Here is a list of all the postings Ray Creighton has made in our forums. Click on a thread name to jump to the thread.
Thread: which parting tool |
19/12/2018 12:17:06 |
Hi, Check out: eccentricengineering.com.au (there is a UK agent) , inverted parting tool, Great design as all the shavings drop out to aid clean parting HTH
Thread: Power Feed For My SX3 Mill |
22/09/2018 13:31:58 |
Hi, Two years ago I purchased a Sieg SX3L Mill and also purchased the then new version of the Sieg X axis power feed. See my message above I posted just after I purchased the mill from Ausee.com.au in Melbourne, Vic, Australia. In the early days of using the SX3L I had intermittent problems with the X axis power drive clutch which connected motor to the X axis lead screw, the clutch was jumping out of engagement, I made some measurements and found out the clutch only had a 1mm engagement, I called Ausee.com.au and explained the problem I was having with the SX3L clutch. They contacted Sieg HQ in China, It turned out the wrong part had been supplied with the Sieg X axis power feed. Sieg HQ supplied the correct part which had a extra 4mm of engagement over the old one, a week or so later it arrived via courier, and I soon had it fitted, that was over two years ago.
I am VERY pleased with the Sieg X axis power feed and my SX3L mill, Ausee.com.au provided great service. The X axis power feed has saved me from many hours of hand wheel cranking. I am now working on driving the Z-Axis hand crank with a NEMA 23 Stepper motor, 3.0Nm(425oz.in), 10mm shaft Regards Ray (Brisbane, Australia) Edited By Ray Creighton on 22/09/2018 13:33:42 |
Thread: Titan HSS drill bit sharpner |
06/02/2017 09:21:28 |
Hi,
Years ago I purchased a USA made Drill Doctor 300, BEST WORKSHOP TOOL I EVER PURCHASED ! If I have a blunt drill, it takes the Drill Doctor less than one minute to to sharpen to a accurate sharp finish. I will be upgrading to a Drill Doctor 750X soon to expand the size and type of drills I can sharpen eg Split point drills
HTH Ray Brisbane OZ
Thread: magazine |
12/09/2016 01:59:03 |
Hi,
Just logged in to my subscriptions and it show I have no subscriptions should expire end of year! no wonder there is no MEW 246 issue. Have emailed PM Ray |
10/09/2016 12:12:16 |
Posted by David Chambers on 10/09/2016 10:45:35:
MEW 246 is not accessible through pocketmags for me. I tried the offline viewer on my PC and through the website. Latest shown in both is 245. I can read 246 through the archive on this website.
Hi, I also have not GOT access to MEW 246 just checked the offline reader. Ray |
18/08/2016 13:55:57 |
Hi, I have just purchased a Sieg SX3L mill from Ausee.com.au and with the long table there a lot of hand winding. Ausee.com.au have just received a shipment of the All NEW SIEG X3 Auto Feeder with Clutch There is a clutch to disconnect the motor from the mill table when hand winding, this solves one of the main issues with the previous design. ----------------------------------------------------- SIEG's newly developed power feed with clutch and limit switches for SIEG X3, X3L, SX3 and SX3L Mill. This Variable speed power feed mounts on the left end of the worktable and smoothly drives the X-Axis leadscrew at a constant speed (feed rate), thus, smoother and finer finish can be achieved. 2. Variable speed 3. Clutch disengages power feed when manual operation is required. 4. Adjustable limit switches 5. Supplied with a 120-240V, 50-60Hz power adaptor. -------------------------------------------------------------- I have placed a order for one of the new power feeds for my now SX3L mill, expected arrival Monday 22 Aug 2016. Once I have it installed and working I will report back. Regards Ray (Brisbane OZ)
