Here is a list of all the postings Robert Atkinson 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: E.stop wiring |
11/05/2019 11:33:41 |
That looks like the original nuclear reactor SCRAM (shutdown) system. Allegedly the first reactor CP-1 had a control rod hung from a rope and the plan was to cut the rope with an axe if the reaction ran away. They still call a emergency reactor shutdown a SCRAM but there is no longer a Safety Control Rod Axe Man Robert G8RPI. |
11/05/2019 10:00:01 |
Hi Mike, I agree most industrial installations would have the E-Stop in the control line, but most industril machines will be 3 phase and higher current. If we were talking about using industrial quality contactors and switches from reputable manufacturers and suppliers I would be happier with just control line E-stops. However we are talking cheap all in one NVRs made in the far east and I have little faith in their reliability. There is virtually no cost or difficulty impact from putting one E-stop that is close to the NVR in the two phase power input before the NVR. Any additional E-stop(s) can be in the control (holding coil) circuit to simplify wiring and not have power on the wiring. My reasoning is if the NVR does not release when toy press the button you will go for the nearst E-stop which will work 100%. If a remote E-stop does not work you will again go back to the NVR and the primary E-stop. This may seem like overkill, but why not when it is very little cost in time or effort that may save a work piece, machine or bodily harm some time in the future. Robert G8RPI. |
10/05/2019 19:53:47 |
This is my recommended circuit for a KDJ17 It is fine for anything up to a few kW. 0.5mm "twin red" lighting cable would suit the wiring to the secondary E-stop(s) Dave, I think it is quite reasonable to assume that mot of the KDJ17 NVR's sold on ebay are for replacement purposes rather than for manufacturing. For 3 phase you do have to use contactors etc but for safety critical circuits on production equipment you have to use suitably safety rated components. https://uk.rs-online.com/web/c/automation-control-gear/machine-guarding-safety/safety-contactors/ Robert G8RPI. Edited By Robert Atkinson 2 on 10/05/2019 19:54:04 |
Thread: Larger VFD/Motors |
10/05/2019 18:36:24 |
Posted by SillyOldDuffer on 10/05/2019 14:12:01:
<SNIP>
Robert, have you never used an oscilloscope on a hefty valve radio transmitter? My scope probes are suitable. The Gnd is the signal ground, and unless there is an earth fault, there is no difference between earth and neutral. Popping the RCD, or damaging the instrument, or electrocuting the operator whilst using an oscilloscope to measure mains voltage is a new one on me! But as explained, Plan A isn't how I'm going to do it. Andrew suggested a current transformer, £4, which I've ordered. No need for an expensive differential probe, and no direct connection to the mains. The disadvantage of the current transformer method is it might not have the frequency response needed to catch spikes and it can't give accurate current measurements without me doing some sort of calibration. Nonetheless, I'm hoping the results will be sufficiently indicative. Unless EMC wrecks the experiment; the waveform close to the lathe could be dominated by VFD switching transients. The question I'm exploring is: 'What current waveform is drawn from the single-phase supply by a VFD/3-phase motor combination when they are first switched on.' I'm interested in the current profile over the first few seconds. With my lathe, I'm expecting to see a largish current, about 20A peak lasting a few hundred milliseconds, after which the current steadies down to a much lower level. Thereafter I expect the average current to be entirely proportional to the load on the 1.5kW motor, couple of amps idling, rising to 6 or 7A working hard. Part of the fun is checking theory with an experiment. Double fun when the experiment itself is challenging. Dave Hi Dave, You may be surprised by the current waveform you see at the input to the VFD on load. If it is a non power factor corrected drive you will see narrow high amplitude spikes, not a clean sinewave current. These current spikes are "topping up" the charge on the DC capacitor. |
10/05/2019 12:25:08 |
At CAT III 1000V and 80M input impedance that differential probe is effectively isolated and is ideal for the job in conjunction with a current clamp. Croc clips are a bit dodgy though. Robert G8RPI. Edited By Robert Atkinson 2 on 10/05/2019 12:26:06 |
10/05/2019 07:47:43 |
Posted by Nicholas Farr on 10/05/2019 07:04:08:
Hi, I agree with John Swift1 diagram. The E-stops should only control the coil of the KJD17 and if you want more than one E-stop, then they should all be connected in series with the one shown. Protection of the KJD17 should be via a fuse or circuit breaker which feeds the supply to it, as suggested and non of the load current should go through the E-stops as Mike Poole said. One advantage of this is that the only way the motor will start is by pressing the start button and unless the KJD17 is or has been seriously overloaded, it is unlikely to fail and so if you get a power cut during use, every thing after the KJD17 will be in a safe mode when power is restored. Regards Nick. Edited By Nicholas Farr on 10/05/2019 07:17:57 If you put the POWER switching E-stop before the NVR (KJD 17) then the NVR will release when the E-stop is pressed so the motor will not re-start when the E-stop is reset. The bigger problem is the NVR contact is not failsafe. The only force opening it is a spring. If the spring breaks, coil armature or sear sticks or the contacts weld there is no force to break the contact. A properly designed E-stop has forced break contacts. The force on the button is directly transferred to the contacts in the opening direction. Short of the structural strength of the switch being exceeded the contact will open. With the E-stop in the NVR coil circuit all the NVR failure modes or the E-stop failure modes will cause it not to work. Robert G8RPI |
10/05/2019 07:32:24 |
Posted by Mike Poole on 09/05/2019 15:52:39:
In john swift 1s schematic diagram the coil of the NVR is controlled through the estops button and the motor load is switched by the contacts of the NVR. The NVR contacts will be designed to reliably make and break the load current. An estop button is designed to switch the current of a control circuit and is unlikely to break the full current of the motor without being damaged. The coil of the NVR is a very small load and will not damage the contacts of an estop type button. Andys suggestion will put the full load of the motor through the estop contacts which could damage the contacts when operated. Mike This is not strictly correct. For the sort of loads we are talking about here a decent E-Stop switch can handle the full load and still stop the motor if the no-volt release fails. 16A rated 2 pole E-stop switches are readily available. This primary E-stop is close to the NVR. Additional, remote E-stop switches can be wired in series with the NVR coil. The switch side of the coils should be in the neutral side so the wiring is not connected to a high current live. A short to ground will disable the remote e-stop (test them once a month if you are worried) but will not cause a fire as a live feed might. If you do put the remote switch connection of the holding coil in the live a fuse should be fitted at the source end. There is no advantage in fitting the E-stop local to the NVR in the holding coil circuit rather than the power. The suggested dual power and holding coil wiring costs no more and gives redundancy. Personally I would not trust a cheap Chinese NVR as my final safety device. I have designed E-stop, guarding and interlock systems for robotic machines to meet European and North American safety standards so do know a bit about this. Robert G8RPI. |
09/05/2019 22:27:22 |
Posted by SillyOldDuffer on 09/05/2019 12:57:47:
Posted by Andrew Johnston on 07/05/2019 11:17:00:
Posted by SillyOldDuffer on 07/05/2019 10:36:40:
I find it hard to get my head round what the effects of starting and loading a 3-phase motor powered by a VFD might be on current flowing on the input supply. On average - I think! - a motor working at a steady rate is a good fit to this sort of analysis: The problem is that one still needs to account for phase angles, even with averages. So ideally one needs to use complex numbers, or as I prefer to call them two dimensional numbers. If you're going to do some measurements, and I'd be interested to see the results, you'd be better off (and safer) using a current transformer, like these: The datasheets are worse than useless and the frequency range is a bit limited. But they'll give an indication of the current waveforms, and it's a lot safer than playing with high side current sense resistors. You may want to check the maximum input voltage wrt earth before you go connecting to the mains. Andrew Thanks for the hint on current transformers - I shall order one. Meanwhile, I've been exploring my oscilloscope's math functions. No sense made of it whatever until I eventually spotted the math range was set to 1 picoVolt per division! Then took me ages to work out from the manual how to change it. All obvious when you know, baffling when you don't. In the learning phase I'm avoiding mains voltages for safety reasons. I was able to calculate the actual value of a random setting of the potentiometer with this set-up: and this display: I used the oscilloscope's square wave calibration output rather than a sine wave but same sums. Hard work compared with measuring resistance directly with a multimeter, but this is proof-of-concept for the next stage. Plan A looked like this: This would allow the start-up current to be calculated accurately at any point of time over a few seconds, but setting up is slightly hairy because the measurements are taken at full mains voltage. Not frightened of that, but Andrew's 'current transformer' suggestion is both safer and likely to give indicative results with less fuss. It's not necessary to use the oscilloscope's Maths functions at all. (Now I've wasted an hour learning how to use them.) As usual I am neglecting priority domestic duties in favour of this interesting diversion. Dave As shown your set-up is likely to damage your oscilloscope if it dosen't electrocute you. It will certainly trip any RCD you have on the circuit because you are connecting the neutral to ground via the oscilloscope. It's really not something you should be playing around with unless you really need to and take precautions. Robet G8RPI. |
09/05/2019 12:37:44 |
Posted by Grant Allen 1 on 09/05/2019 12:13:38:
So I think I got this now, power IN neutral to 13 Power IN live to 1st E.stop through and onto next E.stop through and back to 23 Power to motor live 24 Power to motor neut 14 And leave the link in place from A1 to 24 Not quite. This would run power through all the e-stops. A combination of your scheme and Johns is the best compromise. If you have a E-stop right next to the KDJ 17 wire it in series with the input as you describe. Then wire any additional E-stops between A1 and 24 as John's diagram shows. It's a debatable point but I would swap the live and neutral on Johns diagram so you don't have 240V live with a high current fuse running to all the e-stops. The problem with Johns circuit is that it relies on the KDJ 17 working properly. If the closest E-stop is wired in series with the supply then if you press the normal stop and it doesn't work you will naturally hit the nearest E-stop which will. The remote E-stops still rely on the KDJ 17 but you generally won't be using them because the normal stop was broken. Robert G8RPI. |
09/05/2019 07:27:31 |
Well I was trying to keep it simple and it's not relevant to the original question. Lets not go into vector control other than to say it certainly does not have a fixed output voltage and any set-up should not exceed the motors rated maximum voltage regardless of the control scheme. Robert G8RPI. Edited By Robert Atkinson 2 on 09/05/2019 07:31:30 |
08/05/2019 22:28:40 |
Posted by Simon Williams 3 on 08/05/2019 20:06:35:
About this root 3 business, it depends on whether the line voltage (230V) is a line to line or a line to neutral figure. To calculate the power drawn by a three phase motor load supplied with three phase 400 volts (line to line inferred) you need the root three factor. If the 230 volts figure is the same - line to line - then it follows that the root three factor is still needed. If the supply is specified as 230 volts line to neutral then the root three factor has already been applied by dint of getting from 400 volts to 230 volts. In each case the convention is that the line current in one phase is specified, and the other two phases carry nominally equal currents. The confusion arises because while it is obvious that a single phase input/three phase output VSD is supplied with 230 volts line to neutral, to develop full power at the motor it generates three phase 230 volts line to line, not line to neutral. The motor rating plate assumes that the delta connected motor will be supplied with three phase 230 volts, just as the star connected motor requires 400 volts line to line to develop full power. Of course the arithmetic changes with phase coverters that can generate 400 volts line to line three phase from 230 volts line to neutral single phase input. HTH Simon While this is generally correct, you would not normally see 230V or 240V line to line quoted in the UK. The output voltage of a VFD is not normally fixed, it varies with the speed with the voltage dropping with the speed reducing. This is to stop excessive current flow. This called V/Hz control and maintains a constant ratio between the two. for a 230V 50Hz motor the ratio is 4.6V/Hz so if running at 3/4 speed the frequency is 37.5Hz and voltage 172V. Note that while this imples that running at 1.25x speed the voltage would be 287V the voltage is not normally incresaed above nominal unless the motor is specified for inverter use at higher speed. This is becuse the higher voltage (and induced transients) can cause insulation breakdown. In any case the power delivered should not exceed the motor rating (average and overload). Robert G8RPI. Edited By Robert Atkinson 2 on 08/05/2019 22:30:25 |
Thread: 3 phase to single phase wiring |
08/05/2019 20:36:17 |
The motor is wired Star (Wye). Is your inverter configured for Star or Delta? If it's Star just leave the motor as is and leave the neutral unconnected. If you want Delta you will have to re-arrange the windings as Phil described above. If you are unsure, leave it Star for now. the downside is slightly lower power and top speed but less stress on the inverter. Robert G8RPI. |
08/05/2019 20:05:22 |
Posted by Carl Farrington on 08/05/2019 19:55:11:
Posted by Robert Atkinson 2 on 08/05/2019 19:48:36:
Posted by Carl Farrington on 08/05/2019 14:55:52:
You're supposed to multiply by the square root of 3 (1.732), for starters.
No you don't in this case. it is all referenced to 240V Phase to Neutral voltage this includes the root 3 factor from the Phase to Phase voltage (415V). If I multiplied by 1.72 again the power would go even higher. I do know about these things, it's part of my day job designing aircraft electrical systems. I'm currently workin on a sytem that is the inverse of a VFD. It takes variable frequency from a engine driven generator and produces fixed 400Hz at more than 10kW. Robert G8RPI. I think I finally get it.. If the 3 phase current requirements on the datasheets are per phase like you said, then that makes sense, although it puts it quite high for the 3 phase input on most of them.
I must admit, I'm still a bit confused, but it's been a long day and I've just had a beer. If 3 phase ratings are always given per phase, then that means our 2.2kW motors which say something like 8A @ 230v at full load, well is that 8A x 230V x 3 ? or 8A x 230V x 1.732 ? HI, 8A x 230V x 3 = 5.5kW seems high but they are taking the worst case of high motor load and low input voltage (230/240V is nominal voltage). If the voltage was specified as 398V (415 for 240V phase to phase) then you would multiply by root 3 instead of 3. This gives the same answer 5.5kW Don't worry about it I keep having to explain this to supposed qualified electronics engineers. Robert G8RPI. Edited By Robert Atkinson 2 on 08/05/2019 20:06:04 |
08/05/2019 19:54:13 |
Posted by Alan Vos on 08/05/2019 18:14:54:
It isn't just motors with brief high initial currents. Last year I used a current clamp and an oscilloscope to assess the inrush current of a decent quality 19V 65W switch mode power supply (Intel NUC). Nominal current, say 1/3 amp. Peak observed, nearly 90 amps. But only for about 250 microseconds. Indeed, I've seen similar issues. In your case it was almost certainly EMI fliter capacitors charging. The main supply capacitor charging would be at least 10s of milliseconds. It's the main supply capacitor charging that drives the need for slower circuits breakers, typically type C. Robert G8RPI. |
08/05/2019 19:48:36 |
No you don't in this case. It is all referenced to 240V Phase to Neutral voltage this includes the root 3 factor from the Phase to Phase voltage (415V). If I multiplied by 1.72 again the power would go even higher. I do know about these things, it's part of my day job designing aircraft electrical systems. I'm currently working on a system that is the inverse of a VFD. It takes variable frequency from a engine driven generator and produces fixed 400Hz at more than 10kW. Robert G8RPI. Edited By Robert Atkinson 2 on 08/05/2019 19:55:33 |
08/05/2019 19:38:26 |
Posted by Carl Farrington on 08/05/2019 14:48:33:
Posted by Robert Atkinson 2 on 08/05/2019 14:45:35:
Hi, 230V x 13.3A x 3ph = 9.177kW. I assume that the 13.3A they quote is for all three phases added together (which would give a more reasonable 3kW) but this is NOT the normal convention which is to specify the current for 1 phase and assumes the 3 are equal. Robert G8RPI I don't think you just multiply by 3 like that. Pretty sure that's not how it works at all. Yes you do, there are 3 phases, they should have quoted the per phase current. see next post for root 3. Robert. |
08/05/2019 14:45:35 |
Hi, 230V x 13.3A x 3ph = 9.177kW. I assume that the 13.3A they quote is for all three phases added together (which would give a more reasonable 3kW) but this is NOT the normal convention which is to specify the current for 1 phase and assumes the 3 are equal. Robert G8RPI |
08/05/2019 07:49:43 |
Posted by Carl Farrington on 07/05/2019 12:59:09:
Posted by Robert Atkinson 2 on 07/05/2019 12:51:51:
Another reason for the input current of 23.2A specified for the Eaton DE1 2.2kW drive linked to by Carl **LINK** is the overload rating and input voltage range. It says 2.2kW output so about 95% efficiency gives 2.31kW. Minimum input voltage is 200V 2.31 /200 = 11.55A. The overload rating is 200% for 1.875s 2 x 11.55 = 23.1A no missing power or incorrect data If running at nominal 230 V this becomes 10.05A full load and 20.1 at 200% overload. Thus a "13A" outlet would be adequate. Power factor is less of an issue with the better modern drives as the input may have PF correction. Robert G8RPI. I'm not sure it's the 200% overload. I think it's the single phase to 3 phase conversion. Have a look at the number on this one instead: **LINK** or this one: **LINK** or this one: **LINK** Well your first example makes no sense at all with "Input Current: 19.6A (Single Phase), 13.3A (Three Phase)" so at a nominal 230V the input power is 4.5kW on single phase and 9.2kW on 3 phase! At 200V it's 3.9kW 1Ph & 8kW 3Ph. (single phase nearly matches the overload figure). At least the Eaton figures make sense. Without qualifying what load and input voltage the input current apples to it's impossible to be sure what it means. For practical purposes the motor rating (in kW) / 200 is a good estimate for full load input on single phase. so for 2.2kW you are looking at about 11A so a "13A" outlet should be OK unless you are overloading the motor.(the 200 is based on 230V, 0.95 power factor, 90% efficiency and rounded up). Robert G8RPI.
Thread: Turning Cast Iron question - Health & Cleaning Up |
07/05/2019 18:52:03 |
Posted by Neil Wyatt on 07/05/2019 18:35:29:
Posted by Martin Kyte on 07/05/2019 09:27:32:
Making pastry will clean your hands. :0) Martin Hairwashing is just as good and less anti-social SWMBO would not thank me for washing her hair with dirty hands and I don't have enough hair to make a difference. |
07/05/2019 12:51:51 |
Another reason for the input current of 23.2A specified for the Eaton DE1 2.2kW drive linked to by Carl **LINK** is the overload rating and input voltage range. It says 2.2kW output so about 95% efficiency gives 2.31kW. Minimum input voltage is 200V 2.31 /200 = 11.55A. The overload rating is 200% for 1.875s 2 x 11.55 = 23.1A no missing power or incorrect data If running at nominal 230 V this becomes 10.05A full load and 20.1 at 200% overload. Thus a "13A" outlet would be adequate. Power factor is less of an issue with the better modern drives as the input may have PF correction. Robert G8RPI. |
