Thread: Omron Varispeed V7 - external potentiometer HELP |
13/12/2019 15:41:06 |
Thank you Norfolk,
Yeah - i'm feeling more and more sure, that the 12/10v thing is a non-issue. I actually JUST got an answer to an email i sent to Omron 4 days ago, 1 minute ago, and they were pretty laissez faire about it, just saying: Don't worry about the 12v, and just use a 2K resistor.". Thanks i guess .
The mechanical side, like hooking up SPDT switches etc. i'm comfortable with, so now the potentiometer crisis is over, i'm good to go .
13/12/2019 15:33:10 |
Howard,
I wouldn't presume to understand your explanation fully, but from what you are describing, the pot does indeed function as a divider.
On leg connected to 0v common terminal, the middle wiper "leg" to the frequency reference input terminal, and one to the 12v frequency reference power supply.
John, the 2K (2w) pot i have ordered had no mention of whether it was linear or not. I assume it is.
Your idea about using the VFD with a reverse switch is great. I had actually already ordered the parts for i, and even a foot switch, so i can activate reverse without using my hand.
That part of the wiring actually seems fairly simple .
13/12/2019 14:24:48 |
Thank you for the concise answer Clive - i really appreciate it.
Your answer makes total sense. I just wanted to hook up a VFD to my drill press, and though "hey - there's one from a reputable company - i will buy that" .
Opening the manual was therefore quite a shock, where one is supposed to know term like impedance . I asked a electrician friend of mine, but he is old school, and couldn't answer me.
So all i wanted to know was, if i would fry something, if i just hooked up a 2K pot to the assigned terminals and changed the appropriate parameters, or if there is something everyone that own a VFD knows, that i didn't.
Thank you again .
Ps. People in here are really kind and helpful. What a cool forum.
13/12/2019 14:08:17 |
Posted by SillyOldDuffer on 13/12/2019 13:36:03:
In practice the difference between 12 and 10V probably doesn't matter, but I'd lose the excess volts with a resistor exactly as you propose. Why risk blowing the drive up for the few pence it costs to fit a resistor?
There's an online calculator here. It suggests a standard value 390Ω resistor in series with a 2000Ω pot. 500Ω would be OK too - pots are often only ±20% accurate.
But I'm worried about the input impedance. 20Ω is very low, and if true would seriously distort the calculation. I'd expect a much higher input value, say 20kΩ. Is 20Ω correct?
Hello Dave, and thank you for your kind reply. I was writing my previous post, while you were posting, so that's why my answer might have seemed odd.
You are indeed right that i misreported the impedance - it is indeed 20k-ohm. I don't even know precisely what impedance is in this context, and what effect it has.
I am ashamed to admit i don't even understand the calculator you linked to. I came to 500 ohm by thinking i would connect the resistor on the leg of the pot, that receives the 12v signal.
So my maths was as follows. I want 10v with a 2K pot, so I=E/R.
10v/2000ohm=0,005amp
I want to lose 2v, so R=E/I
2v/0,005amp=500ohm
But i'm sure your calculation is correct. I will see if i can get my hands on a 390 ohm resistor.
13/12/2019 13:48:30 |
Posted by David Jupp on 13/12/2019 13:17:46:
Diagram at bottom of page 65 of the manual shows how to wire it.
Thank you for looking that up David, and taking the time to respond i believe you are referring to this diagram:
I may not have been clear enough in my worry. As a beginner i see something that says it needs 0 to 10v, in this case the FR terminal, i start to question myself, before using a12v supply. Even with a potentiometer, i am regulation the voltage between 0 and 12v, not 0 and 10v.
I don't know if this over volting has adverse effects, or if the only side effect is, that the last sixth of a turn on the 2K pot, will be a "dead zone".
I might be overthinking this, but it seems very odd, that three terminals that are meant to interact has different voltages. On every other VFD i have seen, the frequency reference power supply voltage has been 10v, not 12v, so i thought i might have gotten my hands on some fancy VFD, where it's common knowledge that you are supposed to put a resistor in series on the 12v side before the pot, to get the 10v, since these terminals also can receive a signal from a PTC.
Here is the complete diagram of the VFD:
13/12/2019 12:32:59 |
Hello.
I bought a second hand Omron Varidrive V7 frequency drive, and wanted to hook up an external potentiometer.
The online manual is very technical, and not written in a very accessible language, but i have found out that i have to connect the pot to three terminals. FP (frequency reference power supply- 12v 20ma), FR (frequency reference input 0-10v 20ohm impedance) and FC (0v common).
Since i'm out of my element, i'm bit confused that the FP terminal supplies 12v, but the FR terminal uses 0 to 10v as reference voltage to regulate the frequency.
They call for a 2K-ohm pot at 1/4w minimum as the analog regulator, so should i put a 500 ohm resistor in series with the pot, at the 12v side, to limit the voltage to 10v? (i don't even know if my maths is right, or really what i'm talking about )
The diagrams don't show this - only the 2K pot, but the descriptions are very vague, so supposedly this is something i should know in advance, but i don't .
On many of their other drives the reference power supply is 10v, but not on the V7 series.
I'm not good at this, and all i want to do is have a knob that can regulate the speed of my machine, without having to get a degree in electrical engineering .
