Member postings for Sam Johnston
Here is a list of all the postings Sam Johnston has made in our forums. Click on a thread name to jump to the thread.
Thread: Harrison L5 serial number
26/03/2020 15:09:51
Thanks Shaun I'll get the glasses out😁 on another question I've taken the apron off and looked at the carriage gears they all look really good but I cant workout where they get lubricated from?
26/03/2020 14:27:27
Can anyone show me where the serial number is I've read it should be on the ways but I've been cleaning my lathe down and haven't found one yet. Bit of history my lathe looks like it's been exported to Spain as the brass plate and top plate are in spanish.
Thread: Harrison L5 oiler nipples
16/02/2020 20:54:00
Posted by David George 1 on 16/02/2020 19:28:39:
It depends on what shape the other oil nipples are and what shape your oil gun is. If you get grease nipples which have a spring loaded end you can remove the spring and ball if that helps. You can try these no connection or maybe you have a local supplier.
Harrison Lubrication Engineering Ltd
Lynstock Way. Lostock. Bolton. Lancashire. BL6 4SA
Working Days: Monday - Friday
Working Hours: 8:30 - 17:00
Phone: 01204 691352
Email: [email protected]
Website www.hle.co.uk
David
Thanks David I'll give them a ring tomorrow.
16/02/2020 18:21:41
Posted by David George 1 on 16/02/2020 13:16:47:
Hi Sam have you measured one of the old ones or the hole that they fit into. More information may help.
David
Big problem I have is most are missing and I cant be sure the ones left are original. The three I have left are 6.3mm or 250 thou so probably 1/4" so if I got 1/4 grease nipple would those do the sam job?
Sam.
15/02/2020 14:37:42
I sure this has been ask but a search is not finding it, but can anyone tell me what thread size the oiler nipples are on a Harrison L5 lathe? Looking through ebay I can only find 2 ba or 6mm x 10mm.
Thread: First post.
10/02/2020 14:56:19
Oh and sorry I'm just outside Belfast.
10/02/2020 14:54:47
Posted by Brian H on 10/02/2020 13:04:02:
Hello Sam and welcome.
It may help to indicate approximately where you are located in case you need someone to help you.
Do you have any projects in mind?
Hi Brian my first prodject will be stripping the apron and tailstock down and giving them a good clean as the lathe has been sitting for years unprotected it doesn't seem to be pitted rust just surface rust and heavy dust.
10/02/2020 12:27:49
Hi I've just taken a step back into engineering, I bought a Harrison L5 lathe and I'm sure I will need some help from the hive mind of a forum. I haven't got my hands on lathes or mills since the early 80s so I'll be taking things easy for a while and hopefully find my feet again.
