mm milling vice
03/08/2021 18:36:40
Thanks for the advise folks, I have now worked out what needs to be done. I just did not want to butcher all the parts then find out there was another way of fitting it. Yes I have got the fixing kit with 8 mm bolts but I am going to try and grind down the 10 mm bolts at the base as they will be a better fit on the vice base. Will also use a couple of tee nuts ground down for the location slides.
Wish me luck Mike.
03/08/2021 17:26:08
More problems
I purchased a SX2P mill from Arc Eurotrade along with a 80 mm radial milling vice which was recommended for this machine . However when it came to fitting the vice the bolts supplied are 10 mm while the slots on the table are 8 mm.
Also the guide blocks on the vice are 14 mm so cannot be used in the 8 mm slots on the table.
All seems very strange when they are supposed to be compatible .
Has anyone else come across this problem and managed to find a solution.
Thread: Seig SX2P mill
03/08/2021 13:41:02
Done it,
Many thanks guys, Mike
03/08/2021 13:02:23
My mill has the hole on the spindle, not very easy to get a grip on . Tried turning the nut on the top anti clockwise , goes about 1/8 th of a turn then locks solid. How much force should this take to release it , afraid of breaking something.
03/08/2021 12:19:06
Hi
Just trying to set up my new SX2P mill. Instructions say insert pin in column and turn wrench counter clockwise . Tried this but it seems to be tightening it up. There seems to be a grub screw on the actual collar, wondered if I had to remove this first. Anyone got one of these.
Thread: Hit and miss engine
16/07/2021 17:37:36
Many thanks for replies
John PM sent.
Regards Mike
16/07/2021 16:18:55
Hello all
After building many steam engines , both stationary and locomotives, I would like to try something a little different. I have searched on the internet for plans to build a hit and miss engine but to no avail . Has anybody had experience of these engines or know of a source of instructions to help me on my way. I don't think I can run to a set of castings but would prefer to build from bar stock.
Cheers Mike
Thread: Lumps of aluminium and brass
15/07/2021 08:39:31
Thomas PM sent.
14/07/2021 16:30:17
Steve
Yes you would think so . but according to most of the people I spoke to on the phone its not going to make much difference straight away. One said call back in a couple of months when things go back to normal.
14/07/2021 16:02:40
Hi all
Before Covid I used to go to my local metal stockist ASC in Peterborough and get of cuts of brass and aluminium at prices so low ,made me feel like I was robbing the place. Now though because of the pandemic they are not letting the public in, along with others that I have tried in my area, Does anyone know of a stockist in my area that has of-cuts fore sale. I am fed up with paying FleeceBay prices.
Thread: Tich cylinders
05/04/2021 16:11:45
Many thanks for your replies . I have now taken the plunge and machined the eccentrics to the drawings kindly posted by Nick Clarke. Moving the valve seems to open the ports the same as other engines I have built so all seems as it should.
05/04/2021 10:53:50
From the diagram above I read the eccentric throw as 9/64 x 2 which is about 7.2 mm throw.
From another site on the web someone has stated that this does not give enough port opening and the throw should be 11.13 mm .
Now I am confused , which is correct.
26/03/2021 20:30:26
Hi Nick
Many thanks for the information.
Regards Mike
26/03/2021 15:40:14
HI again
I have ended up with a throw on the crankpin of 17/32 between centres. All I need to know now is what is the throw between centres on the eccentric.
Any ideas Mike
21/03/2021 19:19:23
No think I made a mistake there , distance between crank centres would be half that , 1/2 plus 1/16.
21/03/2021 19:16:58
Many thanks for replies. I should have made it clear that the cylinders are complete and finished , so no chance to alter that. Just to get this right as I understand it. Cylinders are 1 3/4 inch minus 1/8 inch for caps = 1 5/8 inch minus about 1/2 for piston , so distance between crank centres would be 1 1/8 inch, correct ?
21/03/2021 12:14:49
Hi all
I have acquired a pair of Tich 3.5 inch gauge cylinders that I intend to use as the basis for a twin cylinder horizontal mill engine. My question is does anybody know what the piston stroke is on this engine. I just need the distance between the centre of the big end crank to the centre of the small end of the crank.
Many thanks Mike
