Here is a list of all the postings Bernard Start has made in our forums. Click on a thread name to jump to the thread.
Thread: HBM 250-550 Lathe Tooling |
23/07/2023 17:28:03 |
Hi All for those of you interested in mounting a QCTP type 250-111 there is an excellent youTube posted by WBR Works "Lathe Rebuild Pt2" from 3:36 to6:18 Regards to all Bernard Start
23/07/2023 10:25:53 |
Sorry David I'm not sure if I have joined the correct topic. My comment is directed at your HBM 250-550 lathe. I see in other videos the 250-111 QCTP fitted to this lathe. Can you tell me how this is done with the existing post on the HBM top slide?
Regards Bernard |
21/07/2023 18:35:11 |
Very interesting! I have a AMABL250Fx550 Aka Wiess WBL250F. I see from the HBM Lathe rebuild Pt 3 YouTube that they have a QCTP 250-111 as does Precision Mathews but there is a boss on my 250 that prevents this. Any ideas please to circumvent this obstacle?
Bernard |
Thread: Back plate dimensions and tolerance |
06/05/2023 14:50:41 |
Not at all Dalboy. Sharing throws more light on the subject. However, I have just managed to stretch a Mitutoyo 25-50mm to 52.04mm |
06/05/2023 13:39:30 |
Thanks Dalboy, I am belt & braces and my skill with gessing sticks in restricted space and internal diameters is poor. I like to get measure three times, one independant before cutting. There seems to be a reluctance to discuss and share actual dimensions. Do you know why? |
06/05/2023 11:43:38 |
Thank you Dalboy, I see from your classic work bench you have lots of experience! I see you measured it. What was the register measure (5x.xxmm)?
06/05/2023 10:52:00 |
Thank you Circlip, This machine is just off the production line and has not been used in anger to wear it. |
06/05/2023 09:47:24 |
I wish I had a go - nogo plug gauge or I'll be happy with the dimensions. |
05/05/2023 19:20:12 |
Hi Jason & Mike thank you for your latest posts. Especially Jason's photo. I have enough ammunition now. I want the exact dimension of the register so I can make a plug gauge to bore the hole in the new backplate. I cannot keep stripping down the chuck to test it on the nose! I find it extreemly funny (and anoying) that this basic dimension is not in the manual. |
05/05/2023 19:11:07 |
05/05/2023 18:58:57 |
Hi Niel thank you for your interest. The lathe is a Weiss WBL250F manufactured 11/2022 The spindle is basic 3 hole and not camloc. The spindle flange is : - 15mm thick 100mm diameter 52mm diameter register boss 8mm register boss hieght 24.5mm spindle bore 3 M8 fixing studs on 75mm PCB All with my guessing stick I hope you are unbaffled
05/05/2023 17:15:10 |
Thanks SOD your solution is on hold for the worst senario even with a BP. In the meantime I try to do the best. |
05/05/2023 17:09:13 |
I am sorry I think I may have caused some confusion here. The EC32 Collet chuck I have has a 72mm register rebate on rear and cannot be offered to mate with the spindle which has a 52mm boss register. Hence the back plate and the need for accuracy. I will not be happy with any solution that involves drilling, reaming and pining the spindle face in situ. |
05/05/2023 16:22:27 |
Jason you hit the nail! |
05/05/2023 13:41:11 |
Thank you Mike. I do indeed mean ER32. I should know I own one already. It has spent the last 10 years on my ML7 which is being replaced by a Weiss WBL250F I just want to put it on my new 250 and need a new FP which I hope to make as good as I can. |
05/05/2023 12:35:52 |
Gentelmen thank you for your interest and help. The title was FP (Face Plate) for Wiess 250 (Chinese) look-alike Warco WM250. I am searching for a simple drawing of the spindle face (nose) showing register and stud PCB dimensions with tolerances. The UK dealers Warco and Amadeal have no stock. This I am sure you know this is so critical to get minimum run out so I do not want to rely on my guessing stick. |
04/05/2023 16:32:23 |
HI I am Bernard Start in Corbridge. I am preparing to make a backplate for a EC32 collet chuck. I have measured the spindle face with a caliper and find register 51.96mm and 65.20mm btween 3 studs or 75.20 PCD (Pitch Circle Diameter) I would apreachiate guidance to more accurate measurments. I would be happy to share a beer at my expense. |
