Here is a list of all the postings stan smythe has made in our forums. Click on a thread name to jump to the thread.
Thread: EMCO Compact 5 |
16/05/2022 10:07:09 |
As far as I am aware it is connected to an external computer so that would be the 5PC version.
Stan |
16/05/2022 00:25:47 |
Its the Emco compact 5 PC. |
15/05/2022 23:20:08 |
Thanks Dave, I think No.9 is PRINT. Hopefully someone may have a manual and can check the numbers for me |
15/05/2022 21:51:25 |
Emgee, Its a friend who has that version but his manual on that section is blurred so just trying to get the exact nos & wordsas outlined in red.. I just have a basic Unimat db 200 thats complicated enough for me Stan |
15/05/2022 19:26:10 |
Can anyone decipher the wording/ numbers in red outline for me, its from an Emco compact 5 CD page 52. |
Thread: Elliot Unimat lathe renovation |
09/09/2020 19:10:46 |
Thats the clean up done and the lathe up and running, everything appears to be ok. I bought some of the Polyurothane belt stuff to make a couple of belts. Question though is the smooth or rough texture belt better?
01/09/2020 15:02:16 |
Coincidently the guy that sorted it for me said if not using the lathe for a while get a small container with lid and 50:50 diesel/old oil. and keep the chuck in that until required. |
01/09/2020 12:54:28 |
I decided to get help before getting too brutal with chuck jaws so went to a local metal fabricator who does wielding, lathe work, milling etc. He took a quick look and had the jaws free in two minutes.
30/08/2020 17:22:01 |
Now sorted the cross feed, many hundreds of taps with a hammer, WD40, oil, wooden wedges, clamps, vice, heat gun....but got there in the end.
28/08/2020 22:39:51 |
Andy, I tried the backplate removal but need to find a better fitting screwdriver as I don't want to strip the head, I have socked them in WD40 overnight to see if that helps. I already have the grub screws out of the cross feed but still locked solid. Thanks for the link will have a look at that. Once I get everything cleaned up I will probably paint the main body parts as there is a lot of bare metal exposed, my tools are kept in a shed and with Scottish winters I normally wipe all my tools with an oily rag for winter storage to keep rust at bay. |
28/08/2020 19:37:08 |
I have managed to dismantle most of it now. Still stuck on the cross feed but hopefully get that freed before too long. The reciprical jaws are stuck at the moment but should manage to free them ok. So far I haven't done any further damage to anything so once cleaned up should go back together ok. |
28/08/2020 09:06:31 |
Thanks Andy, useful info. I got the spindle nut off ok, I will have a look at getting the chuck off later today..
Thor, thanks for the links that is very helpful. |
Thread: Just joined having acquired a mini lathe |
28/08/2020 00:14:15 |
Posted by Andy Carlson on 27/08/2020 23:47:32:
Welcome to the forum. Looks like you have a decent set of accessories there but you need to do some rust removal. Your motor looks non original - nothing wrong with that though provided it works OK and may be more suited to continuous use than the original. The accessories will be secondary to getting the lathe back to working, then I can work out what the rest is for. I agree the motor is not original especially the way it has been wired up. |
27/08/2020 23:00:34 |
David as yet not making anything, just got the lathe so going to be a learning curve.
Steve, thanks and yes will be lots of questions in the coming months I am sure.
27/08/2020 21:08:40 |
old mart....I have dismantled much of it and will work now on freeing the seized parts. I better get some more WD40 as it looks like I will need a load. Edited By stan smythe on 27/08/2020 21:09:16 |
27/08/2020 20:31:42 |
I am an enthusiastic DIYer and just acquired this lathe, it will be a few weeks before I get to use it as it requires a good bit of restoration. I don`t have any `trade qualifications` but enjoy most anything thats mechanical. I live in Scotland and retired.
27/08/2020 20:23:41 |
Thanks Nick unfortunately I cant edit the heading. |
27/08/2020 19:05:38 |
The motor works ok and spins the chuck. The cross slide thread is seized and the chuck I canot open or close. Any help appreciated. |
