Here is a list of all the postings Rob Frayne has made in our forums. Click on a thread name to jump to the thread.
Thread: Indexable Lathe Cutters advice. |
11/02/2021 18:40:59 |
Matt, The codes I have for the 8mm (WCMT06) is SWUCR0810H06 For the 10mm (WCMT06) is SWGCR1013F06 Rob |
11/02/2021 10:41:06 |
Thank you all for your prompt replies. I have learned a valuable lesson (£109) in the purchase of tools for the lathe. It will be 1 tool at a time from now on. Mind you I am enjoying the learning curve of the Lathe. Thanks again Rob
10/02/2021 20:44:33 |
Hi Just purchased a 9 piece Indexable kit. Unfortunately only being a newbie with my Warco WM180 Lathe ( Last 2 months) I have just been facing and Turning so far. I have not as yet done any boring. So I thought if I bought a kit then at least I would have ALL the right cutters to learn with. So I bought these 10mm cutters. I found that 3 of them were 8mm to tip, so I enquired and was told, I quote. These are used for internal boring so they would have a bigger clearance, the height of them are 10mm so they are 10mm tools. I am a LITTLE bit inexperienced so would like to know if he is right. I have added a picture showing them. They are the top three. Thanks Rob Frayne |
