Here is a list of all the postings Jon Lawes has made in our forums. Click on a thread name to jump to the thread.
Thread: Switches |
17/02/2020 11:57:47 |
I'm not sure if I'm understanding the question correctly, but if its marked as Normally Open then that refers to its state of rest, i.e. not being operated by a finger or whatever. If the switch has two output terminals, say one of each type, they should be clearly marked Normally Open or Normally Closed, either on the switch itself or the datasheet. As a last resort (or a good idea with a switch of unknown provenance!) just a quick check with a multimeter will clear things up.
Thread: What Did You Do Today 2020 |
13/02/2020 15:26:29 |
I started setting the valve timing of my William Prairie. |
Thread: Back after 15 years |
28/01/2020 22:11:09 |
Welcome back to the most rewarding hobby I've ever had. I'm proof you don't have to be good at something to enjoy it, but by the looks of it you are already ahead of the game! |
Thread: Beaten and robbed. |
27/01/2020 10:47:45 |
Posted by Steviegtr on 27/01/2020 10:14:54:
Posted by Tricky on 27/01/2020 08:54:26:
Posted by not done it yet on 27/01/2020 08:12:21:
I read the first sentence (possibly the only full stop in it?). I suppose at least he told us it would have been boring, so easily avoided at the first line. I lost count of the number of full stops as, in fact, the sentences are very short which is much better than some of the rambles that go on here. I thought limited attention span was a fault of today's youth I am sorry for such a long post & the bad grammer used. I left school to start an apprenticeship at 15, having only been interested in Science & Metalwork. The rest I flopped. Probably should know better at 67yrs young. I don't think you need to apologise. Don't forget for those whose eyesight isn't perfect (like me) its possible to zoom the screen on most computers. |
27/01/2020 10:46:42 |
I've bought and sold many cars on eBay, over the years I would guess 10? All for personal use, I'm no trader. The only issue I've had was when a chap who bought an old V6 Mondeo off of me got halfway home before the gearbox blew up. It showed no signs of a problem previously, but had been parked up for a while so maybe some sediment had settled. He rang me on the off chance of a refund, but it was a £1500 car, bought privately. Buying any car privately at that end of the market is a risk for both buyer and seller. As with any of these things, go in eyes wide open and being realistic. I've also avoided looking at cars that were too cheap to be true when the seller told me to meet him at an abandoned pub carpark with the cash.... |
Thread: 1/9 Halifax Bomber Undercarriage |
29/12/2019 13:39:03 |
Welcome, That would have been hydraulic retraction, are you looking for something that looks the part or is an exact replica of the system? Either way it's a fair chunk of effort, I would suggest you make it clear what the deal would be; paying for time and materials etc.
Thread: Slight repair required |
20/12/2019 10:04:24 |
Piasecki were not always the very pinnacle of aircraft engineers... If you haven't already look up the PA-97 Helistat.
Edited By Jon Lawes on 20/12/2019 10:04:41 |
Thread: "Reclaimed Iron Cogs" on Ebay UK |
20/12/2019 09:17:03 |
I may be being a little over-cautious here, and I don't want to unfairly slur anyone, but I am slightly unsettled by someone selling something with such value for so little as they don't know what it is. Surely the original owner wouldn't have let them just go for peanuts, unless it was a poorly carried out bereavement sale or similar? The rest of that sellers items appear to be cast iron items, possibly sifted from a scrap heap before smelting? Maybe I'm being a worrywart. |
Thread: Adhesive to bond metal to glass |
20/12/2019 09:12:27 |
Just a warning, don't be tempted to use an araldite type adhesive (unless its their glass specific adhesive). My grandfather used some to refit his rear-view mirror to the windscreen on an car he owned. What we suspect was the exothermic reaction caused by the hardening process caused the glass to crack a few minutes later!
Thread: Piston Fit |
30/11/2019 21:52:08 |
What a lovely little engine. Top work. |
Thread: William Regulator |
30/11/2019 21:49:55 |
In the absence of any replies, I post this for the benefit of anyone else who comes across this problem: after I cut the edge of the flange off I was able to get access to the sheared off bolt to remove it. Once this had been spun out the regulator unscrewed out freely. The regulator is screwed into the steam pipe. |
29/11/2019 07:22:34 |
I'm currently taking apart a William boiler (the Martin Evans design) to replace what I suspect is a sheared off bolt in the ring of bolts around the regulator, and to potentially improve the seal on the seat. I'm attempting to remove the regulator tube intact but its very firmly in place. I've taken out the vertical steam collector pipe within the dome, removed all the bolts and am trying to ease the tube out but it seems very well stuck in place, presumably by all the brown jointing compound that seems to abound in this particular engine. Does anyone have any tips please? Anything I may have forgotten to disconnect? I don't want to force anything. I have applied gentle heat and penetrating oil to no effect. |
Thread: Ml7 New Owner. |
25/11/2019 20:49:24 |
Where are you in the country Paul? If you are down South West I would be happy to show you the basics on mine. It would have to be the basics, I'm only a novice myself! |
Thread: MIDLANDS MODEL ENGINEERING EXHIBITION |
21/10/2019 14:48:01 |
One quick question; could those who bemoan the lack of exhibits have brought items of their own to display if they did not already? Maybe one constructive suggestion would be to make it easier for individual models to be displayed. I appreciate that for this to happen one would need to be at the show from the start and to remain there until the end... |
Thread: DIY glass fibre pulley? |
06/10/2019 18:59:41 |
I've machined carbon fibre components in the past and even the most hardwearing tools get very blunt tediously quickly. And the mess it makes..... I can understand your logic (my workshop runs on scraps other people throw away) but in this case it sounds like a lot of mess, work and risk to health to save yourself the price of a few beers. I hope that comes across the way it is intended; I mean no offence. |
Thread: Merryweather Steam Fire King self propelled |
06/10/2019 16:20:51 |
Thank you Werner, very interesting. |
06/10/2019 16:20:50 |
Thread: Worried |
26/09/2019 21:58:16 |
What a miserable bunch. Light a candle rather than cursing the darkness. I don't know how many hoops to a rood or chains to a gill, but then I also don't have rickets or TB, so swings and roundabouts. |
Thread: Complete newbie question - RC car from scratch |
20/09/2019 21:36:59 |
Another quick point, Nitro is fun and all, but a good electric brushless setup with a lipo is simple, clean, rapid charging (but you need the right charger) and astonishing power. Way more reliable than nitro and more cost effective too. |
20/09/2019 21:34:05 |
..and I came from an RC10 background! I think the hardest part of the build is likely to be finding a suitable gearbox; may I suggest something like a tamiya DT-02 gearbox? It takes a standard 540 sized motor (the most popular motor size, so it allows you lots of interesting brushless upgrades) and has an integral diferential with output to dogbone style drives that should be easy to build. Many people buy tamiya kits to seperate out to sell on auction sites for those that require spares so the bits will be easily found. It also has convenient mounting points to allow it to be mounted to a simple frame. I would suggest you look at the design of the Kyosho 2wd buggies such as the Tomahawk; for all intents and purposes this is two pieces of solid square section bar bent up at an angle at the front, and joined together with flat plates for the speed controller, radio gear and such. the motor hangs off the back. Flysky 2 channel 2.4GHZ radio gear such as the GT2 will be ideal for this project; it's cheap and reliable, and when you want to add another car you just spend another fiver on a receiver and pair it to the transmitter.
