Member postings for Alan Southern
Here is a list of all the postings Alan Southern has made in our forums. Click on a thread name to jump to the thread.
Thread: ClarkCL300M lathe
29/06/2019 14:34:09
Hello Neil
thanks very much for your advice. I always hone barrels between 800 and 1500rpm. Conversely I have rested the machine and today I did some test turning and all was ok. Lesson learnt 😂😂don’t hone barrels with a low powered lathe that has an overload trip fitted 😂👍I have already decided to get a more powerful lathe and to sell the Clarke, once again thanks very much.
kindest regards
Alan
28/06/2019 17:15:28
Hello everyone,
I am a new member and a gunsmith needing help. My Clark lathe is excellent for the work I undertake but when honing out shotgun barrels it constantly cuts out illuminating the orange fault light. It works perfectly unless I put even minor load on the motor, I suspect heavy use of stiff honing flap wheels has caused the failure of a component on the board. I have checked motor brushes and they are fine. The board is stamped XMT 2325.Any advice would be much appreciated.
Alan Southern
