Here is a list of all the postings Jerry Bland 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Huanyang VFD help please |
09/11/2020 23:06:00 |
Michael thank you so much I have ended with a similar way before seeing your instructions ,but to get an 'off' needed to bring the 'forward' terminal into play, along with the @common' 'SPH' and 'SPL' terminals so in 'off' there is no feed to either of the speed terminals or forward terminal. in high there is feed to forward and to to SPH . Likewise in low there is again a feed to forward , and then to SPL . So the VFD in either speed gets told to run and what frequency... And it works . What do you think Regards Jerry |
08/11/2020 19:40:33 |
Good Evening, can someone help please ? I have my mill, which has been overhauled , has run happily with its new motor on the VFD, starting and stopping via the VFD control panel. When the mill was built back in the 1960's it had a 2 speed motor operated via a switch with high low and off ... I would like to use this switch to control the VFD , possibly to run the motor at 2 different frequency settings so high is 50Hz and low is 25HZ can anyone help please thank you Edited By Jerry Bland 1 on 08/11/2020 19:53:14 Edited By Jerry Bland 1 on 08/11/2020 20:33:15 |
Thread: Alexander master toolmaker |
25/06/2020 19:33:28 |
I an so grateful for the information and help in this thread. I am currently stripping and overhauling my 'Master Toolmaker,.... Can anyone help, with where to obtain the felt seals in the housing around the long drive gear ? Regards to all
