Here is a list of all the postings les peacock has made in our forums. Click on a thread name to jump to the thread.
Thread: On /off switch for small lathe |
16/07/2018 11:55:12 |
Has anyone got a link for an on/off switch for a small lathe, with single phase electric motor |
Thread: Work bench to mount lathe |
10/07/2018 10:58:09 |
Im going to build a work bench to mount my ml2 lathe, what is a comfortable working height, for working on a lathe |
Thread: myford ml2 gears |
09/07/2018 12:31:06 |
Thanks |
09/07/2018 11:59:40 |
I know the gears from myfords ml7 and ml10 will fit the ml2 which has a 5/8th diameter drive hole, so does that mean any gears with a centre hole of 5/8th diameter will be ok |
Thread: myford ml2 / ml4 motor |
06/07/2018 11:12:52 |
Ive decided to go with a single phase 1/4hp or 1/3hp and work on max revs of 1000rpm any recommendations for suppliers for motors
04/07/2018 11:24:14 |
Does any one know the maximum speed you could run a ml2 without damaging bearings, does a vfd allow you to adjust the rpm |
03/07/2018 18:59:47 |
Thanks for the advice very much appreciated |
02/07/2018 20:07:10 |
The centre height is 3-1/8in and what does a VHD cost |
02/07/2018 12:28:01 |
After a little research I think my lathe is an ml2 and not a ml4 as it is 15ins between centres, any way the motor I got with it is a non runner, what motor would people recommend, 1/4hp or 1/3hp single phase or three phase |
Thread: 6MM HSS TOOL BIT HOLDERS |
30/06/2018 12:00:53 |
Im new to machining and looking for a tool holder that may suit my needs , I may have a go at making one but until I have all the tools and equipment to do so it is a non starter |
29/06/2018 20:01:32 |
The diamond tool holders are a bit pricey for what I want |
29/06/2018 11:52:53 |
Are there any sellers out there who sell 6mm hss tool bit holders ,with a small shank suitable for a small lathe |
Thread: TAP AND DIE SET |
26/06/2018 11:25:01 |
Can anyone recomend a good quality tap and die set |
Thread: Myford Easy-set tool holder |
25/06/2018 18:11:27 |
Has anyone got a link as to where you can buy these tool holders |
Thread: Myford, ML7, ML10 , ML4 parts, tools, accessories |
25/06/2018 13:27:16 |
The lathe has a 7/8in thread on the spindle, im a novice when it comes to machining so anything to technical will be a no go until I get a little more experience |
Thread: CHINESE LATHE TOOLS AND ACCESSORIES |
21/06/2018 13:59:26 |
I know the old saying you only get what you pay for but has anyone had any experience with regards to chinese tooling and accessories for myford ml4 lathe or similar |
20/06/2018 13:24:34 |
Are there any parts , tools or accessories used with the myford ml7 and ml10 that can be used with a ml4 |
Thread: Turning tools - hand ground |
15/04/2018 17:59:23 |
I have just purchased my first lathe and after reading this post making your own tools where is the best place to purchase hss blanks and also what are the hardest materials you can machine with these blanks if ground correctly |
