Here is a list of all the postings Neil Minter has made in our forums. Click on a thread name to jump to the thread.
Thread: Grease Myford Super 7? |
10/11/2019 11:15:50 |
I’m in the process of restoring an old super 7. When dissembling, I found the clutch assembly and headstock roller bearings were all loaded with grease? There was also grease in the ‘apron’ assembly around the pinion gears. I can’t find any reference to greasing anything on the Myford, only oiling with the appropriate oils, ie H32, ISO32 or comparable. I’ve removed all traces of grease and would just like to confirm only oils should be used before I reassemble? Many thanks. |
