Here is a list of all the postings Gazz has made in our forums. Click on a thread name to jump to the thread.
Thread: De-snagging an SL125 |
01/07/2021 21:37:07 |
about 15 years ago i had a cruiser style bike (yamaha virago 535) and i pulled the stock baffles out as i wanted it to sound more like a harley than a sewing machine. Needless to say it was a little too loud, and being a short stroke much higher reving engine than a harley... it sounded nice at idle, but droned awfully when riding at speed, and would set car alarms off in towns. So i did what was a common thing back then, mounted a bolt with a washer welded on the head in the end of the pipe, here's a photo i grabbed off google that shows similar to what i did: It took a little playing about with the size of the washer, the hole size in it, and also the angle you locked the bolt off at... thus angling the washer adjusted the sound, |
Thread: Warco GH 18, bench top gear head mill fetteling |
20/05/2021 22:05:44 |
Kerikey, i've gone way off topic again, back to trying to make the stop button work no matter what mode the mill is in etc.... . Next i tried a stack of contact blocks on the stop button, first a N/C type then below it a N/O type, Then as the button goes further down it presses on the N/O contact block, which sends a stop signal as normal, this worked but only if you didn't press the button too fast, once the quill was down a little and off the upper limit microswitch, she speed the stop button was pressed at didn't matter, as the VFD always 'saw' the stop pulse, But if i had to remember to press the stop button slowly when the quill is up in tapping mode against the upper stop, i may as well just press the E-stop button instead. And that's where i got the next idea from.... Use the stop button to trigger the E-stop signal when in tapping mode. To do this i added another contact block to the stop switch, and wired it so that only when in tapping mode it sends the signal via this contact block to the E-stop command as well as the normal stop command. So it's basically like pressing the E-stop mushroom on the button box when in tapping mode, but using the normal stop button still, when the quill is returned to the top of stroke and the upper limit microswitch operates, it sends the normal stop signal and stops the spindle motor. I found i had to use a diode on the 'tapping buttons common' wire to get it all to work, but i am now happy that i can use the standard stop button and at all times it will do as it's supposed to. So if anyones interested, the diagram is below: You need to add another contact block to the stop button, this will need to clip onto the bottom of one of the existing contact blocks (which they are designed to do) as the stop button on the stock wired mill also has a VFD fault reset contact block on it (connected to X3 on the VFD) and an led to light up when the VFD is in fault lockout mode. A diode is needed to be inserted between the tapping microswitch common wires and the connection to the tap/mill switch as shown.
At last, that's over, i'm sorry it took me so long to explain this, if you haven't guessed yet... yes i am on the bi-polar spectrum, so my mind wanders all over the place as i try to recall things, and also why i have so many hobbies that i flit between. To totally finish this bit off, my new button box wiring diagram, i did away with the led and contact block in the stop button that is for resetting the VFD fault condition, instead this is handled by a separate button and led on the front of the electrical enclosure. As can be seen i now have 8 controls in this button box, all operate on low voltage DC which is just a personal preference. and the main new control is the bottom right which is the remote variable speed potentiometer, that allows me to use the mill taking advantage of the VFD fitted to it. That's it for now, Next will be the DRO instal, which is a 4 axis lcd type with RPM readout built in. Edited By Gazz on 20/05/2021 22:24:43 |
20/05/2021 21:55:34 |
So as you can probably tell, i really didn't like this stop button operation in tapping mode, it probably doesn't bother most people, and i imagine it works properly on the single phase versions of this mill? But i wanted a button marked stop to .. .well stop things, i didn't have enough room on the button labels to put 'STOP..except when you are in tapping mode and the quill is at the top of it's stroke' I wanted to 'fix' this, and did so when i wired up my new button box, but it can be done to the stock button box if you wanted of course, so just incase someone else wants to do the same, i'll go over what i did.... i bet there are users of this mill with the VFD that didn't even know this 'problem' existed and hate me for pointing it out, i know some people never want to use the tapping function, and i heard of one person who removed all that stuff and fitted a digital caliper style quill depth readout in it's place in the mill head. I tried a few ways to fix it, handily the industrial style buttons used are modular, so you can add extra contact blocks just by clipping them on the back of the button's clamping block, and you can even stack them up. . First thing i tried was rearranging the inputs to the VFD to free one of them up and setting it to a second stop command..... But that didn't work, seems the VFD can't 'see' a button pulse if the same command is continuously on from another switch, even tho the pulse is sent to a different input terminal... bugger. So i changed the wiring and VFD settings back to try something else, but i now know that if i needed a spare input / output terminal on the VFD, i can use the 2 diode method again to allow a single 'forwards' input to work with both milling and tapping modes. Below are wiring diagrams for the stock button box, showing just the control wires (things like the VFD reset button and led's wires are not shown etc... they are all shown on my wiring diagram of this mill )
And next is the diode version i came up with, this allows you to free up an input on the VFD if you ever need it for something else (maybe to require the reset button to be pressed to re-start the mill when the E-stop has been pressed or something)
Edited By Gazz on 20/05/2021 22:22:38 |
20/05/2021 19:16:40 |
Here is a photo of the mill set up ready to use: Hopefully it shows that the button box's new location, and that it is mounted at an angle making it easy to operate, especially as i use the mill sitting down 99% of the time, you'll also notice the DRO is fully installed here, i will describe that in the next 'chapter'
But now for a sort of mini rant using thousands of words where a single paragraph could likely have said it better, it's something that probably wouldn't bother most people, but it did me so i changed things to 'fix it'
To use the automatic tapping function on this mill, first you set the depth stop up by turning the knurled adjuster under the front of the mill head, What makes this automatic tapping function work is that when that depth stop is reached, a microswitch is operated, and when in tapping mode this signals the VFD to reverse the spindle direction, so the tap winds it's self out of the hole at that point, and when the quill is returned to the top of it's stroke another microswitch is operated which signals the VFD to stop the spindle... you can then position for the next hole and press forwards and repeat the process. simple and clever.
So... the first time i tried the tapping function out.... this was before i'd made any mods at all, the mill was 100% as it came from the factory. I've set the depth stop up, im in gear L-1, which is 95 rpm / ~ 1 and a half rotations per second i think, I press the stop button, nothing happens, i press it again and again, it wont stop the spindle, i'm worrying now... ok nothing bad was happening but damn it i expect the spindle to stop when i press the stop button, i eventually remembered there's an emergency stop button and used that to stop the spindle. I thought there was a wiring fault, or a bad connection / contact in the stop switch or something, but when i tested the buttons with a multimeter all seemed correct, only when i traced the wiring that i figured out what was happening. The VFD is set up to respond to pulsed signals from the momentary buttons, all the mill / tap switch does is change how the signals to the VFD are routed through the buttons and microswitches themselves, i.e. in milling mode the depth stop microswitches are switched out of circuit so do nothing. But when the quill is at the top of it's stroke in tapping mode, i.e. before you have moved the tap down into the hole and started cutting threads, the depth stop rod is holding the upper limit microswitch in, this means that the VFD can't 'see' any pulses from the stop button, the spindle is already stopped when you switch to tapping mode, and it can 'see' the forwards start button pulse as that's a different pulsed signal on a different input terminal. So to stop the spindle once it's been started in tapping mode you need to move the quill down enough so it releases the upper limit microswitch, only then does the stop button on the button box work, so there's no problems using the stop button if you were halfway through tapping and noticed something going wrong, and of course as long as the distance from the tap to the hole is more than the distance to release the upper microswitch, you can simply pull down and release the quill and it will operate the upper limit switch again and send the stop pulse.
Also note... when you are testing the depth stop distance whilst setting it up without pressing the forwards button in tapping mode, when you trigger the lower limit microswitch the reverse signal will be sent to the VFD, so the spindle will start up in reverse, it'll stop if you press the stop button or return the quill to the top of the stroke,
19/05/2021 23:16:58 |
So the wall mounted electrical cabinet houses all the control gear, 2 cables come out the top of it, loop upwards and come back down and attach to the mill, they are the motor power wires in the black conduit, and the 6 core cable for the tapping limit microswitches and the ring light, I made up some 3D printed clamps to hold the grey cable to the conduit, and rotated the motor's terminal box cover 90 degrees so the cable inlet is at the top instead of the rear side, On the bottom side of the electrical enclosure are a few cable glands and a C-13 female connector, that is for the DRO's power supply, The new control box is mounted at an angle below the mill's chip tray on the left hand side, it's fixed to the workbench front instead of the tray so that the mill can be moved if needed and the control box stays put.. as it's cable goes to the wall mounted box and not the mill. The controls are as follows: Top Row, from the left: An illuminated latching green push button for turning the VFD on and off, so it's a main power switch for the mill. Next is the 3 way rotary switch that selects milling or tapping functions on the mill, this is from the original control panel, so centre is off, and triggers the E-stop command of the VFD. A red mushroom latching emergency stop button, this signals the VFD's E-stop function as well as interrupting power to the 24 volt PSU's relay / contactor, this is so that operating this button will stop the spindle and the Z or X axis feed motor if it is running, so as not to drive the workpiece into a now stationary cutter... it will be linked to another similar button on the feed motor control panel when i make it. Final button on the top row, an illuminated white latching push button, turns the ring light on and off. Lower Row, from the left: A speed knob, this turns a 10K potentiometer, which adjusts the speed of the spindle by varying the frequency and voltage the VFD puts out to the motor, the best part of a VFD run motor that was not taken advantage of on the mill when it was stock! Next is a flush green momentary push button that sets the spindle rotation backwards / anti clockwise. Then a raised red momentary push button which stops the spindle, by raised... i mean this button sticks out and makes it easier to hit than the go buttons. And finally another flush green momentary push button that sets the spindle running forwards / clockwise. When the mill is put in 'Mill' mode, the forward and reverse buttons work and you can press either at any time, if the spindle is running and you press the opposite button, it will quickly stop and go the other way, due to the motor being 3 phase this happens almost instantly. If the Mill / Tap button is moved whilst the spindle is running it will stop due to an E-stop signal being sent in the off / centre position. When the mill is put in 'Tap' mode, the reverse button does nothing, pressing the forwards button starts the spindle running clockwise, and you would have (hopefully) set the depth stop up before starting the tapping mode.
18/05/2021 23:03:16 |
Here is the new main electrical box mounted on the wall, next to the mill: The 4 oblong items are indicator lights, from top to bottom they are: The round white light is the main power button, this turns on or off power to everything in the box and the outlet to the DRO.. that's what the keypad is in the bottom left of the shot. And the keypad with the red led display is for the VFD, it's showing the motor speed is set to 43.3 Hz, i.e. slightly slower than normal 'max' speed of 50 Hz, and the 2 red led's above the digits show that it's in forwards and stop modes.
Below is what's hiding behind enclosures door... watch for rats jumping out the nest of wires in there.... On the door back you can see the panel indicators and main switch (i have since made a 3D printed cover that protects me from the 240 volt terminals on that... this whole enclosure is powered from a standard 13 amp plug, so i 'should' pull that before opening the door) Top left, that long silver thing is the 24 volt 15 amp psu that will eventually run the Z and X axis motors. Top right is the VFD that runs the mills motor, that depression with that grey ribbon cable coming out of it is where the VFD programming / display keypad clips into, i've moved that to the front panel of the main enclosure as shown in the 1st pic. There is a cover missing in this pic that screws over the terminals with wires at the base of the VFD, those terminals on the green strip at the front are all low voltage (5 volts) The standard VFD case is not dust proof at all, any metal grinding dust in the air could easily get in and short things out.... there is a small fan mounted on the rear of the VFD's heatsink.. which could help suck in any of that grinding dust... the good news is that fan only runs when the VFD is running the motor, so you wont usually hear it over the mills main motor. Back to the electrical enclosure description..... Bottom left, the square dull grey with holes in it is the 12 volt 3 amp psu, this runs the control circuits so that only 12 or 5 volts DC is on any of the wires to the button box, To accomplish this the VFD and 24 volt PSU are switched with contactors, i used normal 240 volt coil contactors as 12 volt DC ones were rather expensive, and to switch them from the button box with low voltage, the 2 din mount relays to the right of the 12 volt PSU switch the contactors themselves. There's 3 MCB's in there too, a 2 amp type B MCB is for the 12 volt "control" PSU and main switch, There is also a 10 amp fast blow fuse in the black holder to the left of the VFD MCB, some people say that's not needed as the MCB is there, but some VFD manufacturers say you must still use a fast blow fuse to get the fast disconnect time to try and protect the VFD in a fault condition.. thos it's probably more for the users protection than the VFD's... as we know, mosfets usually blow faster than a fuse can. The black items on the top and bottom of the main box are vents, the top one has a filter in it only... more to stop any dust getting in from above, and the bottom one has the 120mm fan as well as an inlet filter, the fan is a thermostatically controlled one, it's thermistor is taped above the EMI filter with that yellow kapton tape.
Finally, you may just be able to see a 'barrier strip' block on the left side wall, there's nother on the right, and i just use them where i may need to disconnect wires in the future, i.e. the 6 wires from the tapping function switches and ring light go through the right hand one. |
18/05/2021 20:46:57 |
Part 7 "I don't like the stock controls" This one is maybe going too far for most owners of this mill, but just in-case someone else dosent like how the stock control box rises with the mill head, here's how i changed that... and typical of me, i couldn't just mount the yellow control box on the mills column where it dosent move, i had to go for a whole new electrical control system including rehousing the VFD. I have issues with my joints (and i don't mean the type you roll) and can find it painful to be reaching above me too much, on most mills of this type the buttons to operate the motor are on a box mounted (i'll call it the 'button box' from now on) to a swing out arm, which in turn is attached to the head of the mill, thus as you move the head upwards, the button box goes with it. This mill has ~400mm of vertical travel, so that means that about half of that travel puts the head above my eye line, and i found it very awkward to be operating the switches/buttons then. I also only stand at the mill if i'm doing a really quick operation, i have a tall bar stool type seat i sit at most of the time. also i wanted to add an extra 2 controls, a speed control for the VFD and an extra button for the ring light. This is the mill with the stock button box on the head, it's wound nearly to full height (it's at the top of the column, but there's another 30 or so mm it can travel before it hits the physical stop) I also didn't like the wire routing, mains comes in to the yellow button box, goes through the fuse, main switch then back out to the VFD, the control wires come from the VFD to the button box... but also the 3 phase power to the motor comes into the button box, then immediately goes back out and to the motor, and then a wire comes from the depth stop / tapping function switches and spindle shield stop switch (which was removed the day i got the mill) to the button box. Reaching for the Z column locks meant having to move the tangle of wire conduits out of the way, i also wanted to have a better housing for the VFD to live in, one with ventilation out the top and not just the bottom, and i plan to motorize the Z and X axis at some point, i wanted room to house the 24 volt psu for that, as well as add a few other control items.
I decided to have a large-ish electrical cabinet mounted on the wall, that will house the VFD, motor psu, a small control psu so all controls operate at low voltage, some circuit breakers, contactors, warning / operation lights plus a mains filter, as i found i was getting a lot of interference from the VFD within about a 3 foot radius of the mill when it was in operation, and this played hell with the DRO's spindle speed function... saying it was turning at 300 thousand rpm's when it was really doing only 90, To do this i basically stripped all the wiring out of the mill, i'd already worked out the stock wiring for it, This Thread shows the circuit diagrams i drew up that covers the stock wiring and operation of this mill.
I purchased a 300 x 400 x 200mm metal electrical wall mount box from ebay for £29 Ebay Link if i was not housing the 24 volt 15 amp psu in there too, a smaller box would have easily housed just the VFD and control items like the contactors and breakers. I'd also bought an english text VFD programming keypad with display and extension cable, as the one that came with the VFD was in chinese, and i wanted to have the keypad on the front of the electrical box so i can see the display showing the frequency i have the spindle running at, and any error codes and so on. For the new button box, i got a plastic enclosure 200 x 120 x 75mm in size, this would allow 8 standard 22mm industrial style buttons to be mounted easily, i plan to get another later on to house the Z and X axis motor controls, and the plan is to mount these button boxes on the front of the workbench just below the mill's chip tray, so they will always be in the same place, and i can build up muscle memory and be able to operate them without flailing about trying to find where the button box is since i moved the head. The VFD will be switched via a contactor, another contactor for the 24 volt psu for the axis feed motors, a 12 volt psu will be used for those controls so any buttons you touch when normally using the mill are low voltage.
I've hit the character limit again, so will continue in the next post..... Edited By Gazz on 18/05/2021 21:23:33 |
18/05/2021 16:11:24 |
Part 6 "Y axis accordion way cover/ bellows" The Y axis has a neoprene sheet type cover for the rear of the ways on this mill, pretty standard on these Chinese mills it seems, but i didn't like it and wanted one of the pleated accordion type way covers like the Z axis has. I could have bought one from china on alliexpress etc, or even had one custom made by a camera bellows maker, but i was ordering some things from arc euro trade and saw they did them, i measured up and of course i'd need the most expensive on they sold, it always seems to be like that. So i bought This One costing £39 The actual item is a little different from that picture, but it's just an extra chromed strip and angles on the end with the taller fixing piece. It measures 240mm wide, which is handily a little wider than the width of the bottom part of the dovetail castings on the Y axis, so it will fully cover the oiled sliding parts of this axis, and I knew i'd need to cut the pvc formers to make it fit, but the actual black parts of the bellows are just right for the Y axis of this mill. I cut the pvc formers straight up and across at the edges of the black part of the bellows, i could have tried cutting the angles so they'd go over the dovetail of the Y axis, but i figured as the pvc formers would be off the end of the dovetails when compressed, they might get snagged and not slide over them when moving the Y axis forwards and rip the bellows apart. I also reduced the overall length of the bellows, as when compressed they restricted the Y axis moving right back, i found if i cut the bellows at the 1st PVC part, i'd have enough length when fully extended to cover the ways and not be too tight, and the metal cover reinforces the end of the bellows nicely. Above you can hopefully see where i reduced the overall length, i could have cut them even shorter, but it was best to cut them where the chromed metal strip is, as that's where the PVC former part is in them, and that gives a strong point to fix that end to the table. For the moving table end i used the holes that were already there for the flat cover.. i used a marker pen to 'blue up' the area around the holes, and pressed the bellows against them and it transferred the holes positions nicely. At the column end (right in the pic above) you can see that i used a piece of aluminium to make up the difference from the foot of the column and the actual column, i used a piece of the aluminium extrusion i had left over from the DRO instal as the packer, the joint where the column meets it's mounting foot is not cast perfectly flush, so you'd need to mill a relief in the packer piece there. Yes, i know, i drilled the holes off centre, i had to use a right angle drill adaptor to get in there to drill the holes in the column and didn't realise i had the left hand one lower than the right until i had finished tapping it, i can't see these fixing screws when using the mill, and i totally forgot about them untill i took this photo. This is the cover from the top fully extended: And here is the cover fully compressed: I mentioned in part 5 that the splash guard for the X axis DRO scale might need to be cut in half to give me full Y axis travel towards the column, it turns out i don't need to do that after all, as it was the flat neoprene Y axis cover bunching up against the DRO scale cover that was causing the restriction. You can see the black pen mark on the base of the mill that i put on when measuring up for the DRO scales, that is the true end of the Y axis travel, so i am short of maybe 2 or 3MM's now due to the bellows, the vice now goes even further back under the X axis bellow, and i can live with out that last couple of mm's of travel i think.
To Be Continued....
Edited By Gazz on 18/05/2021 16:14:25 |
Thread: Chinese Depth micrometer rods |
01/05/2021 14:42:28 |
I now have the broken micrometer someone on another forum sent me, and i have my measurments wrong for sure.
This is the rod lengths that i have:
125-150mm = 170mm 100-125mm = 145mm 75-100mm = 120mm 50-75mm = 95mm 25-50mm = 70mm
So thats makes the 0-25mm rod 45mm long?
30/04/2021 17:05:33 |
Continued from the post above...
So i fit the new vice minus the swivel base to my milling table, and notice that if i wind the Y axis back the top of the vice jaw hits the accordion style dovetail slide protector for the Z axis. I've been robbed of at least 10mm of travel The fix is simple tho, when i removed the 2 Allen bolts that hold the angle bracket for the bottom of the accordion way cover, i found a dovetail bent-to-shape piece of flat steel is bolted to the column, which means the base of the cover extends downwards by way more than is needed to keep the ways covered. So i removed that piece of bent steel and raised the base of the way cover up, the bolt holes are in the middle of the L bracket that secures the base of the cover, and if bolted to the holes that held that piece of bent steel on, the vice top still hits. There is a downside of course, every action and all that like Newton said. You lose a little bit of Z travel at the bottom as the accordion way cover can only close up so much (maybe removing a couple of the pleats may help this), This mill has what i think is a fairly generous Z height on it's column... so much that i had to raise the roof above the mill to accommodate it, so it's usually the other way that people won't give up travel in, i.e. upper Z travel not lower. I have found i usually have an R8 ER32 collet chuck in my spindle, and even with the slightly reduced bottom Z travel i can make the nose of it hit the table. So i decided i'd rather have the extra Y travel, after all it's only 190mm to start with, compared to over 400mm for Z (don't believe Warco's measurements, i ordered a 450mm long scale for the DRO to accommodate the real Z travel, not the 350mm they state) And if i ever do need that little extra to lower the head with say a direct R8 collet mounted bit, it's just 2 Allen bolts to pop out and let the way cover move down, i may make up some thumb wheel bolts to allow me to do this without even getting the Allen keys out. Since this photo was take i have fitted a DRO to this mill, i fitted the X axis scale to the rear of the table, and guess what... with the cover over the scale it robs me of just as much Y travel that i had gained from the Z axis way cover mod.
But i can sort that out, the cover for the scale is over double the width of the actual scale, so i plan to cut the top of the cover along it's length to make so it doesn't stick out too far past the actual scale, and gain my Y travel back. Also you can see how the Y axis way cover bunches up, it's just a flat piece of neoprene. I'll show that mod shortly, then the control panel mods and DRO instal etc. To Be Continued..... Edited By Gazz on 30/04/2021 17:19:11 |
30/04/2021 17:04:39 |
Part 5 "I want that last 10mm of Y axis travel" I bought a 100mm vice to use on my mill, just a cheapie of course but not just any cheap vice.. it's a "Versatile-Milling-Vice-with-swivel-base-and-a-self-aligning-spherical-segment " Yeah, i got sucked in with the sales patter on this one, it's a bog standard cheapie chinese swivel vice with a ball bearing in the moving jaw to lead screw connection, complete with a slightly mis-milled hold down slot and painted with a 6 inch brush by a blind man it seems: But apart from that it seems a good vice and i paid a fair price for it, don't get me wrong, I've spent just over £500 with Arc Euro Trade for bits for this mill and will continue to shop there.
Like most people i guess, the first thing i did was take the swivel part off likely never to be fitted again, But rather than chuck the swivel base under the bench and forget it even exists, i made a 3D printed wall holder for it, just to remind me i have the swivelling part to use if i ever need to, 3D Printable 100mm Swivel Vice Base Wall Mount This was one of the harder to design 3D parts, it's not just hollow inside, it follows the bases curves and angles, and has a tee slot protrusion to keep it fairly straight (i always like to get plenty of wiggle room in 3D printed parts, it's not exactly printable at micron accuracy what with shrinkage and layer lines and all that.
Continued in next post due to character limit for whole post....
Edited By Gazz on 30/04/2021 17:08:37 Edited By Gazz on 30/04/2021 17:10:54 Edited By Gazz on 30/04/2021 17:12:29 Edited By Gazz on 30/04/2021 17:14:14 |
30/04/2021 15:10:11 |
Part 4, "Let There Be Light"..... One of the first things i needed for the new mill was a decent light shining on the work table, about 6 months ago i made myself a little PCB drill press using a dremel clone mounted in a universal mini drill press frame, and one of those cheap tiny (that look bigger in the sellers photo's) X-Y tables to allow me to drill rows of holes in the pcb's in a nice straight line... i use the Y part of the table to set the line i want to drill along, and slide the pcb along it on the X axis.
So i knew i was going to do the same to my 'big' mill before i even ordered it, i chose a 100mm LED 'angel eye' sold to car owners to 'replicate' that BMW ring of light around the headlights look, The 100mm angel eye has an 88mm hole in it, and the GH 18's quill is 85mm at the part that is widest, i just needed something to hold the angel eye to that cast iron ring that clamps around the quill and the depth stop rod fixes to. So i designed a simple plastic holder that the angel eye will clip into and be secured to that cast iron quill ring, the hardest part was getting the 3 pockets the clips go into in the right places plus a slot for the wire to exit, this is where i learnt to 3D print 0.2mm slices of an item that i want to check for dimensions on the real part it's to fit.
About 30 minutes of 3D printing time and i had my ring light mount: 2 holes tapped M3 secure it to the quill's ring piece And my final version of the vertical screw hole adaptor has just 2 holes in it... i always seem to do this, print out something that works but could be better, then i make the mods to the design to make it better and publish that version, but keep the earlier version in use.
Here is what the ring light looks fitted on the milling machine:
The .STL files for this ring light holder are available here: **LINK** There are the 2 versions of the angel eye holder, and also 2 little holders for the 'jelly bean' buck converter that is in the wires to the light, this is because these are designed to go on a car, so a little regulator ensures that the right voltage is always fed to the led's as in a car the voltage could be anywhere from 9 to 18 volts (modern cars with 'smart' alternators can charge the12 volt battery at 18 volts when it's is low from say a winter start!) I just used a 12 volt plug in power supply to run this right light until i did the major control panel modifications, the 100mm angel eye pulls 300 mA at 12 volts. It gives a lovely crisp white light .. when buying an engel eye, pay attention to the led colour, some sellers have those garish blue tinted ones, apparently some car owners like that look! i prefer white to be white, not yellow or blue. In the photo's it looks like it might be a glare into your eyes when using it, but really 90% of the light is fired downwards onto the table, and i really don't notice any glare from it.
I've made a few 3D printable tooling wall mounts others may be interested in... i'm on a budget so most of my stuff is the cheapest version you can buy. I've made holders for R8 collets (based on an interlocking design for ER32 collet holders i found) MT2 collets. MT2 and 3 dead centers, MT2 live centre, center drills, Holders for an an economy parallel set, adjustable parallels, wiggler/edge finder, deburring tool, Soba 75mm boring head and 20mm boring bars, various R8 shanked tools like the drill chuck, fly cutter, those £25 indexable face mills from banggood, a slitting saw arbour (1 inch bore plus blade storage) the index plates and accessories for a HV6 rotary table and so on.
To be continued...... Edited By Gazz on 30/04/2021 15:26:54 Edited By Gazz on 30/04/2021 15:31:22 Edited By Gazz on 30/04/2021 15:32:12 |
30/04/2021 11:58:55 |
i wish i knew the specs of the actual motor fitted, but emailing warco results in no replies, I'd like to know what the motor's specs are so if i ever need to replace it i have at least a ballpark idea what to look for. |
29/04/2021 13:52:50 |
The tapping function on this mill is silly simple, it's just a micro switch that when hit by the depth stop on the quill signals the VFD to go into reverse... you hopefully having remembered to set that depth stop to somewhere before the end of the blind hole you're tapping
For the single phase motor version, how it operates from what i worked out from the wiring diagram in the manual is... The bottom depth stop microswitch releases the forwards motor contactor and starts a timer, when the timer runs down it triggers the reverse motor contactor, the top depth stop microswitch releases the reverse contactor and you can restart the motor in forwards to tap another hole.
Back to the VFD version: The common wire to these depth stop microswitches is only 'live' when the mill/tap switch is turned to tap, when the mill/tap switch is set to 'tap' the reverse button is disconnected, so can't be inadvertently pressed.. nor can you 'automatically' tap a reverse thread, only the forwards button works.. that is to be expected... But the thing that worried me when i first tried it, whilst the quill is at the top of it's stroke the depth stop rod is holding the stop microswitch in.. these switch signals are just pulses, but it's blocking another stop pulse from being seen by the VFD, hence the stop button does nothing until the quill is moved down enough to release the top microswitch. The e-stop button does work at all times thankfully. i did this as i'll rarely use the tapping function, and would panic if i start the spindle, change my mind and can't stop it by pressing the normal stop button, having forgotten about having to lower the quill a bit to get the stop button working.
28/04/2021 13:50:20 |
i did try to do that with a drill, but i'd have needed to make up an adaptor, as the handle on my mill turns a ~20mm D shaped shaft.
I know some mills with this set up... i.e. handle on the lower side of the column) have a power Z axis, and in-place of the nyloc nut at the top of the lead screw is a motor coupler (then a gearbox and a motor) i'm not sure how that motor coupler is fixed on to the lead screw on those systems, it may just be screwed on and locked with a grub screw? Or it may be an extended shaft above the nyloc nut that secures the top of the lead screw in it's top bearing that the motor coupler fits onto... unfortunately getting up there each time to have a look and take measurements etc means standing on a ladder and leaning over, But i gotta do that sometime anyway, as before i get to the motorized axis project, i need to finish off the DRO instal, and that's to fit the spindle speed sensor so it shows the speed on the DRO screen, need to fit some magnets on the top of the spindle drive area, then the sensor that picks them up as they whiz round... i keep thinking it may be better to fit that sensor inside the gear head, but not sure how oil resistant the sensor is if i do that (will only be splashes, wont be immersed in the oil)
Where i really find the handle twirling difficult now is when i've been using the mill then go to use my mini lathe, the carriage hand wheel on the mini lathe is only slightly larger than the quill fine feed wheel on the mill, and the cross slide one is even smaller,
27/04/2021 19:10:00 |
About half that cost difference is for the power cross feed, not all for the VFD
Doh!! i never spotted that, i thought you needed to be at the WM 280 level to get power cross feed, i was originally going to get a lathe to replace my mini lathe, and wanted power cross feed so was looking at the 280, but it was a bit out of my price range but i was hoping to save up, So if i'd noticed the 250V had the power cross feed i wanted i'd have likely had that lathe now instead of the mill. |
27/04/2021 16:12:12 |
Re: the pallet thing, The wooden crate the mill was in was constructed with 3 longitudinal strips of wood on the base, which i thought was to allow a pallet trucks tines to go under, I was told the crate was sent to the main depot of Palletways, where it spent the weekend and then shipped out to me, so not sure if the pallet was from warco, or added at the shipping depot. Someone posted a photo of their WM 18 mill being delivered, and it's sat on a pallet that is the exact width of the machines crate, if my mill had the same it'd have gone through my workshop door. That was a little annoying, but not the end of the world, an hour or 2 with a jack, a prybar and the wheels sorted that out, the crate was wrapped in black plastic, so if it rained it should have been ok stuck outside for a bit.
27/04/2021 15:54:53 |
Warning.. the following show contains excessive use of the word "VFD"
Apparently the last batch of GH 18 mills (delivered up until about Feb 2021) came with the VFD 3 phase motor drive system, i've heard from at least 2 others who were as surprised as me to find this out... and i imagine there are other owners out there who have no idea and think it's single phase fixed speed and the motor just makes a strange whine compared to others.
Or mount the VFD box on the wall and leave the front cover off temporarily and use the knob on the setting panel to adjust the speed like i did for a few weeks.
Warco are out of stock of this machine right now, and they've upped the price by 50 quid, so not sure if that's because the VFD system is standard now, or just a price rise due to covid etc, so anyone thinking of ordering one of these because of the VFD... try and get info out of warco to confirm the next batch of these mills will be the same, or back to the old setup, The lathes that are available from warco with either the DC motor or 3 phase VFD system command quite a premium for the VFD version. i.e the WM 250 lathe, the VFD version is £370 more than the DC motor version.
The 'manual' that comes with the mill has no mention of the VFD, shows a wiring diagram for the single phase forward and reverse contactors, plus the timer needed to ensure the motor has stopped before trying to reverse it (otherwise a single phase motor will just keep going the same direction) And the sales page shows a photo of the mill with a single phase motor (large connector box on the side of the motor housing the start capacitor)
That's why i traced the wires on my mill and made a Colour Wiring Diagram, as all the info i've gathered so far point to no one at warco knowing much about the VFD drive's (purely my assumption, and i could be wrong)
I know of someone who had a WM 290 lathe, from new it had a problem where it seems the VFD is set up wrong, takes ages to get upto speed and cuts out and back in at certain speed ranges etc, ERM... it's a VFD, there are parameters to set all this up and it's obvious one of these parameters has been entered wrong, but if the service engineer doesn't know how to adjust them, what hope do us users of the machines have of getting the info on these systems. The 'cure' for that WM 290 lathe is to replace the whole lathe and hope the next one has it's VFD set up correctly.
I have now learnt not to place too much trust in the machines listed dimensions, fitting a DRO to it i was glad i didn't blindly order the scales based on the sizes listed on warco's site. I have not been totally put off buying from warco, i recently bought a rotary table from them because they had it for the best price, i got it in the 10% off sale over the past weekend... noting that i saved £15, but with the £16 i lost on the hold down clamp thing i'm still worse off lol
27/04/2021 03:08:37 |
Finally after having the mill almost 3 weeks i got to do more than just stick the few tools i had up it's snout and spin them up for a short while then take them back out and twiddle the hand wheels, but during that time i was reminded that my arthritic joints are not getting any better. The Z column is raised with a crank on the left hand side of the mill, it's about 100mm above the table.. so better than the mills with the crank/wheel positioned right at the top of the column, and it's fairly low geared so not too much effort needed to raise or lower the head, but it means spinning that crank handle a hell of a lot, and my left arm is my weakest one. I can raise or lower the head about 50mm then need to take a break, so a modification i must do will be to fit a motor in place of the crank. I fitted an emergency stop system to the workshop when i built it, a 50 amp contactor shuts off power to a consumer unit that runs all the sockets in the workshop when any one of 10 e-stop buttons are pressed, so at least i don't need to rely on the out of reach e-stop button on the mill if it decides to try and kill me one day. I also didn't like that the yellow box that the controls are mounted on is so big, with the single phase motor it would have housed 2 contactors and a timer for the auto reverse tapping function, but with the 3 phase motor all that is done with the VFD, so the box is pretty much empty, i plan to fit a DRO to this mill and the display would sit right where it'd get hit by the stock control box.
So my first real modification was to make a new control system, a new switch box will be mounted just below the chip tray on the left hand edge, it will have 2 more controls that the current button box doesn't have, a speed control potentiometer and a button for a ring light around the spindle. This is a drawing of the new control panel: The new control panel will be low voltage, and later on a second one will be mounted on the other side of the mill area with the controls for the axis motors when i add them. All mains stuff will be housed in a 300x400mm wall mounted electrical box, controls circuits will be 12 and 5 volts and contactors will switch the VFD and 24v 15A psu for the planned axis motors, mcb's will be in there to protect the individual circuits, plus an EMI filter and chokes on the input wiring, as the VFD does make a fair bit of electrical noise that the hall effect speed sensor on the DRO doesn't like... makes it think the spindles doing 300,000 rpm! the VFD programing/info panel will mount in the door of the electrics box as well as tell tale lights to show the psu status, plus the fault indicator and reset button for the VFD, a 120mm fan and vent will keep the enclosure cool, both will have a filter to keep out dust.
To be continued..... |
27/04/2021 03:01:13 |
So with that little drama over it was time to lift the mill onto the bench, this wasn't going to be as easy as moving my mini lathe, i have a condition where my immune system attacks things it shouldn't like my joints, so i've basically had arthritic type symptoms since i was 14, and it being middle of winter wasn't helping with that, so i was useless and my only help was my 71 year old father. I looked into hiring one of these manual pallet stackers (a sort of mini forklift with the forks lifted by a hand cranked winch) thinking that would be the safest way to lift it, push it forwards and deposit it onto the workbench... hopefully gently and the right way up, but local hire places only had the heavier hydraulic models that were too big to fit in my workshop. So i hired an engine crane, i imagine this is the way most people would do it. I read that you are supposed to lift the mill with a strap around the head and to extend the head up as far as it'll go to balance it all out, the engine crane i hired didn't have the hook positioned right at the end of the jib, so i had to remove the mills motor to get it to all work out. With the motor removed I found that having the mill head as low as it would go then balanced it nicely, which turned out to be a good thing. Firstly the engine crane was low on hydraulic oil and i lifted it to about 2mm above the bench height when it ran out of travel, and it turned out the ceiling of the workshop was too low to allow the mill head to be raised to full height.
Once the mill was on the bench the next job was to cut a hole in the roof above it and build a 200mm high 'chimney' to allow the motor to rise into when i raise the head fully. Thankfully the 'workshop' is in the style of a wooden shed, 6 meters long by 2.5 wide, and i thought i was being generous when i made the roof 2.4 meters high,
A few days after the mill arrived i was finally ready to try it out, i'd not ordered a milling vice yet but had ordered one of the '52 piece clamping kits' with the mill, looking on warcos site they listed the 10mm stud sized ones for the WM16 mill, and all other mills used the 12mm studs (except WM 40 that uses 14mm) You know where this is going, the Gh 18 has 11mm tee slots so needs the 10mm hold down kit (their site now lists this mill as needing the 10mm kit) i had to send the 12mm hold down kit back .. costing me almost £7 in postage and get the smaller kit sent out (which is £9 cheaper, and no refund offered) so i lost £16 there. Below is a photo of the mill a few weeks later, i'd got my milling vice now, but it's more to show the 'chimney' for the motor to extend into, the angle of the photo makes it seem it wasn't needed, i could have got away with 100mm height extension, but wanted to be sure there'd be more than enough space to draw cooling air into the motor, The VFD box is mounted on the wall to the left hand side of the column near the top, it's only temporary, it's going to live in a new electrical enclosure soon. To be continued.... |
