Here is a list of all the postings john routley has made in our forums. Click on a thread name to jump to the thread.
Thread: aluminium troubles |
25/11/2019 11:14:05 |
hi, the diameter is 45mm 1 3/4" its supposed to be T6 grade just machined a previous sample (machined outside) finish is completely different and quality is excellent, so i'm now drawn to the material as being the issue thanks for all your help. thought I was going mad |
25/11/2019 09:35:42 |
hi guys, I've contacted the material supplier, weve brought about 20m if it. We have tried machining from 500rpm to 2500 rpm using css and also fixed spindle speeds dia turning has been done at 0.25mm/rev with a 0.06 dia finishing cut at 0.05 feed All the tools are 25x25 shank WNT tools ali tips and using CCGT120404 inserts the "o" ring tool is a 2mm wide grooving insert firmly gripped in a grooving holder the radius grooves (5mm) are machined with a 3mm rad tip. roughed out and then finished with a profile program we have brought aluminium specific polished tips for all the tools we flood the material with coolant while cutting parting is terrible, material goes snotty very easily,
24/11/2019 19:55:28 |
ill bring up all the specs tomorrow
24/11/2019 19:46:59 |
Hello baz your very right its a bit shocking, i brought this large lathe and a 4 axis mill, + and load of other machines at the same time, for the most part im very happy but this finish on the lathe is way off what i would expect....is it machinist or machine is the thing or just the tooling.
24/11/2019 18:10:19 |
Posted by Neil Wyatt on 24/11/2019 16:20:09:
It's clearly tearing, suggests build up on the tool tip. Are you using suds or neat cutting oil? I'm used to getting a near mirror finish on 6082 with inserts and just hand applied neat oil. I have struggled to find ground and polished grooving/parting inserts but I would guess they would help. Neil Posted by Neil Wyatt on 24/11/2019 16:20:09:
It's clearly tearing, suggests build up on the tool tip. Are you using suds or neat cutting oil? I'm used to getting a near mirror finish on 6082 with inserts and just hand applied neat oil. I have struggled to find ground and polished grooving/parting inserts but I would guess they would help. Neil hello Neil, we are using suds rather than oil, for the general parts we make out of derin oil is not needed but we are really struggling with this ali, i know part of the issue was machine alignment but i think its now something we are doing wrong |
24/11/2019 15:16:46 |
thank you for the reply's guys, i cant get hold of my machinist today i cant get the rest of the info you need until tomorrow, but i'll get a full list of tip feed speeds etc kind regards john |
24/11/2019 12:51:57 |
hello all, im looking for some help, i just got a cnc lathe, but having trouble with turning aluminium, we did have some troubles with the machine and had to have a company come out and regrind the bed because there was some problems with it, but still cant get the ali looking any good |
