Member postings for Dave Halford
Here is a list of all the postings Dave Halford has made in our forums. Click on a thread name to jump to the thread.
Thread: Run out on bar
12/11/2021 14:46:50
Posted by Salvie Cudlip on 12/11/2021 10:39:41:
This was after I turned the bar down! Wouldn’t 0 indicated that the bar is now straight in the Chuck? Used a micrometer and reading same values either end!
He has
12/11/2021 12:21:04
Halfway there Salvie. Now you have a straight and parallel turned bar. Take the bar out of the chuck and turn it round to hold it in the jaws by your turned section, then see how much the bar wobbles if at all.
BTW some old worn chucks have been used mainly for small size work and will be bad at those sizes, but they are fine on the unused sections. For example I have a 5" chuck with 15thou runout for sizes under 1", opening the jaws further the chuck key goes noticeably stiffer and the chuck holds like a new one.
Thread: Insert size
11/11/2021 14:57:02
Are they all different types?
Thread: Book Your Covid Booster! Errr, How? Where?
11/11/2021 12:18:18
It seems that as others have said sites come and go on the list depending on bookings so if someone takes a walk in jab their booked appointment gets cancelled and the system throws open the slot again. Blink and you missed it.
11/11/2021 11:35:52
Round bright bar is neither very round nor very straight, the chuck may be fine.
A new 3 jaw may have a 3thou wobble built in, some may be perfect.
Rotate the bar bit in the jaws and re tighten it may be better.
Thread: Guillotine
09/11/2021 21:00:59
Or one of the scissor style?
Those are a lot easier on the hands than snips and will cut 3mm steel, even the short one with a handle extension.
The waste is quite curved
Edited By Dave Halford on 09/11/2021 21:02:04
Thread: Bench mill problem
09/11/2021 12:34:48
Posted by Phillip Priestley 1 on 09/11/2021 12:22:49:
Yes I had to twist them round to obtain the details from them, it now starts every time, I think I should be sourcing a new pair of capacitors for my peace of mind. To answer another question I bought it new, so the capacitors are the ones it left China with!
Phillip
By 'check the wiring isn't bad' I mean check the wires aren't loose in the spade connector crimp, that bare wire is actually touching the spade connector (and hopefully welded to it) and that the spade terminals are not loose on the cap body.
09/11/2021 12:04:49
Posted by Phillip Priestley 1 on 08/11/2021 20:19:14:
Hi, Thanks for the replies, I took the easy option and ran it in fourth gear for ten minutes, naturally it started straight away in top gear, then I left it a while and it would only start after I ran it in fourth again. I have just been back to remove the capacitor covers to obtain the details on them, replaced the covers and lo and behold it started first time in top gear! I am now off to sit in a darkened room for a bit!!
Phillip
Did you move the wiring, twist the caps round to read them etc. If so just check the wiring isn't bad.
09/11/2021 11:58:25
Run caps are in the 400V range
Start caps are 250V
The construction is different.
Thread: Warco WM 16 motor
08/11/2021 19:42:45
Posted by Tony Pratt 1 on 08/11/2021 19:31:25:
Posted by Nicholas Wheeler 1 on 08/11/2021 19:13:42:
Posted by not done it yet on 08/11/2021 18:15:02:
All ‘old hat’ vintage British machines still working very well, even though 60-70 years old.🙂
The remaining ones are. How many were used up doing the jobs they were bought for?
A 60-70 year old m/c will be worn out, much like a 60-70 year old human.frown
Tony
They both persist in still working too wink
Thread: Boxford model CUD mk2 lathe
08/11/2021 19:39:56
I suspect it's a CUD that tripped on the pub doorstep during a heavy night out, it might pay you to look for cracks in the apron.
08/11/2021 19:20:52
75%
There's a need for unburstable piecework machines out there.
Edited By Dave Halford on 08/11/2021 19:25:15
08/11/2021 15:01:21
If you run it first in 4th gear for five minutes and then start it in 6th is it better?
If it's OK like that, the oil just needs to warm up.
08/11/2021 11:53:17
At least you can say the control board is as tough as nails.
I'd love to see a photo of the chips that machine produces.
07/11/2021 19:04:09
Ian, what motor speeds and cutters do you normally use?
Thread: Mill table wonky
05/11/2021 20:55:21
Under one end or both?
Thread: NVR Switch
05/11/2021 13:30:24
That switch stack looks fairly open, you could try a blast of compressed air.
Thread: Music on TV Programmes.
05/11/2021 13:24:15
Posted by Samsaranda on 05/11/2021 10:03:37:
I have very damaged hearing and wear strong hearing aids, the “background” music makes listening to tv programmes a nightmare, because of my hearing impairment subtitles are permanently displayed if available. The music seems to vary in volume so much, usually at its peak drowning out the speech and I end up trying to lipread the person or reading the subtitles, there is no reason for the background music and having complained to the BBC about the problem never received a satisfactory answer. We have a sophisticated sound bar to enhance the tv sound and that makes no difference, I also have WiFi enabled hearing aids which connect with a WiFi transmitter attached to the tv, again nothing overcomes the music drowning out the speech. My theory is that a large proportion of the population have damaged their hearing listening to very loud music, pop concerts etc, that they are oblivious to the problem and the music probably acts as tinnitus masker. Dave W
Having met a BBC producer once they know much better than you non media types do.
It's noticeable that some channels always have fuzzy sound, the Sony movie channels were the worst. Discovery seems quite good. Switching between to two told me it's not my ears nor the set, though it could be the sampling rate is too low for a late 60's brain to fill in all the gaps.
Thread: NVR Switch
04/11/2021 12:21:36
Hi Lynne,
By 'the lathe' I take it you mean your ML7B in your photo album. So you should have the NVR as your motor on/off contactor, then the forward/reverse switch, then the motor.
It sound like the NVR is in the wrong place.
Thread: 3 Way Vice?
03/11/2021 17:40:12
In vertical mode the handle ends up where the drill head is so it's not as clever as it sounds.
