Here is a list of all the postings John Parry 5 has made in our forums. Click on a thread name to jump to the thread.
Thread: Chipmaster oil leak |
21/09/2021 19:15:47 |
Hi My Chipmaster Lathe was leaking oil out the back end of the clutch. I stripped it down and replaced the two Oil seals back together now and still leaking oil just the same |
Thread: Unknown Dividing Head |
11/01/2020 18:13:19 |
Thread: Harrison Mill missing parts |
18/12/2019 23:44:52 |
Hello Could anyone tell me where the oil drain plug for the main gearbox is located
Thread: Newall DRO |
03/12/2019 19:47:38 |
Thanks for the Idea and the Photos Zan. I do like the Student its a nice size. John |
02/12/2019 23:07:51 |
02/12/2019 22:55:09 |
Hi Is there anyone with the same type as mine that they could photograph for me? Thanks John |
02/12/2019 20:42:58 |
Hi This is my Handwheel, it has the Vernier scale,an earlier design? |
Thread: Hello From Horsham |
02/12/2019 00:30:09 |
Hi Neil No not Zundapp but DKW RT 125na 1944. Other is BMW R51 1939. Very poor photo,sorry. John |
01/12/2019 21:39:01 |
Thanks for going to the trouble to take the pictures Graham. You would have thought that a part with a part number would be the same? I don't understand what the grub screw and the brass pad are for? Many thanks John |
30/11/2019 20:29:34 |
30/11/2019 20:22:07 |
30/11/2019 20:13:33 |
Hi Graham, Sorry but i don't know where that part number that i first posted came from |
30/11/2019 17:05:54 |
Thanks very much Graham. I will look through my box of old valve springs. The Lock nut is the part you unscrew to disengage the power feed. Just where the spring fits. |
29/11/2019 21:27:03 |
When i got my Harrison Milling Machine it was in pieces. Now its almost back in one piece i am noticing some parts are missing. The parts are [ Part number MH1 1 12 Locknut and SG 253 Compression Spring. I know the lock nut has a 1/2 UNC thread. Could someone measure these parts for me?. Many Thanks John |
28/11/2019 23:27:44 |
Hello I have now got the DRO installed. Problem is i find myself not using it, seems to lie as to what the OD is. Got a bit of backlash in the cross slide nut about 0.4 mm i need to make some sort of cross slide lock? Any one else had this problem? Thanks in advance. John |
15/10/2019 21:36:53 |
That is just the sort of information my brain has been looking for. Any thoughts on why i am getting Suds in the screw cutting gearbox? Thank's very much. John |
15/10/2019 20:27:58 |
Kwil I like the way you have routed your cables very neat. How have you done that? I notice you are using all Microsyn scales?, the longer scale on mine is the steel type Spherosyn. I will post some photos of my install soon. John |
15/10/2019 01:48:49 |
Hello, Thanks for the idea of hanging the scale over the back there. That is the only way it is going to fit, i thought i was buying a Bantam specific DRO kit two months later and 35 phone calls and it's still not done. The Newall scales are very cleaver. it's a stainless steel tube with ball bearings inside that the reader head reads from. You would think buying British you would get some good instructions. John |
14/10/2019 00:15:06 |
Hello Has anyone fitted a Newall NMS 300 DRO On a Colchester Bantam MK1? Having problems fitting the cross slide scale, because of the cut outs to get to the compound adjusting nuts. John |
Thread: Closet Machinist |
06/10/2019 21:16:32 |
Hi Great Lathe i have the same but the long bed version. I am in the process of fitting a Newall DRO to mine. I only problem i have had with mine is Suds getting in the feeds gearbox? And i am jealous of your taper turning attatchment. Have fun cleaning it up. John |
