Here is a list of all the postings Peter Daw has made in our forums. Click on a thread name to jump to the thread.
Thread: blackgates eng |
17/11/2017 15:15:22 |
hi all have at long last contacted blackgates thanks for all your comments regards peter |
05/11/2017 11:10:35 |
thanks for all your replies have tried ringing but just goes to answer phone will try again monday cheers all |
04/11/2017 14:32:35 |
hi can anyone tell if blackgates are still trading ? |
Thread: 5" gauge loco |
17/10/2017 13:26:30 |
hi duncan thanks for your input quite interesting to read the technical side of the question regards peter |
08/10/2017 13:40:54 |
hi julian thanks for your help and advice very helpful regards peter |
08/10/2017 09:48:39 |
thanks julian one question i forgot to ask was do you advocate the use of a lead ballast behind the balance weights ? also can a 5" metro boiler be constructed single handed i used to be a welder fabricator in the past and also did a lot of brazing manufacturing vehicle components with oxy acetalene and gas flux so i am understand the process thanks for an anticipated reply regards peter |
07/10/2017 13:35:00 |
Hi can anyone put me right on this question i am thinking of building a 5" gauge 2-4-0 metro but one part of the drawings is not very clear to me which is the crank axle has the right hand crank leading but does not show the position of the crank pin in relation to it can somebody please put me right regards P Daw |
