Here is a list of all the postings Robert Atkinson 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: Come on you clever people |
04/09/2018 19:15:50 |
I think Trevor is on the right track. It looks like some kind of H field (magnetic) monitor or antenna. More likely for above ground power lines though. It's effectively a directional radio system. Not Royal Observer Corps (ROC) who monitored for nuclear explosions. They did not use electromagnetic detection systems. Robert. |
Thread: Small Brushless Motors - can they generate? |
04/09/2018 17:15:00 |
Posted by Ian P on 04/09/2018 13:13:07:
Tim, Robert Something in that description does not make sense. I have never seen a 'brushless DC motor' in any aircraft instruments I have seen. A brushless motor needs a power supply to run (to generate the rotating field) and it would not works as a generator. Ian P
notBLDC In the aircraft Tachometer systems they are not called brushless DC becuase they are not run from DC they are called Permanent Magnet 3 Phase Generators / Motors. Magnetically and electrically they are the same as the "motor" part of a drone style Brushless DC motor. Some tacho indicators indicators use induction motors but PM ones are more common. the speed to pointer mechanisim is a magnetic drag cup the same as a traditional car speedo or tacho. Robert G8RPI |
04/09/2018 17:03:21 |
Posted by Tim Stevens on 04/09/2018 16:28:59:
I am sure that when Robert Atkinson referred to 'back to back brushless DC motors', the DC was a mistake for AC. This whole debate has been about motors with rotating magnets and a fixed set of coils, no commutator etc. And I am sure too that what Ian P refers to as a 'normal brushless motor' cannot be the same thing as used on drones and RC models generally. In a drone motor, there is a clump of electronics which so far as I can tell, does the same job as a 'full size' VFD but starting from a small Lithium battery, not the mains. But that does not stop the same motor with no electronics attached responding to a 3 phase input from a similar motor used as a generator, by rotating in synchrony. And surely a stepper motor is the same thing, but with accurately placed magnets etc, designed to go round in a series of cogs, and fed with counted pulses rather than 3 phase continuous? Regards, Tim
No, I ment Brushless DC Motors. The type used in drones and RC cars. ALL motors are Alternating Current at the coil, they have to be to rotate more than 180 degrees. In brushed DC motor the brushes and commutor switch the direction of current. In a Brushless DC motor the switcing is done by electronic switches. In things like small fans these are internal so you put DC in. With he larger model / drone motors the switches are external in a "controller" if you take the basic motor it has 3 stator windings 120 degrees apart and a permanent magnet rotor. The controller produces 3 phase "AC" but it's typically not a sinewave. It also needs feedback from the motor. In earlier designs and simple items (fans) this is by sensors typically hall effect sensors. in newer designs the sensethe back-emf from the coils when the switches are off. So if you have a Brushless DC motor without a controller you can use it as either a pemanent magnet 3 phase AC generator or a permanent magnet 3 phase AC motor. So connect 2 "back to back" , turn one fast and the other will turn at the same speed. Stepper motors will work back to back, but not nearly so well because of their magnetic design. They tend to stall and then won't "pick-up" again. Robert.
04/09/2018 13:04:16 |
Posted by Tim Stevens on 10/08/2018 14:03:09:
Well, this has been an interesting debate - hasn't it? The problem with some of your answers relates to my rather basic grasp of electronics, and the owner of the car himself is way behind me in this respect. So, we want something we can understand. Secondly, the car has very limited dynamo output, and negligible voltage regulation (being an early 3-brush system), and is a six volt system. So, any electronic device would need to be extra clever to cope with variable voltages, etc, and use next to no electricity. The intention was to make an independent (self contained) system, which could easily be removed if needed. And the option of a coil or HT lead pick-up system seems only to be available for 12volt systems (and expensive). But now I have a further question - just confirmation if you like. If I connect the three wires of two identical drone motors, colour to colour, and spin one of them, the other will spin at the same speed - won't it? And swapping two of the pairs would reverse the drive? This would give us a further option, in effect replacing a too-convoluted cable run with three wires, driving a genuine vintage mechanical rev-counter head. Just say Yes, it will work, or no, and explain. Thanks Regards, Tim Edited By Tim Stevens on 10/08/2018 14:09:40 Tim, Robert |
Thread: Myford ML2 re-commissioning |
03/09/2018 12:41:20 |
Well this went off-topic fast! I think I'll stick to my favourite Rocol anti-fretting compound (Molybdenum based) on the screws... Looks like the best way to lock the ML2's spindle without causing damage while unscrewing the chuck/baseplate is to put a expanding mandrel up the back gear end. If I had a working lathe it would be easy to make one Robert. |
Thread: Never Throw Anything Away |
03/09/2018 07:30:05 |
Rather than just skipping or dumping things it's always worth trying ebay or even using freecycle/freegle. I'm stunned how much people will pay for stuff I was going to put in recycling. Old car / bike parts are valuable. Metal can always go to the scrappie or recycling centre. You local garage might even have a scrap bin that they don't mind donations to. Non ferrous, motors and transformers are normally worth cashing in though. Don't forget you are not supposed to put electronics into rubbish skips or bins. If you have more than a couple of boxes of scrap PCBs they can have surprising value. I use AWA refiners www.awarefiners.co.uk They pick it up and you get payment based on the actual metal content, not some "average" value. Robert. |
01/09/2018 15:05:03 |
Myford ML2 re-commissioning. So as I’ve said in my “introduce yourself” post, I’ve recently purchased new old lathe. While advertised on ebay as an ML4 it appears to be a late ML2 (or ML1 with upgrades). Seemed to be reasonable condition and right price, £200, but you don’t know until you see it in the metal. From the photos in the listing it had a nice round end cabinet stand and tumbler reverse. I’m an Electronics / aviation engineer and have used lathes etc before. I had access to a well-equipped prototype machine shop at my previous employment and have been missing it for small home jobs. The big decision was a new “Chinese” machine or an old British one. So that’s decided then. A quick look at the sellers when picking it up showed one significant fault – the fibre headstock V pulley is badly split and warped. Getting the lathe home and having a closer look revealed the following: I’m calling this a re-commissioning as it’s the intention to get a working lathe, not a restoration or significant modification. One thing I am considering is replacing the old induction motor and layshaft with a modern motor and drive. More on that later. Robert. |
Thread: Hello from Cambridgeshire |
31/08/2018 19:09:27 |
Hi Andrew, I'm in a Village west of Cambridge on the A14 with a big Tesco so pretty close to you. I was at the St Neots radio rally on Monday. I'll have to look up the ME club there. Robert. |
Thread: Electric Motor Conversion European - USA |
30/08/2018 20:54:13 |
Muzzer is totally correct. The motor will run fine from a USA 220V socket intended for driers aircons etc. Brown to Red Blue to Black. No connection to the US neutral (white). Make sure you connect the earth wire as the moter neutral will now be at a 110V above ground and any insulation fault that might not show up in the UK will in the US. The setup i very similar to the 55V-0-55V 110 volt safety system used on UK building sites. One thing to note is the motor will run 20% faster as the UK is 50Hz and the USA is 60Hz. Robert (new to ME but I've designed equipment to work in UK and USA) |
30/08/2018 20:03:54 |
Hi, Thanks for all the good wishes. I've had a closer look and some measurements and it's not an ML4. The bed ways are only 18.5" long. It has tumble reverse, 7" cross slide and a swing away change wheel cover (slotted style) so I think it's a late ML2 or an ML1 with upgrades. Now he bad bits. The fibre V drive pulley (3 section) is breaking up and warped and there is half a turn backlash in the cross-slide screw. The spindle looks like it's the later type with the 11/8 12TPI thread. This is nice because it opens up modifying the register for ML7 chucks etc. The size is based on the faceplate that came with the lathe as the chuck won't come off with gentle force so I need to make a spindle lock. I know enough not to use the back gears. Not sure what to do about the pulley, I need to investigate further. The cross slide backlash is in the screw / endplate. This should be just ann adjustment and maybe a thrust washer, but the handle, nut and indictor disk have beed soft soldered together so again investigation needed. Robert. |
29/08/2018 22:40:50 |
Hi, Robert. |
