Member postings for Eric Sinclair
Here is a list of all the postings Eric Sinclair has made in our forums. Click on a thread name to jump to the thread.
Thread: Lathe protection
16/07/2021 17:31:50
You could try a commercial rust proofer such as Rocol Z30. Not cheap though.
Eric
Thread: ME Fastener Suppliers?
20/10/2020 21:05:28
Lee Springs have a huge range, not cheap though.
Thread: Shiny Chrome type paint
20/04/2020 15:33:43
Molotow liquid chrome pens are very good.
Thread: Dam Solution?
09/08/2019 19:46:56
Posted by Michael Gilligan on 09/08/2019 18:18:56:
Posted by Eric Sinclair on 09/08/2019 17:54:00:
I'm interested to know how the 70% failure probability mentioned earlier was calculated. [ ... ]
Eric
Estimated [not Calculated] was the word that Bill used ...
From something [as yet uncorroborated] that I was told today; that estimate was a 'gut feel' based on one of the very early videos of the spillway event. ... These are probably worth a second look.
But putting a number to a gut feel gives it an unwarranted weight. I wonder how much experience of similar circumstance the gut feel was based on. Unless it was vast I would argue that a numerical probability should not have been used. I stick by my gut feeling of the error bounds (noting the inconsistancy of that).
09/08/2019 17:54:00
Posted by Marischal Ellis on 09/08/2019 17:31:49:
Hullo everyone,
Not familiar with the area, but if the dam is for making up the canal where locking down can mean a big loss of water, such that further operations are delayed until more water is available, which could have made the canal uneconomic at the time, then a possible modern way would be to back pump from lower down so recapturing the lock discharge. Dead easy....... but not quite! Big pumps, ducts, track excavations, a basin, and all that. An interesting problem. What to do with the old dam? Dead easy.......but not quite! Perhaps let it grow into an attractive ruin. Sailing club and an SSSI could be very expensive. You can see the lawyers circling already as there will be much to be had. The residents fear ....it won't go away. A few sleepless night for some people in charge.
Best wishes to all and happy modeling.
I believe Combs reservoir will feed the canal system.
I'm interested to know how the 70% failure probability mentioned earlier was calculated. Probabalistic structural integrity assessment is possible, but it is difficult and requires a vast amount of data. I suspect the error bounds on that figure are approximately +29%/ -69%.
Eric
07/08/2019 15:18:34
Posted by Samsaranda on 07/08/2019 13:59:44:
Shouldn’t be a problem discharging from the pumps into the canal as canals have their own discharge spillways strategically positioned along their length to discharge excess water and prevent said canal from flooding.
Dave W
The canal over spills into the Goyt at Whaley canal basin, perhaps 20 yards from where any water coming from the reservoir arrives.
At its closest point the Goyt is much closer to the reservoir than the canal.
The flow channel from the reservoir to the canal is not large: you would not get much flow down it.
Pumping into the canal instead of the Goyt would not have been in any way a reasonable option.
Thread: DraftSight no longer free
28/03/2019 21:02:39
Posted by Russell Eberhardt on 28/03/2019 14:15:33:
My copy is 2018 sp3 and works without an internet connection but comes up with a notice to say that news and community features will not be available. I bet it will stop working though!
It does seem very unfair as, although Qcad will read and work on simple drawings some of my drawings are virtually unuseable in Qcad as it confuses layers and uses different font styles and sizes for dimensions. Perhaps it will be worth exporting all my drawings in various dxf versions before Draftsight goes tits up.
On the other hand perhaps some kind hacker will come up with an unlocked version that will keep working.
Russell
Russell, what problems have you find with layers when reading Draftsight dwg files in Qcad?
Eric
Thread: E bay
24/02/2019 13:31:10
Try an ad blocker. That worked for me.
Thread: Simplex 3.5 (Simplex Minor?) - help requested
25/10/2018 08:09:27
Simplex Minor was serialised in Model Engineer starting with issue 4024.
Watch out for the dimensions there are errors. The one I remember in particular is a 0.5" difference between the cab and tank side length and the corresponding length on the frames.
