Member postings for Brian Thorby
Here is a list of all the postings Brian Thorby has made in our forums. Click on a thread name to jump to the thread.
Thread: EMCO compact 8 parts
15/02/2016 16:30:53
You EMCO Compact 8 /8E men will probably all now be aware that replacement Cross Slide Leadscrew Mount BA4 020020, which falls apart in its original die cast Mazak form, is now replaced by a "machined from solid" version .In stock at PRO MACHINE TOOLS. Ive just ordered one at £58.20 inc VAT /Postage
Does anyone make an adapter flange for the 8 (with its special DIN Nose /hole centres)to enable fitment of cheaper oriental chucks etc
Cheers
Thread: Spotfacing Tools
12/02/2015 11:33:00
Thank you gentlemen for your so prompt suggestions.Arc's set doesn't go to 20mm cutter with a 10/10.5 dia pilot which is my first size objective.It looks as if I will have to make some,but will try MSC .Thanks again.
12/02/2015 09:17:12
I require a series of spotfacing cutters to suit hexagon nuts/washers on M6/M8/M10 sizes. I have searched online and the regular tooling retailers and all I get is the Counterboring Tools for Socket-Head Cap Screws i.e too small counterbore in relation to washer seating size of a regular bolt or nut.Can anyone suggest who sells such mundane tools, before I have to make a set ?
I am machining aluminium castings.
Thank you
