Here is a list of all the postings Dave Halford has made in our forums. Click on a thread name to jump to the thread.
Thread: air compressors | ||
31/01/2022 17:20:31 | ||
That one is 2 CFM FAD, which is the real air delivery. This is from a random search Air compressor reviews The 5724 might end up more useful. | ||
Thread: Boxford VSL 500 Drive Pulley | ||
31/01/2022 17:08:05 | ||
Posted by Roy Birch on 31/01/2022 16:50:06:
No that’s not a crack it’s the piece that was broken off which I have just placed on the hub Gear side photo so the other side of the pulley, there's a spiral of little black spots | ||
31/01/2022 15:37:43 | ||
Looks like there's a crack on the pulley side as well. | ||
Thread: Right to Repair | ||
31/01/2022 10:51:29 | ||
Posted by Adrian R2 on 31/01/2022 09:09:53:
Do you have a fault code reader? This has worked for me several times on my VW - plug in gizmo, get fault code, the free software I have explains some of them, others you have to do your own research. Best one was an intermittent misfire where the code pointed straight to a faulty connection in the cylinder head wiring loom, no way I would have found that otherwise. I would also check the tail light clusters for water ingress and corroded connections. Good luck! OBD 2 readers are both generic work on engines 20years old and cheap enough, however they only work on the engine systems. Anything else like lighting or traction control etc is maker specific and costs an arm and a leg. | ||
Thread: Cowells 90ME 14x1.5 backplate question | ||
30/01/2022 20:58:06 | ||
I would buy a 14 x 1.5mm tap and a disc of 6mm steel plate or cast iron and machine as required. | ||
Thread: Metal Cleaning Using Vinegar? | ||
30/01/2022 11:24:58 | ||
Farm supplies Molasses is £9.50 for 5L | ||
Thread: Steel tyres on alloy rims | ||
28/01/2022 11:07:22 | ||
Oddly back in the day I had an Aussie Ford Falcon Fairmont. It had composite wheels with alloy centres and steel rims without any issues, whereas Landrovers alloy door panels on steel frames would corrode where they touched. | ||
Thread: Britain Capstan Lathe | ||
25/01/2022 18:12:29 | ||
A member has one. | ||
Thread: The demise of UK fossil fuel Power Stations | ||
25/01/2022 15:12:45 | ||
Posted by Michael Gilligan on 21/01/2021 15:57:21:
Posted by not done it yet on 21/01/2021 14:26:35:
[…] useless, as are suggestions that it is simply more than about 23 degrees north of the equator. . You are really on form, aren’t you ! I answered your specific question accurately, then included two riders by way of trying to help. MichaelG. You are both wrong, anyone from London knows that the North starts just past Hatfield. | ||
Thread: Centec Myford Rodney | ||
25/01/2022 11:03:04 | ||
The tiny spindle bore. I had the same issue with a Centec horizontal spindle bore not matching the arbor that it came with. I found M6 studding fitted, welded a bit of bolt that fitted the arbor to one end and made a long M6 nut for the back as studding is usually a loose tolerance. | ||
Thread: Are you going to buy a milling machine | ||
25/01/2022 10:37:47 | ||
That things huge and takes up so much daylight, so why would you? | ||
Thread: skip find box of slot drills | ||
24/01/2022 11:48:23 | ||
Complete junk m8, I'll pm you my address and i'll safely dispose of them into my cutter drawer.
All you need to do is check the pointy bits are still sharp as that's the first place they go. No one keeps pristine cutter boxes to the throw the old blunt stuff away in. Those are new. | ||
Thread: Fabricating a Weber Carburettor Manifold Flange | ||
24/01/2022 11:12:55 | ||
Posted by Oily Rag on 23/01/2022 21:57:40:
I ran a 1275 (well 1310 actually) 'S' in rally trim in the late1960's with a Jim Whitehouse 'Arden' 8 port alloy head - fitted with 4 32mm Amal carbs. Given the car was a Group 'C' and was substantially lightened down to around 9cwt it performed sufficiently well to give an Escort Twin Cam or even a BDA Escort a good run for its money. The engine was giving about 130BHP; its 'transient' torque and the response with the multi carbs allowing short intake to valve head was vastly improved over the standard 5 port head, but the gearbox was always a problem even with straight cut de-speeder drop gears, TR bearings for the intermediate drop gear, and a full straight cut 'dog box'. Probably the major reason for my acute deafness now! Martin I remember that one Martin - respect. | ||
22/01/2022 18:58:28 | ||
Here's a man to emulate with an A series, no photo of the original metallic green version. The only 1300 that had to run against cars 3 times the capacity. | ||
Thread: solid carbide spade? bit for drilling spring steel saw blade | ||
22/01/2022 18:27:47 | ||
Spade bits are more for drilling glass. Any carbide twist drill will do | ||
21/01/2022 17:32:27 | ||
The two holes are the carb side the oval would match the blower intake shape essentially like your existing manifold only dropping the carb height and except the blower end would be a single oval port. Can I suggest that as you haven't cut the blower yet and IF there's room, that you try fit an 90deg elbow on the pipe flange (and a blanking plate on the other hole if it fits) your existing SU will do for size. The reason is SU's are known to work well on blowers and there's a lot less trouble with jetting (you can get a Gunson Colortune to check the mixture is in the ballpark. Some of them even had electric heaters to combat the icing. | ||
20/01/2022 11:09:18 | ||
So why not use a chunk of 40mm thick alloy and angle the ports down 45deg to drop carb or leave the blower un cut and use an SU on a 90 elbow and block the other blower port with a plate? Though that might put the hydraulics in the way.
My visualisation of mini bonnet space is of course now 50years old | ||
20/01/2022 10:08:42 | ||
As Jason says you can whittle that just as easily with hand tools and drawing around a card gasket. Side draft Webers were not a popular swap for minis back in the day due to the need to cut the firewall. Inserting a Merc blower in there at least fixes the issue of the carb trying to swallow the speedo. However why the u-tuber strangles the air flow into the blower so much with all that weld instead of lifting the carb plate up an inch and use all of the slot + the unequal length outlet ports from the plenum. Mind you he does say the kit that he sells is different so maybe you are supposed to try DIY then give up and buy from the 'expert'. | ||
Thread: 'Vision aid magnifying glasses', any good? | ||
19/01/2022 16:39:08 | ||
Note the working distances on the Axminster ones, all the others will be the same. | ||
Thread: Help need with Traction Talk | ||
19/01/2022 10:17:40 | ||
Posted by Oldiron on 19/01/2022 10:02:23:
I tried to view a couple of posts on TT this morning and was greeted by the following message. regards
Edited By Oldiron on 19/01/2022 10:02:46 That is just similar to having to be 'signed up' on here to post, otherwise I couldn't view and make posts on TT, which I still can BTW so not a recent change.
It has to said that TT has always been almost glacial on signing up approvals which doesn't exactly encourage new blood. Edited By Dave Halford on 19/01/2022 10:20:45 |
