Here is a list of all the postings Jon Lawes has made in our forums. Click on a thread name to jump to the thread.
Thread: Lathe Carriage Stop |
05/04/2019 18:59:37 |
Our MES has a Myford with a lovely little device that clicks off the feed once its reached the desired travel. Fantastic bit of design. You've got a lovely finish on those components, nice work. |
Thread: Todays DUMBO award |
04/04/2019 19:28:30 |
If it makes you feel any better I've done the same thing. I don't remember having set the lathe to reverse but I know it took me ages to work it out... |
Thread: Soft Feel Finish on Radio |
01/04/2019 18:00:15 |
The disabled hand controls in my car did this when parked up for a while. I went to use it again and the rubber hand grip for the throttle/brake had turned to blu-tac. |
Thread: from a 3.5 inch Gezina to 5 inch tramway Plettenberg locomotive |
28/03/2019 20:39:07 |
Looks fantastic Werner, sehr schön. |
26/03/2019 19:54:03 |
I don't think I'd be going off for a coffee break with a lit fire! |
Thread: Completed models - just out of interest |
24/03/2019 16:35:36 |
I quite like refining things after I've built them, an improvement here, a tweak there. Nothing is ever truly finished. |
Thread: Its nearly there ! |
24/03/2019 16:34:30 |
I hope its not too good to use, that would be criminal! |
Thread: DIckins live steam loco |
23/03/2019 22:50:26 |
I thought this quite an interesting page after googling the locomotive to see what you were referring to. |
Thread: Strange Myford Motor Fault |
19/03/2019 21:25:27 |
Sometimes my ML7 would stall and it would turn out the contacts in the Dewhurst switch were grubby, and I think the increased current draw would cause a burn on the contacts. Cycling the switch usually cleared it. Cleaning up the contacts in the switch reduced it, and installing an inline switch to control the power and just using the Dewhurst for reversing cured it. |
17/03/2019 19:48:37 |
Those Dewhurst switches are great for changing direction but for starting and stopping they seem to arc and erode over time. If I can respectfully suggest another switch inline which you use for starting and stopping the lathe, leaving the Dewhurst engaged and only changed when a direction change is required. Its is also a good opportunity to include a No Volt Release switch, which is a good safety improvement anyway. The work you have done on restoring that lathe is superb, good work. Jon. |
Thread: Beware new engine project! |
13/03/2019 10:24:30 |
They have replied: "Hello Thank you for your email. We do not feel it is appropriate to comment on 'chat-rooms'. If you have any queries please contact us directly so we can address any issues you may have, Tasha."
Chat rooms, haven't heard it called that for years! I have replied pointing out that the complaints are there on the thread, what they do with the information is entirely up to them. Based on what I've seen so far I can guess what they plan to do. |
13/03/2019 09:11:06 |
I've contacted the company in question to bring this thread to their attention; it's only fair they have their say. They may not be aware of some of these issues.
Jon. |
12/03/2019 12:44:05 |
Surely the best thing is for someone to steer a representative of this company to this thread. Maybe they are not aware of the depth and scale of the problem. Companies need to be aware of what their customers need in order to keep their custom; although there is evidence in the past there has been a certain amount of "Well its always been good enough for everyone else" bandied about, if they can see how people are feeling they can either a) act upon it, b) ignore it, or as has happened with other companies on these threads, c) angrily tell everyone its the customers fault and resume b). Whatever they choose, there is a chance things will improve.
11/03/2019 18:43:46 |
I complained to the same company (I believe) that their ratchet teeth on a lubricator gear I purchased were far too shallow to work properly, this was the response: "Hello
We are aware that the teeth on the ratchet wheels are not particularly deep however the same one has been sold for over 17 years now. Builders have mentioned it however that is as far as its gone.
Unfortunately we are unable to offer a different one so if you are not able to use it please return it for a refund.
We are very sorry we could not be of more help." |
Thread: If starting again, what would you buy with a budget of £5k? |
11/03/2019 18:40:45 |
I was a little surprised at the tone of some of the responses on here, usually its a helpful place. If people are annoyed that a thread has cropped up again maybe just hold back on responding? I would reiterate though; this will be easier if you can do a bit of research into what sort of work you plan to do; where do your interests lay outside of workshop work? Maybe that will help with the steering? |
10/03/2019 13:43:07 |
Although I can understand your ambiguity, maybe its best to pin down a little more tightly what you can forsee yourself making. Although you say you want to be open about the sort of things you will be making, its currently a "What kind of car should I buy" question, with the answer to "what do you want to use it for" currently no more accurate than "everything". As you can see its a question thats been hotly debated in the past! |
Thread: Just Done Something Stupid!! |
08/03/2019 20:53:13 |
How on earth did you make the holes so regular, I can sit for ages trying to line everything up and still end up with my holes looking like Jackson Pollock drilled them... |
Thread: Western Steam |
27/02/2019 19:30:03 |
Previous experience aside, I reckon a broken collar bone is a pretty fair excuse! |
Thread: Plastic Balls in Bearings? |
27/02/2019 17:12:41 |
Posted by Chris Trice on 26/02/2019 20:06:29:
Back in my car restoration days, I used to specialise in Triumph sports cars and the lower front bronze trunnions of the Herald/Vitesse/Spitfire/GT6 cars, that carried all the weight of the front of the car, had simple plastic bushes shaped like top hats about 11/16" OD and 9/16" I.D. with a steel sleeve inside that. Yes, they wore eventually but they were easy to fix and obviously deemed up to the job. Edited By Chris Trice on 26/02/2019 20:07:33
Funnily enough I'm about to look at a solution to the trunnion design on my GT6. The high kerbs at some circuits does give it all quite a beating and someday I suspect a trunnion will make a bid for freedom. I see some based on a Caterham design are knocking around but I really would like a better solution. I could be tempted to start from scratch with rose joints. |
Thread: Aircraft General Discussion |
27/02/2019 17:10:35 |
All the photographers at Boscombe Down complain bitterly that their Harvard was sold. It was a perfect platform for photography. |
