Here is a list of all the postings Dwayne Clark has made in our forums. Click on a thread name to jump to the thread.
Thread: Myford Hoover Motor |
02/12/2020 04:17:09 |
Just curious, was the bagpipe maker Hugh MacPherson? Hugh made my first set of pipes. Cheers Dwayne |
Thread: Insert for internal ACME thread? |
19/11/2020 19:09:11 |
Just grind a tool out of high speed steel and cut the thread. This was one of the first jobs I did in my apprenticeship. Somewhat intimidating at first, but really not that difficult and a great learning experience. |
Thread: Boring a cylinder |
18/11/2017 20:59:07 |
Set your tool a frogs hair above center, be sure it is absolutely sharp, use as big a bar as possible and maybe sloww your machine down a wee bit. |
Thread: Is a tool & cutter grinder worth having? |
10/11/2017 20:39:46 |
If you are running a milling machine and using larger cutters,ie greater than 3/8" or using broaches a tool and cutter grinder is a wise investment. IMO |
Thread: Chucks |
25/05/2017 05:28:13 |
Four jaw is much safer, way harder for workpiece to come out of the chuck! Take only a wee bit longer to setmup,but gives a much more secure and accurate setup. |
Thread: Brazing carbide |
13/05/2017 03:03:35 |
Silver solder onto mild steel shank. Make sure everything is clean and fits reasonably well. |
Thread: Workshop thermal gloves- advice please |
27/02/2017 00:22:56 |
Might be worth trying a chemical finger warmer like skiers use. Instead of putting it on your fingers, try placing it near an artery upstream of your fingers. |
Thread: Engineer's Blue |
22/10/2015 03:30:27 |
I think you might be looking for what we call Prussian Blue in North America. Cheers. |
Thread: Plasma Cut wheels |
01/05/2015 03:51:52 |
Water jet cut might be a little nicer, less distortion etc. |
