Here is a list of all the postings MW has made in our forums. Click on a thread name to jump to the thread.
Thread: Something exciting on its way... |
30/08/2017 21:08:51 |
Posted by Bikepete on 30/08/2017 17:04:05:
On Twitter Neil says it's "well wicked". Four candles?. Perhaps he's referring to wicking properties; ability to absorb moisture? I wish I could get another micro lathe but then I would be neglecting the sherline ;'( Michael W |
Thread: lathe bit sharpening |
28/08/2017 19:58:06 |
Posted by Michael Gilligan on 28/08/2017 18:25:59:
Posted by Michael-w on 28/08/2017 16:16:43:
It's important to understand there's no equity between what material you choose to cut with vs. knowing how to sharpen tools. So learning how to sharpen and change the qualities of HSS tools is definitely worth the experience. There's no replacement of HSS when it comes to taking the finest of cuts from a sharp tool. Michael W . I agree wholeheartedly with the sentiment, Michael; but you are showing your age [or lack of it] ... Years ago, comparisons similar to those we now make between carbide and HSS were being made between HSS and high carbon 'crucible steel'. MichaelG. Thsnks Michael, It's good to see you back again, Definitely a lack of age, I could muse from what I know about my rudimentary introduction in steel making, how it started off as such an unreliable process, due to the fact that iron is only ever found in an oxide form in nature. If I were a wood worker, I would probably place my bet on carbon steel giving a nicer cut. But for metal working, there's just something about HSS that makes it so versatile that it can be used satisfactorily for nearly any material and that's why I recommended it there and why I would recommend anyone to use HSS in a foundation sense. Michael W
Thread: New Moore & Wright any good? |
28/08/2017 16:23:33 |
Definitely stick with mitty-witty-tuyo when it comes to hand measuring equipment, I've put mine through hell, the only thing that's prone to wear is the thumb wheel insert for the Vernier. The batteries seem to be magic as i'm still on the first and I ALWAYS forget to turn it off. The only advice I can give is with buying, if the price looks too good to be true, then it probably is, always stick with the approved suppliers to avoid the disappointment of buying a fake, it's worth it to just buck up and pay the cash, I've found. Michael W |
28/08/2017 16:16:43 |
It's important to understand there's no equity between what material you choose to cut with vs. knowing how to sharpen tools. So learning how to sharpen and change the qualities of HSS tools is definitely worth the experience. There's no replacement of HSS when it comes to taking the finest of cuts from a sharp tool. Michael W |
Thread: Powering high frequency grinders with a VFD? Also how good are HF tools? |
27/08/2017 23:58:27 |
Posted by Mike Poole on 27/08/2017 10:36:23:
Air tools and then battery took over 25 years ago or more. Mike Air tools can be great if you're at a factory where they're compressing air anyway and much cheaper per unit cost. Having said that, it's not without it's problems at times, moisture in the system, pressure drop at peak demand... Tends to be seen much more in industrial environments, rather than a home workshop, they're noisy and expensive to run and pretty terrible in terms of power efficiency (get the electricity to run the compressor, in order to use a tool rather than just running the tool straight from the power). Michael W Edited By Michael-w on 28/08/2017 00:07:04 |
Thread: What type of DRO is this |
27/08/2017 23:49:29 |
If it's all you can get then fair do's, Sherline have a system that counts the handwheels, but it acknowledges the shortcomings of this, allowing you to program an axis offset. and it reads it all from one "readout" hence the name. Glass scales, with an independent readout are normally considered the ideal. I use the system sold by arc. If you want one on the cheap, I believe you can get some magnetic, Vernier type scales with a little readout unit from machinedro. This would also take into account the backlash of the slide. But they probably wouldn't last as long, as well as the batteries to contend with of course. Michael W
Edited By Michael-w on 27/08/2017 23:53:57 |
Thread: What Did You Do Today (2017) |
26/08/2017 12:44:46 |
Posted by duncan webster on 26/08/2017 00:02:38:
I earned my living in engineering for a long long time, encompassing industries as varied as steam turbines and nuclear decommissioning. I've never come across any company which employed a blacksmith The U.K army seem to have them, albeit described slightly differently: **LINK** Michael W Edited By Michael-w on 26/08/2017 12:46:34 |
Thread: MEW READERS' TIPS - A Change in the Rules. |
23/08/2017 16:16:18 |
Posted by XD 351 on 22/08/2017 18:57:30:
Perhaps a discount voucher for their next subscription ? Ian. hmm, i'd prefer something tool-like (or voucher towards tools) myself, as a prize rather than a discount for something i'd buy anyway. Michael W Edited By Michael-w on 23/08/2017 16:16:55 |
Thread: What Material for 5C collet Rack |
21/08/2017 20:47:49 |
I agree with XD; you could go all fancy and make something you want to be proud of but to be honest, I've made collet racks and tool holders just out of scrap soft wood and steel angle brackets, I'd rather use what's to hand than spend money on new materials. i'm not trying to win a prize for it, I just want a place to put my things. In terms of tools to use, large drills or wood bits for small inserts and hole saws for large / or morse taper inserts. Just deburr it all by hand with a sharp blade. (In my case I prefer kennedy red plastic handled blades from Cromwell, but it really doesn't matter.) Michael W Edited By Michael-w on 21/08/2017 20:52:16 |
Thread: 3D Printed Threads |
21/08/2017 19:08:23 |
Posted by Journeyman on 21/08/2017 11:29:39:
Posted by SillyOldDuffer on 21/08/2017 11:17:05:
That's an impressive demonstraion of precision 3D technolgy in the home isn't it! Very interesting, I want one...
I got one... You won't go far wrong with the one Neil has. See Factory 3D Kit Build for more info. John Edited By Journeyman on 21/08/2017 11:43:37 Just make sure you catch them on a good day, they're running at full capacity most of the time! Michael W |
Thread: Effect of Tensioning a Boring Bar |
19/08/2017 22:27:34 |
Posted by ega on 19/08/2017 17:13:28:
Posted by jimmy b on 19/08/2017 15:19:39:
here is a video on using Kennametal damped boring bars
theywork!!!!!!!!!! Interesting video but how many model engineers need a 1" or more diameter boring bar? The adjustable tuning mechanism was not described. Do you know what principle is used? I've got a 20mm boring bar, not far off it and I wouldn't consider myself a professional user. Have I used it? Well yeah, once or twice but obviously big stuff doesn't come round often as much as smaller stuff. (My lathe machine is far from a top-of-the-line or professional ones you occasionally see, but definitely bigger than a mini lathe.) My guess would be that those screws on the surface are preloading the tension of the internal bar inside the tube. Michael W Edited By Michael-w on 19/08/2017 22:33:12 |
18/08/2017 21:06:52 |
This tensioning idea does make sense if you're going to try and bore a large and long cylinder, say 250mm long, guarantees are you're not going to have the same size one end as you do the other, regardless of dialling in the cut. Michael W |
Thread: Health and Safety shoots down entire RAF |
17/08/2017 16:05:04 |
Posted by Neil Wyatt on 17/08/2017 15:07:58:.
The Harrier is a fifty-year-old design. The Spitfire was only a thirty-year-old design when the harrier was introduced. Come to think of it, lathes and mills are pretty old too! 3D printers are based on 70's technology and that's treated like the new kid on the block. One of my favourite English planes was the dehavilland vampire. Michael W Edited By Michael-w on 17/08/2017 16:07:15 |
Thread: Milnes Type 'R' Lathe on eBay |
17/08/2017 12:30:07 |
Now it's in Brandon, and you all know that's the gleaming heart of humanity. Glorious Brandon reign eternally. Wonderful little lathe though. Michael W |
Thread: Workshop Walk |
17/08/2017 12:26:22 |
Posted by larry Phelan on 17/08/2017 12:02:36:
Could it be that the Rust Fairy is selective ? It largely depends on what kind of atmosphere they've been sitting in, a dank or moist environment will rust even protected chucks far quicker than ones sitting in a bone dry environment with no protection. I find some kind of thick viscous grease will protect chucks quite well when they aren't in use, you might want to rub them down when you do use them. Michael W |
17/08/2017 12:18:40 |
DP Edited By Michael-w on 17/08/2017 12:20:16 |
17/08/2017 12:17:11 |
Posted by Roderick Jenkins on 17/08/2017 09:21:54:
Posted by Ady1 on 17/08/2017 07:46:02:
The Liberals have succeeded where Adolf failed "adjective: liberal
1.
willing to respect or accept behaviour or opinions different from one's own; open to new ideas."
Not yet a term of abuse in this country. Rod Yes, beneficial in moderation but not without a catch.. I forget (May have been Carl Sagan) who once said "It is good to have an open mind, but not so open that your brains fall out" Michael W |
Thread: Blunt hand rea.mers |
15/08/2017 19:29:04 |
I would just run a small sharpening stone up the side of it or maybe a diamond lap or file, normally on 1/2" theres plenty of room to do this without scuffing up the geometry. Michael W |
Thread: Up the garden path to new lathe |
13/08/2017 20:55:27 |
Posted by mechman48 on 13/08/2017 20:52:16:
Ah but you missed the stain at the tailstock end on the floor... or was that where your pooch left its mark... Given the environment, I think it's more likely an old oil spill Great lathe, Btw, Rik; now you've got to put it through it's paces. Michael W Edited By Michael-w on 13/08/2017 21:00:25 |
Thread: Hello from Turkey |
13/08/2017 20:40:26 |
Welcome to M.E, Levent I would start with some of Tubal Cain's (Tom Walshaw) books on simple stationary steam engines, I've found them to be a decent introduction. Of course, you can always post questions on here and the frequency and knowledge of the people on here makes this place a genuinely good tool to have in your arsenal, so to speak. Michael W
Edited By Michael-w on 13/08/2017 20:45:49 |
