Member postings for mark brockley
Here is a list of all the postings mark brockley has made in our forums. Click on a thread name to jump to the thread.
Thread: Make your own 'Air Rifle'
11/07/2018 17:55:58
I know this is now an old post but I have seen the for mentioned book along with a book I think called the tool makers air gun. Is it legal to make your own gun ? I now there is a power limit in the uk 12ftp for a rifle but do remember an article the other year saying the powers that be wanted to licence the purchase of engineering equipment to combat illegal guns. I think this was regarding the conversion of imitation guns though.
Thread: Small polyflex belts
12/09/2017 13:07:09
Hi Dave
I think the 5M730 belt is the one to try it will be a lot less strain to change on my fingers and more importantly the belt !
The bearings will probably have less of a hard life as well.
12/09/2017 10:49:25
The replacement belt was a genuine gates so at least I knew it wasn't a cheep copy. Cant be sure of the original on the lathe though.
I am concerned on how tight the belt is to change speeds with the tension leaver in the slack position I cant see any way to reduce the tension the idler gives to the belt.
I have been told the belt size has changed but that's ok. I am doubtful the layout of the position of the idler and pulleys have changed but who knows.
11/09/2017 13:00:09
That's an interesting point Jason the instruction manual supplied with the machine has no information on belt size !! and looks different than the link you have given.
I have been informed that belt sizes changed and have had to e mail customer services with the problems I am having.
Will see what they say.
10/09/2017 16:13:00
I did check the pulleys for burrs and polished them. The lathe is a Chester 920. The first belt just snapped with no warning at all just a noise like a rifle going off.
This second belt has 2 splits in it I will try and get a pic of it.
I will get in touch with Chester and see what they say as I have only had the lathe 3 months.
09/09/2017 14:56:48
The lathe has a ''clutch'' lever to de tension to start and then tension it up for running. I do think it is tight so with the new belt I bought I am leaving it in the start position as it is not slipping and to me feels tight enough.
I will contact the company next week but am disappointed with things so far.
I will check out the tension calculator cheers.
09/09/2017 13:14:08
Yes your right they are pollyflex not sure about them on washing machines but guess they will be
09/09/2017 12:32:28
Has anyone else had problems with the modern drive belts used on new lathes ?
Just under 3 months ago I replaced a small lathe with a brand new bigger machine. It has a bigger swing than my ML7 but is about the same length of bed. It is driven by a gates 5M710 belt .
Within 1 week this belt snapped after only a couple of hours. I was sent a replacement and I purchased a second at £16 !!!!
The lathe hasn't been used in 3 weeks due to health but the last couple of days its been used for just over an hour.
The V belt is cracked in 2 places and only held together by the fibber reinforcing .
Thread: variable speed lathes
24/06/2017 23:58:45
I have an ml7 and yes that will stall but the motor while getting hot after a few hours takes the heat but guess it is always running at a constant speed and the pulleys take care of speed so the fan does its job.
Did consider a second fan tonight especially as the motor is tightly encased so air circulation will be poor. Thanks for the info Paul its always good to get another persons thoughts.
I am thinking of rebuilding this lathe and selling it as I have seen a slightly longer bed lathe with better swing and a good speed range via pulleys.
24/06/2017 23:22:21
Does anyone have issues with variable speed lathes and the motors burning out ? Just cooked my second in 18 months. Drilling holes of around 15 mm and if it grabs can stall the motor. I did start small 4mm and worked my way up.
Thread: Metric Minnie
25/09/2016 00:10:41
Thanks again Jason I have had another thumb through the book and seen now the reference to soldering the plates in. I have realised after a search that finding hens teeth may well be easy compered to bronze bolts ! Your guidance is appreciated as this is my first big steam project and first boiler build.
Mark
24/09/2016 00:52:33
Thank you for that information. I have located my nearest / easy to attend ME club and will discuss with there boiler tester. Instead on the 3.5mm holes what do you recommend instead ?
21/09/2016 12:56:51
Can anyone advise I am starting a build of Minnie using a combination of the metric plans available and LC Mason's book. The plans say use m4 bronze with a stainless steel spacer. Could I use stainless all thread ?
Thread: Metric plans and kits
29/04/2015 21:39:44
Thanks will keep that in mind and ask before I have a go at it. Doubt it will be this year. Will also keep an eye out for he book as well.
29/04/2015 13:22:09
I thought I would struggle to find a Foden Jason thank you for all the links they give me some ideas. I will try and convert a small plan set I think. I am a relative youngster so have a good few years yet so the Foden can wait for now. I found on line the metric Minnie so that's worth considering. When I can Neil I will get it made and send you the pics.
28/04/2015 16:14:38
Thanks all I am more into the idea of a traction engine eventually and would like it to be a Foden due to family links several generations ago to Foden. I have found a plan on the net for 2 simple stationary engines and made a start on one. My background is as a clock maker so anything involving clocks goes down well. I intend to make the depthing tool shown in the last 2 MEW.
28/04/2015 11:45:42
Can anyone give me an idea on where to find kits and plans in metric ? I know you will all say its easy to convert from imperial but after a stroke some years ago I prefer to stick to metric.
