Member postings for Keith Whiddett
Here is a list of all the postings Keith Whiddett has made in our forums. Click on a thread name to jump to the thread.
Thread: Jason's Firefly .46 Build
24/11/2018 10:52:56
Hi Peter, I would suggest your tolerances were a bit tight regarding the crankpin,I put a small chamfer on the pin to enter the hole and froze the pin, locktite the pin. Make sure every thing is perfectly square when pushing in the pin.
You could of course turn the crankshaft including the pin! I ballraced my engine a very worth while modification
Good luck.
Thread: Steam boiler identification and advise
11/07/2018 15:39:41
Edited By Keith Whiddett on 11/07/2018 15:41:21
11/07/2018 15:36:28
i have just been given a gauge 1 boiler, having just finished a stuart turner 10v and a 10 h can I use this boiler to run these engine?
Having said that could any body tell me what pipes do what ie there are three 1/8th pipes coming from fire box end,centre one goes to Center of boiler top and appears through union. The other two 1/8th pipes go through to the front of boiler into threaded unions? Any help would be very welcome  picture in post below is front of boileruld be very welcome
Edited By Keith Whiddett on 11/07/2018 15:42:45
20/04/2018 18:54:34
Thanks for like Jason. What I did not add is that I ball raced the main shaft !!
20/04/2018 16:35:46
many thanks to Jason for the thread as that was all I had except for the plan smiley. Engine mount wood is flexing hence movement sad
**LINK** https://youtu.be/DQ_LxO-p75s
My first attempt at an ic engine, very please with result, it’s not exhibition standard but it runs and looks ok.
Edited By JasonB on 20/04/2018 18:10:02
24/09/2017 23:33:05
Hi would some body be kind enough to tell me where I can get the plans for this engine,please
Thread: Nemetts 15cc engine
07/01/2017 21:10:49
Hi to all I am new here and would like very much to make the Nemett engine. I have enjoyed reading this thread and I have seen that there is a subscriber living near me who if he is willing would allow me to contact him and perhaps get a word or to of advise and if I need it some help?i live in Norwich my email is [email protected], I hope to be in touch very soon many thanks keith
