Member postings for Richard Thatcher
Here is a list of all the postings Richard Thatcher has made in our forums. Click on a thread name to jump to the thread.
Thread: Help with Electrics on Emco FB-2 Milling head/table
17/12/2018 14:35:43
Hi Joe, I have been looking at the wiring diagram and notice that Emco mark incoming lines as R and Mp do you know why they don't use L Live and N Neutral?
The Emco FB-2 manual that I have says
Mounting the plug for Electric Connection Single Phase Version
The yellow-green wire is connected to the grounding contact,
The Blue and Brown wires (Mp,R) are connected to the other contacts.
So is it that Mp = Neutral (blue) and R = Live (brown).
Thanks, Richard
12/12/2018 20:29:50
Hi Joe, thanks for your reassurance.
I will connect it up next week.
Thanks again Richard
12/12/2018 18:19:34
wiring dig.jpgHi Joe, I am no Electrial Engineer, so no I am still looking at the emco wiring diagram that is above, and I may have worked it out, as I have shown the lead that comes from the milling head has 4 cables three are marked 1.2.3 which connect to 3.4.5 on the Capacitor Black to 5, and Blue to 6.
Please tell me what you think?
Thanks Richard
10/12/2018 20:57:20
Wiring Diagram 1ph Vde Maximat Super 11Hello thank you all for your replies, I have uploaded the Maximat Super 11 Lathe Wiring diagram.
The wires that come from the motor head and the capacitor where they were connected are shown on the right-hand side.
I will also upload a few of the photos that I took when I disconnected the milling head from the lathe.
Any help is appreciated.
thanks, Richard
10/12/2018 15:29:53
motor plate.jpgemco fb-2 mill.jpgcapacitor.jpgblack cables.jpgHello, I am hoping that I can get some help with an electrical problem.
I have an Emco Maximat Super 11 which had the FB-2 milling head attached to the back of the lathe bed 220/240v.
I have been able to buy an FB-2 type stand with table and have fitted the head to the Milling table.
Unfortunately, all the manuals refer to electrical insulation as a mill head attached to the lathe bed, the capacitor being installed within the lathe electrics, the on/off switch being integral on the side of the motor. head
The cable that comes out of the Motor/Switch housing has three wires which are marked 1,2,3 what I would like to know if anyone can help as to how I can wire the capacitor in and then a live and nutural feed into the circuit?
If anyone has experience with this I would appreciate your help.
