Member postings for Oldiron
Here is a list of all the postings Oldiron has made in our forums. Click on a thread name to jump to the thread.
Thread: WHAT IS IT ?
12/03/2021 11:31:28
Well spotted Martin. I missed that. I have sent a copy of the image to my FIL who is a Prof of Mathmatics maybe he has seen something like it.
regards
12/03/2021 11:20:50
It appears to be a calculator that can be used to add fractions together. Also seems to be in 1/64th increments. I have a huge collection of calculators & sliderules but this one has escaped me.
envious regards
Edited By Oldiron on 12/03/2021 11:21:05
Thread: Sending Unpleasant Personal Messages
11/03/2021 14:15:11
I have never had that happen to me on this forum. I cannot see how attacking someone for their views can help any thing. I did get some really vile messages on the old Boxford forum when I suggested a few changes I thought might help improve some aspects of it. Some on my email which could only have been revealed by the mods. Soon left there and never went back.
regards
Thread: Keeping track of tool inserts?
11/03/2021 14:06:32
Once it gets a bit dodgey mark the bad edge with Tippex and turn it round. Of course you could be OCD like my brother and make up a spread sheet with hours run etc for each tool/tip.
regards
Thread: Metal Lathe help in Southampton
11/03/2021 14:02:27
Hopefully the "mens sheds ( ladies accepted )" will be open soon. There is one next to Bitterne Bowls club SO197NP. There are others, you can search here>> Sheds
IHTH regards
Thread: Record drive centre poor quality?
11/03/2021 13:52:30
When I had a wood lathe many years ago I always fouind the 4 prong centre to be very inferior to a 2 prong or a serrated ring type centre. Always difficult to get a 4 prong to bite unless you bandsawed a cross into the end of the block. I much prefered the centre and 2 sharp outer pins to all the others.
regards
Thread: Model Engineers Handbook
10/03/2021 20:48:09
Posted by Peter Ellis 5 on 10/03/2021 16:46:01:
Posted by Bo'sun on 10/03/2021 15:25:51:
So who is Lyle Peterson (Tubal Cain)?
He is an American retired metalworking teacher. I think his later videos dropped the Tubal Cain name after complaints. Whilst the name is Biblical, Tom Walshaw used it for 50 years and although it was disrespectful of Tom, I don´t think he was aware of him.
mrpete still uses the monica Tubalcain ( no space between ) It is in every title of his video's.
regards
Thread: What’s this tap? Thread form?
10/03/2021 17:12:07
Disregard
Edited By Oldiron on 10/03/2021 17:14:37
Thread: A Certain Age
09/03/2021 15:18:00
Posted by Nigel Graham 2 on 09/03/2021 11:11:35:
Well, as a bus-pass age bloke in a shed, I use computers now, having been introduced to them at work at the ending of MS DOS and the start of WIN 3. When I retired the organisation was on WIN 7 Pro.
I can remember way back using Gem desktop UI on I think an Amstrad IBM compatible machine. If I had a really good search through my old floppy's I might still have a copy. Or maybe I copied it to a cd when I was compacting my software library.
regards
Thread: mitre saw use for roughing out/ vertical milling mild steel?
08/03/2021 12:12:08
Posted by jon hill 3 on 05/03/2021 14:50:59:
I guess this is one of those questions that will have some screwing up there face at the thought of such a suggestion but here goes:
As I have a hobby grade milling machine which would struggle to cut say even a 4mm grove in mild steel, could a wood mitre saw be used for 'rough' horizontal milling with suitable metal blades and perhaps a taylor made clamp?
I am just thinking out load and wondering if this is a practical shortcut?
Most if not all "hobby" machines should be able to cut a 4mm groove in M/S. My little Chester Conquest will cut 10mm wide by 2mm deep in one pass with out struggling. A lot more if I take it easy. It all depends on diameter/RPM/speed (FPM)/depth of cut & sharpnes of cutter.
If you are having trouble at 4mm diameter maybe if you tell us in what and how you are trying to make a slot we may have some tips for you.
regards
Thread: Compressor questions
08/03/2021 11:54:58
Best to let the air bleed out from the vavle under the tank so as to drain any water accumalation.
regards
Thread: Mad Modder site not secure?
08/03/2021 11:39:57
I use go there quite often and have no problems with it. Malwarebytes does not report it as dangerous.
regards
Thread: Dipping a toe into VFD stuff
06/03/2021 11:01:01
IMHO. Just clean it up and replace any dodgey bolts etc. Replace the cable ties for nice shiny new ones and sell it on. Anybody looking for a second hand wheel will want it cheap so will not be willing to pay the price for a shiny new VFD & motor.
regards
Thread: Model Engine Show USA
05/03/2021 14:23:34
Posted by JasonB on 05/03/2021 11:06:34:
Plenty of other shows and great individual models if you look through Gil's (Reddrryder)videos, he has quite an impressive private collection of models
Yes a very good collection of models he has there. Collection
regards
Thread: Is this a daft idea please?
05/03/2021 10:48:40
See here Moving mill Plenty of other threads on this subject.
regards
05/03/2021 10:43:18
For anyone missing the model engineering shows here are a pair of videos of an American show. It took me 2.5 hours to get through the first one as I kept pausing the video to get a better look of what was on show. The second one I will watch in a few days when the fancy takes me.
Model engineering show part 1
Model engineering show part 2
enjoy.
regards
Thread: SouthBend 9 Model A (NAR10) - Instruction Manual
04/03/2021 10:04:03
The Boxford chuck back plate will tighten up before it settles onto the spindle spigot unless either part has a badly worn thread. "been there done that" It is the difference between 55Deg & 60Deg thread.
regards
edit for missing word
Edited By Oldiron on 04/03/2021 10:04:51
Edited By Oldiron on 04/03/2021 10:16:55
Thread: Moving warco gh universal into workshop
28/02/2021 12:15:28
Posted by Speedy Builder5 on 28/02/2021 11:39:34:
Visit you local weight lifting gym - ask for 4 strong men, 2 x strong timbers + straps and carry it up there. You can be the "Banksman".
Those 4 men are probably very out of shape due to gyms being shut for the last few months. Also not able to help due to Covid restrictions.
regards
Thread: Boxford electrical problem
28/02/2021 11:48:54
Graham Check your inbox at top of page.
regards
Thread: Problems using Clickspring's technique for Blueing steel
26/02/2021 19:16:49
Posted by peter smith 5 on 26/02/2021 19:07:24:
Go onto that Amazing site, put in Cold blueing and see the results.
pete
No idea what that site is. Give me a clue.
regards
