Here is a list of all the postings PaulF has made in our forums. Click on a thread name to jump to the thread.
Thread: Single Phase Switch + EStop? |
03/03/2021 15:08:19 |
Hi i have fitted these NVRs in the past from Warco https://www.warco.co.uk/accessories/346-nvr-switch.html I have fitted them to bench grinders too. Paul |
Thread: M-DRO on SX2.7 |
21/01/2021 14:58:25 |
Looking good Rodger. Now to get the 10V back on the go again. Paul |
20/01/2021 14:21:32 |
Hi Roger. After 3 weeks at sea I have finally had a chance to fit the Y axis DRO. I opted for a fixed tape and moving read head. I used the supplied bracket, then made another bracket to bolt to this, and then both bolt onto the table in the drilled and tapped holes already there. The documentation which was supplied with the kit said the head would work with the tape up to 1 degree angle. This was the angle of the casting of the base, it works fine. Anyway, hope you got yours installed. Paul
20/12/2020 19:23:37 |
Some photos of my X axis installation. Paul |
16/12/2020 20:19:29 |
Posted by Roger Benson on 16/12/2020 18:42:56:
Posted by PaulF on 16/12/2020 17:11:08:
Hi Roger. Im in exactly the same position at the moment, I should have the X axis completed tomorrow. For the Y axis I think I’m going to have a fixed scale bolted to the base casting and make a custom bracket to allow the head to bolt into the holes already there on the table. Paul Hi Paul I have the magnetic version as well. I have not built up much metal stock yet so have sent off for some aluminium to play with. I would prefer a fixed head myself.
Roger I was planning to post some pictures when done (if it’s a good enough job) as there are not many resources online about fitting this type of DRO. I do have quite a bit of aluminium stock in the garage so will hopefully have something useable. I am hoping to have some time tomorrow to finish the X axis and start the Y axis. Paul |
16/12/2020 17:29:52 |
Hi Dave, You have done what I was planning. Thanks for the photos. Paul |
16/12/2020 17:11:08 |
Hi Roger. Im in exactly the same position at the moment, I should have the X axis completed tomorrow. For the Y axis I think I’m going to have a fixed scale bolted to the base casting and make a custom bracket to allow the head to bolt into the holes already there on the table. Paul |
Thread: Ball Nose End Mill / 10V Bearings Question |
14/05/2020 20:34:24 |
I used an RDG Tools 11.0mm carbide ball nosed end mill with good results. |
Thread: Hello from Midlothian |
13/10/2019 18:31:08 |
Hello everyone. I am an engineer in the Merchant Navy (27 years), currently a Chief Engineer. Experience in both two stroke and 4 stroke engines and steam turbine installations. Just overhauled a 1957 ML7 and bought an SX2.7 mill. Currently machining the castings of a Stuart 10V (my first project) in my leave. The 3 weeks on/off rotation suits model engineering! Regards Paul |
