Here is a list of all the postings Tony Worrall 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: End Mill Sharpening of Helical Flutes |
13/08/2019 13:43:38 |
Hello Bill Thanks so much for your help - thats great. Sorry to be a nuisance. Tony
13/08/2019 13:08:23 |
Hello Adrian Thank you for info ref phone number. I am having trouble finding a way to delete it or how to contact a moderator Please help if you can Regards Tony
13/08/2019 12:14:24 |
Hello Andy Thank you for your interest. I have only just joined this forum and still a bit green as to how it works. I have tried to create an Album of photos associated with my membership. The photos attempt to show how I achieved the sharpening procedure. If you need further explanation you can ring me on ****************** (Edit by PM) Regards Tony
Edited By JasonB on 13/08/2019 13:49:35 |
13/08/2019 11:28:04 |
I have found a way to sharpen the helical flutes of End Mills and Slot Drills using a Dremel grinder attached to my Mini Millert plus a few gizzmos I made. If anyone wants info and or photos I can supply but the photos are more or less self explanatory. Regards Tony
Thread: Tony from Burnley |
11/08/2019 21:26:53 |
Thank you to you all for the welcome and information on how to use Albums. To Brian - I think "ingenious" is a bit over the top but thanks for your interest and positive response. Not sure about the automation Frances IoM - I only have 4 * 18mm & 2 16mm End Mills to sharpen. My method takes about 30 minutes to setup the miller for grinding but it only takes about 10 minutes to sharpen each endmill. Don't know of Neils mag. To 34046 - there are 2 other listings on Ebay for the ST1300 - you can get more details of the Parking Brake on my web site if you want. - www.tworrall.uk Hi Fizzy - had a look at your Steam Boilers - very impressive. I agree about costs of Ebay etc but I really just make the parts for an interest / hobby - it covers my costs - I will not make my 1st million thats for sure. Thanks again for all your comments and welcome Tony
11/08/2019 19:02:20 |
Hello Brian Thank you for your help, I have tried to send the photos - hope its successful. More info available if required i.e. how I grind the end faces of an End Mill in lathe. Kind regards Tony
11/08/2019 15:39:06 |
In my workshop I use a Chester DB10 lathe and an SPG Mini Mill. In addition I have all the usual stuff like Compressor, Mig Welder, Generator, Tyre Changing M/C and wheel balancer. As a hobby I make Parking Brakes for Honda Pan European Motorbikes, ST1100s and ST1300s and sell them on Ebay. Having accumulated quite a few blunt 16mm End Mills I eventually found a way to sharpen the Helical Flutes as well as the Ends. I only use the miller and a Dremel plus some other bits of gizmos I made - works great. I have taken photos of the Helical grinding setup if anyone wants copies and or more info. Hope this info is what is expected from a new member. Tony
