Here is a list of all the postings BW has made in our forums. Click on a thread name to jump to the thread.
Thread: Anodising |
27/11/2016 05:23:19 |
Posted by David Clark 1 on 30/03/2010 16:43:36:
Hi There
Check out the digital free copy of Model Engineers' Workshop.
It has a good article on anodising.
regards david
Where do I find this please ? |
Thread: how does this ball turner work ? |
27/11/2016 01:16:53 |
See first photo in this article. Not the same tool, but a similar idea, and much easier to understand. http://www.haythornthwaite.com/133%20Spherical%20Turning.pdf |
Thread: WHat can you make with these things ? |
23/11/2016 08:07:32 |
Am curious. Anybody ever seen one of these things in the flesh ? http://www.ebay.com.au/itm/6-In-1-Multi-Metal-Mini-Wood-Lathe-Motorized-Jig-saw-Grinder-Driller-Milling-Set/322027988900 What materials can they realistically cut ? |
Thread: Defunct Hard drives |
05/11/2016 10:34:59 |
I've got a vague memory of seeing a photo of a dremel type diamond disc stuck onto a computer drive and then used to sharpen things. Bill |
Thread: Richard Smith Toolpost Handle |
04/11/2016 12:43:21 |
In the latest new there is a description of a tool post by Richard Smith, page 35. If the tool post is pivoted by using a spanner on the flats at the base of the thread then what is the purpose of the big handle that fits in the hole at the top of the post ? At the moment am struggling to understand the purpose of this handle.
Bill
Thread: Digital copies of MEW on disc |
22/10/2016 10:12:02 |
Posted by Neil Wyatt on 21/10/2016 19:39:49:
We were on the verge of producing a DVD of MEW, more than £14 but much cheaper than the price charged by many American magazines. We had a change of staff ad it 'faded' I will see what we can do. Neil Yes ! Good idea. I'd be interested in a DVD Bill |
Thread: Why is skiving not used more frequently |
20/10/2016 04:51:18 |
Posted by Neil Wyatt on 19/10/2016 15:31:01:
It does look a lot of extra effort for questionable returns. It does remind me, however, of the finishing tool like a D-bit turned through ~70-80 degrees that supposedly can remove 'cobwebs' of metal. Neil Neil, Ironically, I usually get a superb finish using that tool, even on cruddy "black bar". I know it as a "vertical shear tool" or a "shear tool" - well documented here http://www.gadgetbuilder.com/VerticalShearBit.html It removes cuttings as fine as steel wool - quite amazing - it was my first ever succesful tool grind. To date I have been completely unable to get a good finish with the standard round end HSS tool bit. I usually get a good finish if I turn a knife tool around to almost rub - as mentioned by Sparey and Westbury in their books - I can also get a good finish if I turn a tangential tool around by 90 degrees to turn it into a shear tool, or put a big radius on the cutting corner, but a conventional round grind HSS bit - never worked for me. ......... and thanks very much to everyone for all the replies on the skiving. This is called gear skiving and I think it is amazing ............ https://www.youtube.com/watch?v=XUDkQQJ8Uyw there are various other videos on youtube.
Bill |
Thread: Why dont we have end mill gear cutters ? |
19/10/2016 13:13:11 |
I saw a post a while back on this forum about end mill type gear cutters. A bit like a corner rounding end mill cutter only it cuts the profiles between the teeth. Thought it was a stunning idea and am aware that somebody in USA has a patent on it . I reckon people must have tried diy versions but have found very few references in google - I did find on google a mention of a video by John Stevenson - is that the same chap that posts on this forum ? Am puzzled that I havent seen much about this in forums, blogs and old books - is it something that would impress a newbie like me but more experienced people instantly see various traps ?
Bill
19/10/2016 13:04:53 |
I get the impression that not many people use this technique - only a couple of videos on youtube and not much in forums and blogs. It seems like a terrific idea to me ........ why is it not popular ? Bill
Thread: M8 tapping drill |
15/10/2016 08:27:14 |
Posted by Neil Wyatt on 11/10/2016 14:42:50:
Posted by Roderick Jenkins on 11/10/2016 11:28:56:
even down at 60% the shear strength of the thread is 2.5 times the tensile strength of the bolt core As soon as you allow for minor deformation under tension spreading the load over two or three turns of the thread there is more strength in the thread than the core. That's why you rarely strip a screw but normally either snap one or pull the thread out of the hole (when its in a softer material like CI or Ally). Neil What books should I be reading to be able to understand material strengths & properties and be able to intuitively know things like this in a few years time ? Bill |
14/10/2016 11:06:00 |
Thanks for replies. Corrected link http://www.model-engineer.co.uk/editorial/page.asp?p=1278 look through the index and see the photo labelled page 80 Hopper, I've looked at the photos again and your comments make sense to me. Will now read the article again and with this new understanding the photos and the drawings will make more sense. Will try to better understand the two pivot points as well. Thanks again. Bill
14/10/2016 08:38:21 |
Has anybody made the ball turner described by David Fenner in the 25 year anniversary special edition ? I've read the article a couple of times now and I don't "get it", I don't understand what the piece attached to the back of the cutter is for and why its connected to the other arm that comes out of the back of the main block. Its a repeat of the article in volume 127 July 2007 Photo on this page its the article that starts on page 80. model-engineer.co.UK/editorial/page.asp?p=1278# |
Thread: when not to use mild steel ? |
01/10/2016 14:02:29 |
Hello ........ Am wondering what books / websites / threads / back issues of magazines I should be reading to get a better understanding of what I can and cannot use mild steel for and when I should start considering other materials ........... For example - I've made a copy of my lathe nose - 1.5" diameter x 8tpi out of mild steel, what should I be reading to find out whether or not I could use that in a diy wood lathe - am guessing that things like that should be hardened high carbon steel ? Similarly have made a couple of morse tapers in mild steel - they seem to work okay but I think the bought ones I've got are all hardened steel. Would a "light use" hobbyist, like me, be able to get away with using mild steel for some things whereas in an industrial situation things like these would always be made of stronger harder materials ? What logic do others apply when deciding what materials to use to make a part ? Bill |
Thread: CNC beginers books web pages etc |
16/09/2016 15:53:51 |
Found this WWW.cncintheworkshop.com - website for the current CNC articles in mew Didn't realise that the website gives access to all articles from issue 203 onwards
16/09/2016 15:00:56 |
I'd like to better understand what cnc machines are and what they do, I've ordered all of the available books in the Victorian public library system. Is there a Sparey or a Harold Hall equivalent who writes introductory books for cnc machines and 3d printers ? Any mugs guides or good introductory forum threads or web pages you can recommend ? Am wary of buying a book that might turn out to be a dry as dust library of computer codes. Regards Bill
Thread: Myford ml7 21 tooth change gears |
15/09/2016 07:01:04 |
OK,
Please ignore previous post. Found a heap of 1/5" timing wheels up to 72 teeth here http://www.globalindustrial.com/g/motors/timing-belts/aluminum-timing-belt-pulleys/XL-1-5-pitch So as per Michael G's post can see how to run a hybrid sysem with a 21 drives XX joined onto a standard change wheel. Thankyou Michael - good idea - have bought a 21 tooth for $5.47
Bill
15/09/2016 06:17:30 |
Posted by Michael Gilligan on 29/12/2015 17:52:04:
This 21 tooth Timing Pulley may be of interest. I bought 'the last one' today, but presumably there will more available sometime. MichaelG. I've been pondering this 21 tooth pulley and the following photo posted by John S. I found this link for different belt lengths - https://sdp-si.com/eStore/..%5Css%5CPDF%5C15501003.pdf - and I note one can buy the belt by the metre and make your own custom belt lengths, cannot find many different sized big wheels (found a few up to 36 teeth nothing bigger) to stick at the other end of the belt from the 21 tooth - have concluded that it would be a pain to make them. What should I search for please ? Are these standard items I would know more about if I was conversant with cnc machines and 3d printers ? Bill
14/09/2016 14:16:14 |
Posted by Neil Wyatt on 14/01/2016 09:47:56:
Posted by Roderick Jenkins on 14/01/2016 09:26:10:
That's the first really clear explanation I've seen of why a 63 (or 21) tooth gear works so well, as a driver, for metric conversion. Shame on you Rod, you must have missed the excellent article in MEW 204 Neil From Issue 204 : These should be cut by thread milling, using the leadscrew to turn the mandrel with the lathe switched off. To dothis a toolpost milling spindle and a leadscrew handwheel such as that described by Alastair Sinclair (Model Engineer’s Workshop, issue 91, July 2003) will be needed. Am curious ......... what would the milling cutter look like in the thread milling process described above ? Would it be a very skinny vee shaped end mill ? or a chunky slitting saw with a vee shaped cutting profile ?
Thread: screwcutting |
11/09/2016 12:30:38 |
Hey Les, That issue has been bugging me too, Windows Vista, I think its similar to Windows 7. Do you have to copy an entire directory or just a few files ? If you do this sort of thing with any program do you have to somehow tell the computer to look in the new directory or does it simply just find the files wherever they are ? I dont know much about computers Bill |
11/09/2016 05:30:05 |
OK, I contacted the Lathegears author. Download for PC available here 9dt553xj8vnwzyf/LGV1.2.exe?dl= Why I think its so good ............ You can set a maximum error ie 0.3% and it will only calculate combinations inside that tolerance You can include all gearbox ratios as well as all change gears You can specify certain gears must stay in certain positions. If no combination exists it will calculate the number of teeth required on the missing gear Will calculate both metric and imperial threads for both metric and imperial lathes Will output all results to a file on PC and you can then copy and paste or print or do further calcs in excel.
Bill |
