Member postings for Charlie Croat
Here is a list of all the postings Charlie Croat has made in our forums. Click on a thread name to jump to the thread.
Thread: Clarke CL500M (YES I KNOW)
13/01/2018 16:19:38
thanks for all the prompt replies and updates !! will go ahead and give it a go... may take a bit of a creative repair as you can see..now where to put the new box.....anyone know why Clarke moved the switch and plonked it on the side ??..
Edited By Charlie Croat on 13/01/2018 16:31:41
12/01/2018 18:23:39
Hi, just received my new switch for my WEMAS lathe/mill which was a precursor of the Clarke CL500, same thing just way older and made in Germany...had to keep repairing failing switch so happy to find a replacement. Even happier to find this site that can help wiring it. The new switch is the same as yours in the photo...KEBU JD3..looks identical but came with a bunch or pre wiring (( see photos in my album)). So was doubling checking if the wiring diagram you posted did work for you... your post is from a few ago so thought it prudent to do the double check.... thanks in advance.....
