Here is a list of all the postings Master of none has made in our forums. Click on a thread name to jump to the thread.
Thread: Which stand for Myford ml7 |
30/05/2022 20:06:34 |
I would recommend against the use of boards such as MDF or chipboard used in kitchen worktops. Whilst the material appears initially to be strong enough to support the load without excessive deflection, over a period of time it creeps without further loads being applied. This is often seen where rough shelving is made of chipboard, particularly when the moisture content may be relatively high, as may be the case in a garage or unheated shed used as a workshop. |
Thread: Accessing Digital Archive |
18/05/2022 22:20:18 |
I registered with Pocketmags to see the magazines but I can only see the issues since I registered. I have not been able to see the issue before then which were not posted on the Model Engineer site. |
