Member postings for Darren Bingham
Here is a list of all the postings Darren Bingham has made in our forums. Click on a thread name to jump to the thread.
Thread: Mystery Gun Part?
05/08/2023 08:04:00
Hi Martin! Looks lovely whatever it is!
is it for sale?
all the best
Darren
Thread: Reilang oil cans, fit for purpose?
22/07/2023 08:51:53
Posted by Bryan Cedar 1 on 07/06/2021 10:55:55:
Having invested a fair sum for a 300ml Reiland oil can, I have found that it leaks badly form the can to screw in top. The top part which is threaded has two large flats where the thread is absent. The leak occurs from these areas even though there is a flat rubber washer that is supposed to seal the joint. A club member that I spoke to has the exact problem. How do Reilang continue to sell oil cans like this?
I have tried different o rings and rubber washers, and the pump continues to leak.
As the can would have to be laid flat in my tool box it is not fit for purpose and will have to be returned.
Apologies for digging this back up but I hope this will help others too.
after having the same issue, I decided to run off a load of leather washers.
the rubber o ring is completely useless once it gets the tiniest drop of oil near it, it just squeezes out of the side of the can.
I have used an excellent quality, veg tanned leather. The inner diameter is a perfect fit for the 200ml pump.
im interested to know if all reilang oil cans utilise the same pump, with just the can increasing in size. If this is the case, these leather washers will fit all models.
If anybody is interested, I’ll happily post them.
£3 per washer £1 postage.
I hope this helps!!
Darren
Edited By Darren Bingham on 22/07/2023 09:00:22
Thread: Keen beginner
10/06/2020 21:24:05
Posted by Neil Wyatt on 10/06/2020 21:16:37:
Welcome to the forum, Darren,
You need to make a calliope!
Thank you Neil
Yes! Maybe I should!
I probably need to start collecting loco whistles
Thread: Parting off
10/06/2020 20:32:32
Posted by SillyOldDuffer on 10/06/2020 10:13:50:
Hinted at but not explicitly mentioned is parting off is easiest on big heavy machines and decidedly tricky on little ones! It's to do with rigidity. As parting requires more force than most operations and the tool is likely to be fully extended almost any unwanted movement due to the tool or tool-post bending, or the cross-slide twisting against the gibs, or the saddle moving will cause a dig-in. Everything has to be snugged up or locked, which may not be possible if the machine is worn or out-of-adjustment. Plus swarf jambs in the slot, the tool has to at a right angle to the job, lubrication is advised, and it needs a steady not-too-fast or slow feed, ideally under power because humans wobble and dither.
Darren didn't identify his machine, but parting off on a mini-lathe is difficult. My much larger WM-280 is far less fuss. It parts off OK from the ordinary tool-post, but it's happier cutting with a heavy rear tool-post. The rear post is considerably stiffer than the cross-slide and towering front tool post and it grounds the cutting forces directly into the saddle. Basically a rear tool-post removes several opportunities for unwanted movement. I'm sure a well-adjusted lathe in the Boxford, Colchester etc class would make parting off even easier; I wish I had a bigger workshop.
10/06/2020 08:58:17
Thank you so much for everyone that replied.
I had no idea that this was a common issue, it’s restored some confidence.
best wishes to all
Darren
09/06/2020 08:45:03
Thanks Brian,
I am after a Myford ml10, mostly because of a recommendation from a friend.
id like imperial, mainly as I don’t tend to work in imperial a great deal so I’d like to learn.
i don’t have a massive amount of space or money for that matter, but that said, if it’s more expensive I’ll just save until I can get what I want, rather than buying something I won’t be happy with
08/06/2020 18:39:23
Good evening!
thank you for your reply.
I’m still after a lathe for home, preferably an ml10.
the lathe in question on my other post is a Harrison that we have at work.
Ive not used it a great deal, but I’m trying to gain some extra knowledge so I can use it confidently and safely.
I am by no means a stranger to machinery, but I must admit it did make me jump when it jammed up!
made me think that I could do with some extra help!
I should probably add that perfection is generally a great part of my job. I’d like to think that I’d be capable of setting up such machinery, but i thought it best to ask for help from people who really know.
Thread: Parting off
08/06/2020 18:26:14
Thank you all for your quick replies!
I should have really said....
I'm using plenty of lubricant, not cutting too fast and not turning too quickly.
as someone said, I too have set up the tool by bringing it to the face of the chuck. I thought it was as good as I could get it.
I checked the vertical with a set square.
I will check to see if there is clearance ground on the parting tool.
I had it in the holder as far as possible too!
may well be worth making a second cut as mentioned in one of the replies, especially when using such a narrow tool
08/06/2020 17:03:31
Having a bit of trouble with an eclipse parting off tool
it is very sharp, but I had it jam on me in a mild steel bar.
any help would be appreciated.
are the tipped parting tools better?
08/06/2020 14:18:05
Hello to all!
My name is Darren I’m 30 years old and I am a cabinet maker and pipe organ builder.
I am looking for a lathe and a milling attachment. I’m going to try my best to learn how to use them.
I always have a project on the go and I’m sure these skills will help me no end.
I have always loved steam power. I think this is a good excuse to actually get into making something.
Any help and guidance really will be appreciated.
Thank you
Darren
