Here is a list of all the postings C T has made in our forums. Click on a thread name to jump to the thread.
Thread: Songs about Engineering |
23/02/2022 16:29:31 |
6 5 special, The show opened with film of a steam train accompanied by the programme's theme song, played and sung by the Bob Cort Skiffle Group, which began with the words "The Six-Five Special's comin' down the line, The Six-Five Special's right on time. |
Thread: Can you identify this motorcycle? |
23/01/2022 21:00:21 |
Thank you for that yes a BSA C10 from around 1940 looks to fit the bill. Now as an addition I have found an owner's manual for the BSA "C" range of engines giving a little more credence to the C10. Thanks again |
23/01/2022 20:33:00 |
I have looked at many images of the BSA M20 through its production run and am unable to find a match. I thought I was looking at a sidevalve engine but now not sure if it's possibly a 2stroke. Again the James surgested can't find a match. The owner of the motorcycle in the photograph had quite a number of bikes over a number of years. I have found many photographs of him his wife with their transport, his wife also rode bikes. I have extracted 6 bikes so far from an outbuilding. The bike in the photograph is not one of them yet. |
23/01/2022 19:41:00 |
The BSA M20 was the closest match I could find but no not quite. Unless there was slight changes during production period, the shape of the casing changed. |
23/01/2022 19:04:13 |
Edited By C T on 23/01/2022 19:05:33 |
Thread: Voltage sensitive relay |
07/10/2021 18:11:58 |
Posted by Robert Atkinson 2 on 07/10/2021 17:58:25:
You can feed the new fusebox from the AUX battery terminal on the VSR. You should fit a fuse rated to protect whatever size of cable you are using to feed the fuse box at the VSR end. Otherwie if the cable chafes it will cause a fire. Robert G8RPI. Robert, Thank you for the reply, Already installed are midi OTO fuse holders one into the relay and one out of the relay, I just need to replace the fuses. Using the already fitted relay and wiring will save time and money. I will be using only a fan and a light on the circuit and if it takes a little time start up it will not be a problem. I just needed to know that it would work safely. Regards CT
Edited By C T on 07/10/2021 18:13:23 |
07/10/2021 17:55:47 |
Posted by noel shelley on 07/10/2021 17:43:11:
Voltage sensitive relay 140A maximum current rating ? Why only using fan or light when engine running ? Do you have other electrical problems ? Why not run fan and light from the ignition switch run position or if you feel the need for a relay wire this through the run position then to a small fuse box. It seems alot of work and technology for no useful gain. Please explain what you need and why ? Noel Noel, This method is only because most of the circuit is ready installed, I have removed the battery already. Battery needed replacing but having removed the winch it powered I have no use for it. |
07/10/2021 17:53:48 |
This is the relay fitted. 12V Voltage Sensitive Relay - 140A12 volt 140 amp with red LED indicator. Allows split charging of second battery bank without discharging the primary/start battery. 140A Relay makes at 13.3 volts and breaks at 12.65 volts. L 68mm x W 54mm x H 68mm. CE approved. |
07/10/2021 17:46:32 |
Posted by Oily Rag on 07/10/2021 17:24:33:
Where does the 140 Amps quoted come from? Is it the winch consumption? or is it the fuse box rating? Do you not want the interior light to work when the engine is not running? I can understand the fan not being required when engine 'off' but I would have thought the interior light would ideally be switchable at all times. I also do not understand exactly what you mean by a voltage sensitive relay! Do you really mean the AWL relay (Alternator Warning Light)? Or do you mean a dual charging relay as used with caravans, which only charges the accessory battery when the main vehicle battery is consuming less than 13.2V? A brief sketch of the circuits to be employed would be helpful as well. Martin Martin Thank you for the reply. The 140 amps is the relay it is a voltage sensitive relay and was used to charge the auxiliary battery. I wish to repurpose it to create a circuit with a fuse box not a battery on the one end. The relay has three connections one to the starter battery one to the auxiliary battery and an earth. My plan was to use the cable which went to the auxiliary battery to feed the new fuse box and not a battery. Thus creating a fuse box live only when alternate is charging. This method is only because most of the circuit is ready installed, I have removed the battery already. Battery needed replacing but having removed the winch it powered I have no use for it. Regards CT
07/10/2021 16:32:56 |
I am in need of some reassurance or it could be putting on to the correct tracks. I am still working on my Land Rover Defender, I have just removed a front winch (The winch had seen better days). It was powered from an auxiliary battery which was charged via a volt sensitive relay 140Amps. I want to install a 4 way fuse box to run a small fan and an additional interior light 20/30watts max load. I want he fuse box to be live only when the engine is running. Am I correct in thinking that I can connect the fuse box from the voltage sensor relay without an additional relay or is this out of the question. The auxiliary battery is also removed so direct from relay to fuse box. Thank you in advance CT |
Thread: 12volt three wire fan connections, |
15/09/2021 18:18:10 |
Posted by John Haine on 12/09/2021 18:28:23:
You are overthinking this. If the maximum input voltage is 10V then feed the control wire from a potential divider with a 2.2 K resistor to +12V and 10 K to ground. This will give just under 10V on the control wire. Or use a 10 K potentiometer with one end grounded and the other connected to +12 V through a 2.2 K resistor, the slider on the violet wire for speed control. You won't need things like voltage stabilsers etc. Thank you I have purchased some Bochen 3296. W103 (10k) and it is working just fine. Regards. CT
12/09/2021 17:21:51 |
Thank you for your replies, I now have a better understanding of how the fan should be connected. Let me first describe my understanding from your posts and then ask another few questions just to clarify which direction I will be going. My understanding is that the fan will work on a DC voltage from 9V to 15V and that is via the RED + and the BLACK – wires, the third wire PURPLE (VIOLET) Is a control wire and requires a + feed of between 0V to 10V to make the fan function. I hope that's correct so far. I know that 0V on the control wire and the RED and BLACK hooked up to the car battery gives no fan rotation (because I have tried it) but will the fan speed vary with voltages from 1V to 10V (I have the 0V to10V from the link given by Michael). On the subject of the control wire and the 0V to 10V will the 10V be a maximum voltage if it is then would the simple solution given by SillyOldDuffer cause damage the board within the motor? If it is the case that 10V is a maximum, I would need some form of regulator to limit the vehicle voltage to 10 volts. I have in the past come across things like ballast resistors, voltage regulators and voltage stabilisers. I have done a little googling with the above and spotted a 10V voltage stabiliser used on car gauges for greater accuracy of the gauges. Voltage Stabilizer (148876J) (sngbarratt.com) Would one of these on each fan serve the purpose to set a maximum of 10V on the control wire. Currently I believe that running the fan at full speed will fit my application but if in practice I find I need to slow the fan speed or vary the fan speed would a potentiometer between the voltage stabiliser and the fan serve as a speed control. If it will what specification potentiometer should I use. I hope I have not asked too-many questions and thank you again for the help so far Regards CT Edited By C T on 12/09/2021 17:24:39 Edited By C T on 12/09/2021 17:25:40 |
11/09/2021 17:15:20 |
I have just purchased two mini fans, these fans are used on VW T5 transporter vans to move warm air from the front of the vehicle to the rear. I would like to use them in a similar application but on a Land Rover Defender 110. They have three wires and that has thrown me into a panic haw do i wire them up. The wire colours are RED, BLACK and PURPLE. I have connected the red to a positive and black to negative on a car battery the fan dose not work. Please help Regards CT |
Thread: Retro fit heated window elements |
11/10/2020 16:37:05 |
Gentlemen, Thank you for your replies, i have purchased two kits to do the job . Yes it would be nice to have done the job with one kit but I would be the two vertical pieces short. Nevertheless having two kits I will use them. I believe my none electrical brain understands what you are telling me but please can someone confirm this way will be correct please. I fit the window heaters as per the instructions using both kits one on each window. Now because I will have halved the length of each heater my connections will be as follows:- Left hand window attach the positive cable to the left hand terminal, right hand window attach the negative cable to the right hand terminal. Now the other two connections join them together to complete the circuit. This installation will give the heat the kit intended. Please accept the other part of the wiring like switch and fuse I am OK with. Thank you in advance CT |
10/10/2020 17:19:22 |
Hi, I am hoping someone can help I have two small windows in each side of an old 110 Land Rover Defender, which I would like to install heated window elements. I have the kits supplied by Holden Vintage and classic parts **LINK** I am OK with the general procedure to install and all the required wiring but what is not sitting comfortable with me is the CUT TO LENGTH of the horizontal strips. Why I am not comfortable is the windows I intend fitting them to are half the size the kit is capable of covering. My question is if I just cut them to my correct size (which is half the size they are capable of covering) will I be changing the resistance of each horizontal strip and altering the heat output at which the completed installation should work? The instructions (they are in the link) give a size stipulation for the height I am OK with that it is just perfect for my application. I could fit double the number of horizontal strips would that help or hinder? CT |
Thread: Help required to select correct replacement Relay |
21/04/2020 17:14:33 |
Posted by Grizzly bear on 20/04/2020 18:29:55:
Hi CT, Thanks for your reply. The transistor is good for 0.5 amps, it's only operating the relay coil. If you have an automotive relay to hand, go for it. Good luck, Bear. Grizzly Bear. Thank you for taking time out to help. Sorry for the delay in getting back but cleaning the house plastics (guttering, soffits and the like) interrupted serious work. Back to business I do have a number of relays I have collected over the years not all new ones but in the collection is a new R20BC- 5 blade 40/30A changeover relay. Data sheet https://www.vehiclewiringproducts.co.uk/c-219-relays-flasher-units/p-644-12-volt-5-blade-relay I also found something I had forgotten about it was when Maplins were closing down I purchased a number of items I thought may come in useful. In amongst a lucky bag of random things one of which is a timer kit you know the self assemble ones. Well in the kit is a 5 pin changeover relay HKE HRS4=S=DD12V C Found the data sheet https://www.manualshelf.com/manual/hke/hrs4h-s-dc12v-c/datasheet-english.html Is there any mileage in either of the relays? Regards CT
Thread: Another mystery object. |
21/04/2020 10:04:06 |
Posted by Ian P on 19/04/2020 19:41:09:
Grinding spindle extension is my best guess too, the only thing that makes me curious is how it is meant to accurately locate itself and run run true. Unlike a lathe chuck there is no register associated with the 5/8" thread, there is only the remains of the 1" diameter face once the spanner flats are taken into account so the slightest burr on the face would throw the far end of the extension quite a long way off. If it is for internal grinding then presumably it would be rotating at high rpm so concentricity and balance are really important. The extremely fine pitch and the very close fitting thread of the collet nut point to it being a precision made item but its at odds with the mounting thread. Ian P Ian, I should have read your first post fully as you had already dismissed the grinding quill theory sorry, A three things come to mind firstly do you know where the engraver came from (the company and what they produced) this may give a clue. Secondly is it an ejector rod? The reason I ask this is because many years ago one of the things we made for the foundry industry were ejector plates and ejectors they were of a similar design to your mystery object. We never made anything as long as your one but that's not to say no one did. It has all the features securely bolted to a plate, a number can be used of differing lengths, replaceable wear part "the ejector pin" held securely by a collet system and adjustable to ensure accurate contact with the part being ejected. Third but the collet doesn't fit the criteria is a Core drill spindle--https://www.ebay.com/itm/2x-Core-Drill-Bit-Adapter-5-8-11-Thread-Male-to-1-2-Shank-Diamond-Power-Drill-/401074587031
Regards CT
Edited By C T on 21/04/2020 10:04:40 |
20/04/2020 17:18:04 |
Posted by SillyOldDuffer on 20/04/2020 11:30:02:
Posted by Andy Carruthers on 20/04/2020 09:04:39: ... I did find this relay on eBay: https://www.ebay.fr/itm/163857213519 Please check the pinouts and unfortunately I don't speak French but it *might* be the right part I think this is certainly the right part. It has a matching part number. HR-AMR-Y/012 Z1 HR-AMR-Y means it's an Automotive Relay. Although 'Fitre' made the faulty one there's no reason to replace it with another 'Fitre', any part matching the specification should do. 012 means it has a 12V coil Z defines the pins, internal switch arrangement, current capacity and the 'must operate' and 'must release' voltages. 1 means the relay is fully sealed rather than being open or having a removable dust-cover. The codes that matter when ordering an equivalent automotive relay are 012 and Z, and the French site ticks all the boxes. Decoding part numbers is hit and miss. Many manufacturers use private codes making it difficult to identify entirely bog-standard components. Published identifiers can be hard to track down and it doesn't help the generic identities come in national flavours, usually for historic reasons. But in this case I think it's clear - the French relay is compatible, fingers crossed! Dave Dave Thank you, With the detail you give to the identifiers and that you are absolutely clear in your own mind the French offering is perfectly compatible "not just compatible but exactly the SAME" relay then I think I will take a chance with ordering two from them. I know I have been guided away from choosing an automotive sized relay and fitting it outside the module but would it have WORKED? Regards CT
20/04/2020 10:25:21 |
Posted by Dave Halford on 20/04/2020 10:13:18:
If RS fails you try Farnell Morning Dave I have also looked at Farnell and was unable to find a suitable replacement. My not finding a suitable replacement is more than likely due to my lack of knowledge than anything else. All I have to go on is the pdf data sheet and me trying to match all the criteria of the original relay, not knowing what is critical and what's not. Perhaps the only feature I can be sure of is that the colour of the case is not critical. After saying that I bet someone will say how the colour is important for heat distribution and can be detrimental to working heat range.
Regards CT
20/04/2020 10:00:13 |
Posted by Andy Carruthers on 20/04/2020 09:49:09:
Occams Razor - the simplest solution is always the best I would go with direct replacement otherwise I have to ensure the replacement meets or exceeds the original item specification and modify wiring which from experience is time consuming and makes the fix non-standard, in years to come I don't have to remember what I did! Thank you for that yes I agree simplest is the best. The pins on the French unit look the same as my one and if made to an ISO or equivalent standard will have the correct spacings so do we (royal we because I don't know) believe they will be a direct replacement? I have put a photo of the SPAL M5 control unit in my album. Than you CT
