Member postings for John Barber 5
Here is a list of all the postings John Barber 5 has made in our forums. Click on a thread name to jump to the thread.
Thread: Strangest Things
27/07/2023 08:17:44
Thanks, Gary, for that information confirming that it really was "once in a lifetime". But that account doesn't mention the total darkness during daytime which to me was the most strange and memorable part, something which would only be expected normally during a total eclipse of the sun.
Thread: Winding Engine Peculiarity
27/07/2023 08:00:37
I've just discovered this description of gab valve gear on Wikipedia. It mentions the Blists Hill engine but doesn't refer to the counterweight.
25/07/2023 11:48:52
One of the strangest things I've ever seen was a weather event in the Birmingham area round about 1980 (I can't be sure of the exact year). I was working for Lucas Girling at Tyseley at the time, and I'd been on my own in a room without windows. When I came back into the main office area something was different, but what? Then I realised it was pitch black outside even though it was the middle of the day. Everyone was staring out of the windows and asking (not entirely jokingly) if this was the end of the world. The sky stayed black for some time then it seemed to turn green before going back to normal. At the same time there was a massive amount of rain. Some parked vehicles wouldn't start afterwards because water had got right inside their engines causing a hydraulic lock. Fortunately my trusty old Transit just managed to turn over and fire. Does anyone else remember this event? I've never seen anything like it since.
Edited By John Barber 5 on 25/07/2023 11:53:11
18/07/2023 13:51:36
Some interesting thoughts there. It hadn't occurred to me that the engine had a slip eccentric, but obviously it must if it is to operate in both directions with just one eccentric. I was previously thinking it might have something to do with the need to stop the engine at a precise position to align the cage with the floor, but if it was just a question of balancing the crankshaft it could probably be done in a simpler way. I like the idea that this is more a slip eccentric feature than a winding engine feature. Could it possibly be just to reduce friction so the "slip" happens reliably?
Edited By John Barber 5 on 18/07/2023 13:52:04
18/07/2023 10:16:23
The winding engine at Blists Hill Museum has a counterweight arrangement which applies an upward force to the eccentric. This seems to be a feature special to that type of engine. I've also seen one at the Black Country Museum which uses a tension spring for the same purpose. I've heard a number of different theories as to what the purpose is. Can anyone give a definitive answer?
Edited By John Barber 5 on 18/07/2023 10:20:01
Edited By John Barber 5 on 18/07/2023 10:41:47
Edited By John Barber 5 on 18/07/2023 10:43:47
Thread: ML7 Topslide Angle Limitations
12/03/2021 19:48:33
Posted by ega on 12/03/2021 12:29:26:
Hopper:
The best I have found thus far is in this thread and John Stevenson's post:
https://www.model-engineer.co.uk/forums/postings.asp?th=90683
I think my original suggestion may have been based on a confused memory of GHT's useful device for fine adjustment of the topslide angle shown on page 143 MEWM.
Thanks for pointing out that thread. There are some interesting ideas in it.
Thanks to everyone who has replied.
12/03/2021 08:02:19
Posted by Hopper on 11/03/2021 23:58:29:
Not impossible. Just takes a lot of faffing about making a sub-table out of flat plate to go between the cross slide and top slide. Can't say I've ever needed to do it though.
I may never need to do it myself, I just find it slightly annoying that if ever I did want to do it, I wouldn't be able to! I'm surprised I've never heard anyone mention this limitation before.
I can see how a sub-table would solve the problem, but it would also further raise the top slide which is already about 3mm too high to take full advantage of quick change tool posts.
11/03/2021 23:49:06
I'm a relatively new ML7 user, and this evening I realised for the first time that the top-slide clamping arrangement doesn't give you the full range of angles. It can't come within 30 degrees or so of being perpendicular to the lathe axis, as would be required for turning a blunt taper. This must mean that there are certain turned components which it is impossible to make on an ML7 - a truly shocking thought!
Or am I missing something?
Thread: Learning CAD with Alibre Atom3D
21/12/2018 10:06:26
Fascinating. The wheels remind me of the Shepherd ball castor.
14/12/2018 14:37:27
Thanks, both.
14/12/2018 11:02:50
If I do an Extrude Cut and the sketch goes outside the material, I am left with some red lines in the Part display. What are they for, please, and can I switch them off?
10/12/2018 16:43:52
Posted by David Jupp on 10/12/2018 11:26:17:
There are actually more ways the taper could have been added (chamfer tool for one).
Yes, I've just discovered you can define a chamfer by a length and an angle. That would be a very good method.
10/12/2018 10:23:29
Hi David and Jason,
I have a couple of questions related to the second MEW article:
1. I assume he only used 'revolve cut' to teach us the technique, as it would have been easier to use extrude with a draft angle, as we did for the tapered hole in part 1.
2. At the assembly stage, is it not possible in Alibre to 'mate' the two conical surfaces, rather than just align them? That would better reflect the physical reality of the situation.
Thanks,
05/12/2018 20:01:46
Posted by AJS on 05/12/2018 18:24:05:
2D sketch was deactivated and the circle just drawn disappeared.
Just wondering if you might have created a "reference" circle, rather than a "sketch figures" circle.
01/12/2018 14:03:05
Many thanks, David.
01/12/2018 13:10:31
Does it mean anything when a 2-D drawing dimension is shown in red? I added two further dimensions to an existing drawing and one came out red. I couldn't see any way to change the colour, but when I deleted the dimension and added it again, it appeared in black as normal.
27/11/2018 22:51:01
Just going back to the question of creating a section view precisely through the axis of a hole in 2-D drawings, I'm still not seeing the ghost lines which David referred to, but I've found his other suggestion of using constraints works well for me. I deliberately place the section line slightly off target, so I can see it snap into the correct position when the constraint kicks in. If the hole appears as a circle in the parent view, I use a co-incident constraint between the circle and the section line. If the hole is sideways on, I turn on hidden lines, then use a symmetry constraint between the section line and each side of the hole. This makes sure that diameters are correctly dimensioned as such in the sectioned view,
26/11/2018 11:08:20
Thanks!
26/11/2018 10:46:54
Is there a rule that a sketch can be used only once? I thought I could kill two birds with one stone by extruding a single sketch in one direction without a draft angle, and then in the opposite direction with a draft angle, but when I try to do the second extrude the "OK" button is grayed out.
22/11/2018 21:16:40
Posted by David Jupp on 22/11/2018 15:51:19:
Another tip for getting back to showing the whole design (zoom extents) - press the Home key on the keyboard..
That also reminds me - you can program pretty much every button function to a keyboard shortcut of your choice. You can even override the default shortcuts if you prefer.
The Home key doesn't appear to work for me. I looked under Help to see how to edit keyboard shortcuts and it was supposed to be under System Options, but doesn't appear to there for Atom. Is it a Design only feature?
