Member postings for Stuart Smith 5
Here is a list of all the postings Stuart Smith 5 has made in our forums. Click on a thread name to jump to the thread.
Thread: Mystery post
31/08/2020 11:26:40
It is most likely a box belonging to the local council street lighting department.
It may be worth a call or email to them.
Regarding Dave (SOD)‘S suggestion to open the box. DON’T !! Apart from the fact it belongs to someone else, you don’t know what you may find inside. If it contains electrical equipment it may be in poor condition and also you might not be able get it to lock again.
Stuart
Thread: Mini lathe blown fuses and Motor overheating
28/08/2020 19:21:18
If you need a motor or control board, Amadeal sell these and most other parts for their CJ18A mini lathe. ( I think this will be the same as your 618 lathe. There are photos of the motor and control board on their website.
Stuart
Thread: back issues of ME
28/08/2020 11:26:47
Bricky
If you look on eBay you will see one for sale.
Stuart
Thread: How to stop scam phone calls for good?
26/08/2020 22:20:27
Ian
The BT phones I mentioned do not block a genuine caller such as the hospital. They just ask the person ringing to say who they are.
That is the big advantage over our old Panasonic phones for instance which were not as sophisticated.
As you say, phones that block all unknown numbers cause problems for genuine callers.
Stuart
26/08/2020 17:11:39
Buy a BT branded phone (or phones) with call screening and blocker built in.
See my earlier post.
Since we have had this we have had no nuisance calls.
Any number you have programmed into your contacts gets through straightaway. They don’t even know you have call screening.
Other callers get a recorded message asking them to say their name. The phone rings and plays their name and you decide to accept the call, block the number or let it go to the answerphone. So genuine callers, such as doctors, hospital etc will give their name and the phone will ring.
This gives the best of all worlds. No nuisance calls, friends and family get through as normal and other genuine callers get through by announcing their name. Can be used with any network and no ongoing cost once you have bought the phone.
Stuart
Edited By Stuart Smith 5 on 26/08/2020 17:12:10
Thread: KITS
25/08/2020 20:14:29
It seems like the auction has been stopped by the threat of legal action. See this newspaper article:
I was also interested in some of the items, but if the training centre can be saved or taken over by another organisation, this is a good thing surely.
If you look at the terms and conditions of the auction, they are not obliged to sell, even to the highest bidder. No doubt the auction house will have spent money and will be eligible to be paid for their abortive costs.
Stuart
Edited By Stuart Smith 5 on 25/08/2020 20:15:02
Thread: Laptop power supplies
24/08/2020 13:55:07
Seem to be some very complicated scenarios being proposed here.
Surely the most likely is an intermittent open circuit on the lead from the PSU and a battery which is not holding it’s charge.
If the laptop is always used via the mains, a worn out battery may go undetected.
I suggest just buying a replacement PSU initially and see if this fixes the problem. Probably best to avoid the ultra cheap but a reasonably priced compatible one should be OK.
Stuart
Thread: Cut down DRO
21/08/2020 13:36:37
I fitted one to my Warco WM16 in place of the standard one. I have made a small circuit to connect it to a cheap android tablet running the TouchDRO app. ( I have 3 axes ) .
I cut it to length with no problems.
I initially fitted 2 of these to the x and y axes but found the display as supplied a bit small, so that’s why I am using the TouchDRO app. Plus it has extra features.
Stuart
Thread: Waiting for my copy of MEW
08/08/2020 10:49:13
Mine just arrived too.
Thread: Arduino low power alternatives
07/08/2020 09:33:15
There is a lot of useful information on using a bare atmega328 on the Arduino website.
Another alternative would be a PIC micro, but you would need a programmer and different programming software. I have used PICs in the past and there is a massive choice depending on what you want to do, but there is no doubt the Arduino is easier to programme.
Stuart
Thread: Bulbs Electric Life of
24/07/2020 22:52:11
You could use an LED and a circuit from this website to control the brightness :
Stuart
21/07/2020 21:49:23
Just noticed that Martin Hamilton has recommended the same BT phones and he has had no unwanted calls either.
Stuart
21/07/2020 21:45:32
We were always being pestered by nuisance calls, so I bought a BT branded cordless phone (actually have 3 phones but you can get just the one). This incorporates call screening and blocking facilities without any extra ongoing costs and can be used with any service provider.
Have had it for a couple of years now and it has completely stopped nuisance calls.
You can programme friends, family etc in and they get through straight away. Any number not in the list gets a recorded message asking who is calling. A legitimate caller responds, the phone then rings and plays the callers message. You can choose to accept or reject the call, or leave it to let the answerphone switch in. Scammers and nuisance callers don’t respond and also silent calls don’t even cause the phone to ring.
Cant recommend it highly enough.
It incorporates Truecall technology, but there are no ongoing costs.
Stuart
Thread: Copper boiler plate flanging, or not?
09/07/2020 11:08:57
Bob
You might find these videos interesting. They show how Blackgates Engineering make the boiler plates for their Sweet Pea boiler kit.
Stuart
Thread: Small drill bits, <<1mm
05/07/2020 23:05:04
I have bought small drill bits from CPC, mostly for making PCBs. I have just done a search for drills up to 1 mm on their website and these are the results:
Stuart
Edited By Stuart Smith 5 on 05/07/2020 23:05:23
Thread: Which Milling machine and what is its footprint?
05/07/2020 18:17:31
Roger
As I said in my previous post, I have a Warco WM16, but if you are considering the Axminster 2.7, I suggest you look at Arceurotrade. They sell Sieg made machines and are generally cheaper than Axminster and have a good reputation. See their Sieg SX2.7. **LINK**
Stuart
04/07/2020 00:07:02
I have my Warco WM16 on a wooden bench 550mm deep. The chip tray is 50mm from the wall and is 480mm deep. This is about as close as you can put it to the wall so that you can turn the column handle without your knuckles hitting the wall. The y axis handle protrudes about 100mm in front of the chip tray. The mill x axis table is 700mm wide and 930mm wide across the x axis handles plus you need extra space each side for the x axis travel. (About 200mm each side).
Hope this info is useful.
I bought it secondhand and am pleased with it.
Stuart
Thread: Amadeal lathes - Any good??
01/07/2020 19:56:22
I bought a cj18a mini lathe from Amadeal just over 2 years ago. I have been happy with it as an entry level machine to the hobby.
I had no experience of lathes , so looked at the prices and specifications of the similar lathes sold by the various uk sellers ( Warco, Chester, Axminster, Arceurotrade etc). I decided to buy the one from Amadeal as it was among the cheapest at the time and had a better spec than some of the others.
The lathe was delivered quickly . The second time I used it, the plastic hand wheel broke ( I think it was damage in transit). I rang Amadeal at about 4 pm to explain the problem. They sent me a replacement which arrived the next day, which I thought was excellent customer service.
I have bought a few small items from them since and have been happy with the service and prices. They seem to stock a large range of spares for their machines with the prices listed on their website.
I did have a problem with one item ( an ER collet chuck) which was not machined accurately. I contacted them and they sent a replacement the same day with a prepaid envelope to return the faulty one. Unfortunately, the replacement had the same problem, so I asked for a refund. They offered to get them picked up by courier, but I preferred to post them back myself, which I did. They refunded the cost of the item and my postage costs direct to my paypal account the day they received them back.
So overall, I am happy with my lathe and the service from Amadeal.
Stuart
Edited By Stuart Smith 5 on 01/07/2020 19:57:27
Thread: 3 Phase in a Model Engineers workshop
17/06/2020 20:09:05
It may be that the motor starting current is higher than the converter or the single phase mains supply can supply without too high a voltage drop.
Bearing in mind that the starting current will be about 6 times the full load running current, so the 3 phase starting current could be in the region of 50 amps.
The attached document shows the size of motors that can be connected to the DNO network. The largest 3 phase motor that can be connected without any checks is 6 HP and the largest single phase is only 1 HP. This is to avoid voltage fluctuations affecting other nearby customers.
This is something that never seems to be mentioned when discussing the use of single phase to 3 phase converters.
Stuart
Thread: wiring
15/06/2020 13:11:05
Too slow typing! Nick beat me to it.
Stuart
