Member postings for Nick Wheeler
Here is a list of all the postings Nick Wheeler has made in our forums. Click on a thread name to jump to the thread.
Thread: Drill sharpener
13/11/2016 18:29:47
Posted by John Rudd on 13/11/2016 18:13:48:
Adam,
I used the grinder straight out of the box....so to speak.
A visual comparison between a reground drill and a brand new one showed no difference in the geometry for either standard ground or 4 facet. Drilling performance of a reground drill appeared no different either compared to a new one. I did not think the stone was too coarse or too fine, very little dust produced from the process.
I bought one.
Read the instructions, and sharpened every blunt drill bit in the house(about 30 years worth, because you never throw them away right?) in about 1/2 hour. Well worth the £50 that it cost. Now I have to try and remember how to sharpen the blacksmiths's drills that I blunted on some awful work-hardening stainless that are too big for the machine.
Thread: Mixing fractions and decimal units in an imperial drawing
06/11/2016 20:14:06
Posted by Sam Longley 1 on 06/11/2016 19:52:38:
That is why the industry (construction) chose millimetres & metres. There can be little confusion between the 2 being such a big difference in size
The problem comes when people try to think between the two systems. Once they are tuned to think metric & forget imperial they find it easy. Do not think of a room in feet , think of it in metres. Unfortunately in the construction industry problems arise because in schools kids are taught to think in centimetres as well & carry that forward in future life.
That's exactly what my grandfather told me, thirty years ago - work in what you're given, and never try to convert. While I think in metric, imperial measurements aren't a problem.
Clive, I'm afraid you're going to have to explain the absurdity of your 5 miles example again, as I can't see how 11.45km is even remotely complicated? Whereas converting the mixed imperial units into one number to get that 11.45km was a pain.
Thread: 14mm spanner
30/10/2016 21:03:29
I've an old toolbox full of spanners and sockets that I rescued from scrap cars. I have absolutely no qualms about modifying them for special jobs. If that means chopping them down to fit or bending them to clear an obstruction, then so be it.
This was a tired 30mm socket with worn 1/2" drive hole. I bored the hole to accomodate a Torx socket, and welded on a piece of strap to make a spanner for my cambelt adjusters. I could have bought the cranked spanner to do the job, but this tool took about 10minutes to make and saved about £40.
29/10/2016 22:20:13
Posted by Neil Wyatt on 29/10/2016 21:42:03:
Posted by Maurice Taylor on 29/10/2016 19:30:10:
Ford cars use 12,14,15,16 and 18mm spanners
Back in the eighties I'm sure they had a way of making sure you needed all five sizes to remove something only held on by four bolts...
French stuff still does. That's before you discover that the bolts are made of an engineering grade of cheese.
Thread: Just musing
29/10/2016 19:52:21
Considering that Unipart was BL's parts division, millions of parts for thousands of cars would have been more appropriate. I bought a NOS driveshaft coupling for my sister's 1300 that looked like it had been machined with a blunt spoon.
28/10/2016 19:16:53
It's why every tool manufacturer sells spanners/sockets in sets. I'd never used a 15mm spanner until I bought a BMW. Before this week, the only place I'd used my 7mm socket/spanner was on Jubilee clips; it's since had a workout on Sukhoi turnbuckles.
Does it really matter if a European M8 bolt uses a 13mm spanner and a Japanese one is 14? It's the need for hex, internal hex, the same in Imperial and Whitworth, then Torx, E-Torx, Ribe etc, etc that rankles. 22 years ago I inherited some BA spanners from my Grandfather, that I've never used, but they are another standard.
Edited By Nicholas Wheeler 1 on 28/10/2016 19:18:37
Thread: Just musing
28/10/2016 00:33:01
If you drive a lot(and I used to do fifty thousand mile p/a for work) you see all sorts of lousy sign writing. As you say; a company name but no way to contact them, or so much crap on the van you can't make out what it's for as it passes you on the motorway are common.
Then there's the graffiti on vans: white with a hint of M25 written in the dirt of the filthiest Transit I've seen amused me.
Another game to play is spot the stupidest slogan. Some of them are clearly the result of a boozy lunch between an incompetent manager and a hapless advertising wonk: specialists in all types of repair was one I saw recently.
Thread: Tools I would like to have
25/10/2016 18:55:24
Posted by Speedy Builder5 on 25/10/2016 18:09:16:
FIAT - I thought it stood for "Fix It Again Tomorrow."
Why would you do that when you could "Frow It Away Today"?
Thread: Alternative to PC based Cnc controllers
28/09/2016 12:22:56
Posted by Zebethyal on 28/09/2016 11:56:41:
@sam
I don't think anyone is looking for a silver bullet, however, these units being discussed cut out a whole heap of steps that many simply don't want to be involved with.
The idea with one of these units is that you DON'T need to:
  • obtain a PC (free or otherwise)
  • install an OS (free or otherwise)
  • install any applications (free or otherwise).
  • buy any third party boards (Break out, Smooth Stepper, Mesa, etc)
You simply hook up your stepper drivers, PSU, etc, adjust some settings for your mill/lathe, upload some Gcode on a USB stick and off you go.
The front end takes up no more space than a DRO and looks professional - easy sell to the CNC newbie.
What will I make on it - I have no idea, probably parts for other projects. For me it is all about the journey, the satisfaction of having built it and the learning experiences gained along the way, many others simply want to get on and make stuff, and for those people these units are a no-brainer.
That list is exactly why I'm interested in one. I'm more interested in productivity improvements than some of the fancier CNC capabilities; automating the numerous small cuts necessary with my mini-mill would mean I could do more important stuff than just cranking handles. A conversion based around one of these units is going to cost a similar amount to a decent DRO, something else I've considered. I would get bigger improvements from a Bridgeport sized mill, but I don't have room for my current tools.
Spending months buggering about getting computers, operating systems, software, impenetrable electronic gizmos and mechanical bits working together would require time and patience I have better uses for.
Thread: Catering at shows
27/09/2016 15:28:09
Posted by Neil Wyatt on 27/09/2016 13:29:49:
Most shows are beholden to what the venue's caterers can supply. These days any good caterer should at least be able to tell you what is in what.
Having been to a lot of(mainly car shows) over the last 30 years, I'd like to know when it was decided that we'd all be happy to pay £6 for a slime burger and a can of warm coke?
Thread: Apple Car
22/09/2016 11:32:22
Posted by Roger Provins 2 on 21/09/2016 21:10:43:
Linux Car - the one you don't buy, it's free! Is supported by a worldwide web of enthusiasts, needs less fuel and is faster than its high priced competitors.
No, a Linux car is one that you have to assemble the mechanical bits, usually from junk you have lying around, and then install free software that was written 10 years ago for a 3 cylinder 10valve Gronkle engine, not your 5 cylinder turbo Aardvark. After six months of swearing and conflicting 'advice' you get it to run for 15minutes. Then you give up and buy a Ford that just works.
Thread: MEX Photos for those that stayed home
16/09/2016 21:48:24
Posted by Michael Gilligan on 16/09/2016 21:13:02:
Thanks for the photos, Jason ... Some lovely work there.
But what a shame that the exhibition thereof does not appear to do it justice.
... It reminds me of the 'Village Show'.
Imagine how much better it could be; with decent lighting, a few turntables, cameras and big TV screens.
That might be a little modern for many of the elderly gentlemen who were there. I thought it fit really well with the whole shabby amateur atmosphere that Brooklands has.
I did have a good time, and was quite glad that there were so few traders tempting me with stuff I want but can't afford.
Thread: Machine tool paints
15/09/2016 17:25:41
Posted by Ajohnw on 15/09/2016 17:11:32:
Some people in the UK have used stuff sold as military paint on ebay and reckon that they have had good results.
Old machines tended to use a rather heavy filler primer first and then some sort of enamel on top. This is what coach paints are more or less such as Tekaloid which I think is still available. One dodge with that paint is to thin with white spirits and leave for ?????????????? to dry. Several days in other words. That way it's possible to get a pretty high quality finish with a brush.
Via a spray gun i think I would try adding a retarder as I am not that skilled with them. Not sure if it's still possible to get car repair paints but with a retarder added they are fairly easy to use.
Interesting, as most people I know who aren't going to use a booth prefer a faster activator! I make no claim to be a painter, but swapping to two-pack paint and a (cheap) HVLP gun made a massive improvement to my finishes.
A quick look in the Yellow Pages will find a local supplier of any type of car paint.
Waiting days to brush on yet another coat of enamel isn't going to happen for me. Especially as anything I brush ends up looking like it was painted by a drunk blind man with his hands tied behind his back. Not that I'm ever going to paint a machine tool.
Edited By Nicholas Wheeler 1 on 15/09/2016 17:26:44
14/09/2016 18:08:11
Posted by Geoff Perkins 1 on 14/09/2016 10:51:19:
Maybe have a look at what the car restoration/modification enthusiasts use for major components such as engine block, gearbox, diff etc. that can't easily be done with the standard automotive body finishes?
Every one of those can be painted with anything you like from hammerite(which is hideous), through old-fashioned cellulose, two-pack to modern water-base paints. Thorough preparation is the important part, not the paint.
14/09/2016 13:52:57
I find it interesting that 2-pack paints are considered expensive and hard to get hold of. When a litre of 2-pack is just enough to paint a small car for about £40, how is that expensive? And then there is the convenience; if starting with a prepared surface, you could epoxy prime, primer fill, flat back and top coat the small areas on a small machine tool in a day.
13/09/2016 15:05:04
Posted by Neil Wyatt on 13/09/2016 14:13:25:
John's just popped round to show me the magic box, just PSU, box, stepper driver and a stepper on X happily whirring through a program that's been uploaded to it.
It's that just that defines the appeal of this magic box. I've considered converting my mini-mill to CNC on a number of occasions, and while fitting ballscrews with a motor attached doesn't worry me, the whole knee bone is attached to the shoulder blade with a gronkelwanger that simply(?) converts a thingy into a whatsit via PFM amplified by a side fumbling throbnozzle has always put me off. Add in the need to acquire, and find space for, a computer to work it all, plus the usual hideously unfriendly(and they're the ones you have to pay for!) software and the whole plan goes out the window. This way, the conversion should cost less than a decent DRO, and actually make stuff while I do something else - the real appeal of CNC for me as cranking handles to make simple parts is just boring work.
Top of the list of stuff to do when I can afford the controller.
Thread: Antiques Roadshow
12/09/2016 14:55:54
Posted by duncan webster on 12/09/2016 11:21:37:
Suggest relevant owner's clubs for drawings and bits and pieces. Chucking them is definately last option
If classic bike clubs are like car owners ones, John would save a load of time and grief by wrapping each metal part he has in a number of drawings, repeatedly smashing them with his biggest hammer and dumping the whole lot in the nearest skip.
Thread: security Wheel bolts
10/09/2016 16:29:52
Posted by peak4 on 10/09/2016 10:25:03:
Sealey, amongst others, do a 1/2" drive socket with a coarse left hand thread inside it, rather than the normal hexagon flats.
Try ebay and search for "Locking Wheel Nut Remover" to get some photos
I have a set of six different sizes of those. It's still common to find that the bolt is between sizes, or that the socket won't fit in the deep hole in the wheel. The better bolts tend to be harder than the socket; my success rate is about one in ten.
I have a different set that have a taper that you hammer on to the bolt. My boss supplied us with these, and none of us ever got them to work.
As for retaining the security bolts, in the thirteen years I worked for a recovery company, we had one job for stolen wheels. That was the only time we ever used the multi-fit slave wheels that some smooth talking saleman convinced my boss to buy. Damaged or lost locking wheelnut keys were a daily occurance. None of them are particularly reliable, the ones that use three or four pins to drive the bolt are shockingly bad. I won't have any of them on my cars.
Edited By Nicholas Wheeler 1 on 10/09/2016 16:30:41
09/09/2016 22:45:40
Posted by V8Eng on 09/09/2016 22:25:05:
Just out of curiosity, has he asked a VW Service Dept for advice? They probably had to do this before, my one seems helpful.
As will any garage that's been in business since before today.
09/09/2016 22:07:19
If there's a rotating collar, you need to chisel it off.
Then, you might undo it by hammering a socket over the remaining bolt.
You can buy sockets with a left hand thread to do this, but I find my set of six rarely have a suitable size.
You could try drilling them, but they are supposed to be hardened.
A die grinder will remove the head, but you do need to be careful of the wheel.
If there's room. welding a decent sized nut onto the bolt head might work.
You probably noticed a lot of mights!
Undo them all, and replace with standard bolts.
